查看: 1720|回复: 0
仿真时LCD一直显示DHT11采集的数据为0,求大神解决一下
请问是因为没采集到数据吗,还是时序问题呀  纯小白QAQ
DHT11代码:
#include"reg52.h"
#include"DHT11.h"
#include"delay.h"
#include <intrins.h>
sbit  DHT11_DQ=P3^7;
bit status;
void delay_10us(unsigned int nus)
        unsigned char i;
        i = 2*nus;
        while (--i);
void DHT11_Rst(void)
        DHT11_DQ=0;
        delay_ms(20);
        DHT11_DQ=1;
        delay_10us(4);
bit DHT11_Check(void)
        unsigned char retry=0;
        while(DHT11_DQ&&retry<100)
                retry++;
                delay_10us(1);
        if(retry>=100)return 1;
        else retry=0;
        while(!DHT11_DQ&&retry<100)
                retry++;
                delay_10us(1);
                 return 0;
bit DHT11_Init(void)
        DHT11_Rst() ;
        return DHT11_Check();
static unsigned char DHT11_Read_Byte(void)
        unsigned char retry, dat = 0, i;
        status = OK;
        for(i = 8; i > 0; i--)
                dat <<= 1;
                retry = 0;
                whileT11_DQ == 0 && retry++ < NUMBER);
                if(retry >= NUMBER)
                        status = ERROR;
                        return 0;
                delay_10us(2);
                if(DHT11_DQ != 0)
                        dat++;
                        while(DHT11_DQ != 0 && retry++ < NUMBER)
                                DHT11_DQ = 1;
                        if(retry >= NUMBER)
                                status = ERROR;
                                return 0;
        return (dat);
bit DHT11_Read_Date(unsigned char *temp,unsigned char *humi)
        unsigned char i = 0,retry = 0;
        unsigned char buf[SIZE];
        DHT11_DQ = 0;
        delay_ms(30);
        DHT11_DQ = 1;
        delay_10us(3);
        if(DHT11_DQ != 0)
                //??ó|′eD?o?
                return ERROR;
                while(DHT11_DQ == 0 && retry++ < NUMBER);
                if(retry >= NUMBER)
                        DHT11_DQ = 1;
                        return ERROR;
                retry = 0;
                DHT11_DQ = 1;
                while(DHT11_DQ != 0 && retry++ < NUMBER);
                if(retry >= NUMBER)
                        DHT11_DQ = 1;
                        return ERROR;
            for(i = 0; i < SIZE; i++)
                        buf[ i] = DHT11_Read_Byte();
                        if(status == ERROR)
                                DHT11_DQ = 1;
                                return ERROR;
                if((buf[0]+buf[1]+buf[2]+buf[3])==buf[4])
                        *humi = buf[0];
                        *temp = buf[2];
                        DHT11_DQ = 1;
                        return OK;
                        return ERROR;
主函数
        unsigned char temperature;
        unsigned char humidity;
        Time0_Time1_init();
        lcd1602_init();
        led= 1;
        delay_ms(1000);
        L1602_string(1,1,"WD:");
        L1602_string(1,8,"SD:");
        L1602_string(1,6,"C");
        L1602_string(1,13,"%");
        L1602_string(2,3,":");
        L1602_string(2,6,":");
        L1602_string(2,12,":");
                DHT11_Read_Date(&temperature,&humidity);
                delay_ms(50);
                L1602_int(1,4,temperature);
                L1602_int(1,11,humidity);
                if(key1==0
                        buf++;
                        if(buf>1) buf=0;
                if(buf==0
                        L1602_string(1,15,"SD");
                        if(key2==0) led=~led;
                        if(key3==0) q1=~q1;
                        if(key4==0) q2=~q2;
                        if(temperature>40) q2=1;
                if(buf==1
                        L1602_string(1,15,"ZD");
                        if(key4==0) miao++;
                        if(key5==0) fen++;
                        if(key6==0) shi++;
                        if(key3==0) shi1++;  if(shi1>23) shi1=0;
                        if(key2==0) fen1++;  if(fen1>59) fen1=0;
                        if((shi==shi1)&(fen==fen1)
                                if(humidity>70) led=q1=q2=0;
                        if(temperature>40|humidity<35
                        led=q1=q2=1;
                L1602_int(2,1,shi);
                L1602_int(2,4,fen);
                L1602_int(2,7,miao);
                L1602_int(2,10,shi1);
                L1602_int(2,13,fen1);
                delay_ms(150);
void Timer0() interrupt 1
   TH0=(65536-50000)/256;
   TL0=(65536-50000)%256;
   count++;
   if(count==20
    count=0
                miao++;
                if(miao>59)
                        miao=0;
                        fen++;
                if(fen>59)
                        fen=0;
                        shi++;
                if(shi>23) shi=0;
