查看: 3433|回复: 11
keil中标红的显示错误error C216: subscript on non-array or too many dimensions
是为啥呀
#include "lcd1602.h"
#include "TLC2543.h"
#include "math.h"
sbit MD1=P1^6;
sbit MD2=P1^7;
sbit RED_LED=P3^6;
sbit GREEN_LED=P3^7;
bit fflag;
unsigned char fcnt;
float ACRead_f;
unsigned int ACRead;
unsigned char ACRMS[4]={0,0,0,0};
unsigned char i;
unsigned int maxa,mina,max,min;
unsigned char keyval;
unsigned char mode;
unsigned char index;
#define KEYMODE 0X01;
#define KEYSHIFT 0X02;
#define KEYMINUS 0X04;
#define KEYPLUS 0X08;
void panduan()
        if(ACRead>maxa)
                GREEN_LED=1;
                TR0=1;
                fcnt=100;
                MD1=1;
                MD2=0;
        else if(ACRead<mina)
                GREEN_LED=1;
                TR0=1;
                fcnt=25;
                MD1=0;
                MD2=1;
                RED_LED=1;
                GREEN_LED=0;
                TR0=0;
                MD1=1;
                MD2=1;
unsigned char key_scan()
        unsigned char temp;
        temp=P2|0xf0;
        if(temp==0xff) return 0;
        //delay1ms(10);
        temp=~(P2|0xf0);
        while((P2|0xf0)!=0xff);
        return temp;
        TMOD=0X01;
        TH0=(0-10000)/256;
        TL0=(0-10000)%256;
        ET0=1;
        EA=1;
        TR0=0;
        LcdInit();
        LcdWriteCom(0x80);LcdWriteData('A');LcdWriteData('C');
        max=188;
        min=170;
        maxa[0]=8;maxa[1]=8;maxa[2]=1;
        mina[0]=0;mina[1]=7;mina[2]=1;
                        keyval=key_scan();
                        if(mode==1)
                                if(keyval==KEYMODE) {mode=2;index=0;}
                                else if(keyval==KEYSHIFT)
                                if(++index>2) index=0;
                                if(index==0) LcdWriteCom(0x86);
                                else if(index==1) LcdWriteCom(0x85);
                                else if(index==2) LcdWriteCom(0x84);
                                LcdWriteCom(0x0e);
                                else if(keyval==KEYPLUS)
                                if(++maxa[index]>9) maxa[index]=0;
                                max=maxa[2]*100+maxa[1]*10+maxa[0];
                                LcdWriteCom(0x84);
                                LcdwriteData(maxa[2]+0x30);
                                LcdwriteData(maxa[1]+0x30);
                                LcdwriteData(maxa[0]+0x30);
                                eles if(keyval==KEYMINUS)
                                if(maxa[index]==0 maxa[index]=9;
                                else maxa[index]--;
                                LcdWriteCom(0x84);
                        else if(mode==2)
                        if(keyval==KEYMODE) {mode=0;LcdWriteData(0x0c);}
                                LcdWriteCom(0x0e);
                                if(++mina[index]>9 mina[index]=0;
                                min=mina[2]*100+mina[1]*10+mina[0];
                                LcdWriteCom(0x84);
                                LcdwriteData(mina[2]+0x30);
                                LcdwriteData(mina[1]+0x30);
                                LcdwriteData(mina[0]+0x30);
                                else if(keyval==KEYMINUS)
                                if(mina[index]==0) mina[index]=9;
                                else mina[indax]--;
                                if(++maxa[index]>9 maxa[index]=0;
                                LcdWriteCom(0x84);
                        else//???è?à2a?£ê?
                                if(keyval==KEYMODE)//?£ê??ü
                                        mode=1;
                                        index=0;
                                        //éè????1a±ê
                                        LcdWriteCom(0x84);
                                        LcdWriteCom(0x0e);
                                        ACRead_f=read_DC_TLC2543(0x0);
                                        ACRead_f=ACRead_f*5.0/4095.0*3.1415926535/2.0/sqrt(2)*100.0*51;
                                        ACRead=ACRead_f;
                                        panduan();
                                        ACRMS[5]=ACRead%10;
                                        ACRMS[4]=ACRead/10%10;
                                        ACRMS[3]='.'-'0';
                                        ACRMS[2]=ACRead/100%10;
                                        ACRMS[1]=ACRead/1000%10;
                                        ACRMS[0]=ACRead/10000%10;
                                        LcdWriteCom(0xc0);
                                        for(i=0;i<6;i++)
                                        {LcdWriteData('0'+ACRMS[ i]);}
void t0int(void) interrupt 1
        static i;
        TH0=(0-10000)/256;
        TL0=(0-10000)%256;
        i++;
        if(i>fcnt)
                i=0;RED_LED=!RED_LED;
ID:161164 发表于 2023-5-7 10:08 | 只看该作者
maxa,mina不是数组
ID:1075785 发表于 2023-5-7 10:39 | 只看该作者
lkc8210 发表于 2023-5-7 10:08
maxa,mina不是数组
请问怎么修改呀,不太懂
ID:639106 发表于 2023-5-7 13:59 | 只看该作者
maxa[10],mina[10]
ID:908826 发表于 2023-5-7 15:10 | 只看该作者
一个菜菜菜菜鸟 发表于 2023-5-7 10:39
请问怎么修改呀,不太懂
在你贴出的源代码中,就没看见你定义的数组
ID:161164 发表于 2023-5-7 16:16 | 只看该作者
请问怎么修改呀,不太懂
unsigned int maxa[3],mina[3],max,min;
ID:1073299 发表于 2023-5-7 20:23 | 只看该作者
还是需要先把C语言的基础知识搞定才行喔
ID:1075785 发表于 2023-5-7 22:03 | 只看该作者
谢谢大家的回复,这个错误没了,但剩下的错误还是不会修改
ID:1075785 发表于 2023-5-7 22:07 | 只看该作者
谢谢大家的回复,学到了
ID:415064 发表于 2023-5-8 08:34 | 只看该作者
#define KEYSHIFT 0X02;   去掉后面的; 语法错误   其他几个宏同理
ID:415064 发表于 2023-5-8 08:35 | 只看该作者
ACRead 是unsigned int        maxa是数组、       类型都不一样,怎么比较
ID:206581 发表于 2023-5-8 09:23 | 只看该作者
再学学C语言的语法知识
