查看: 2576|回复: 2
妹纸求教1602问题
ID:56673 发表于 2013-11-6 14:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问一下大神们  我用1602写了一个时钟 都正常运行了  后来想加一个一开始从右向左移动的滚动进入的程序   结果滚动显示后时钟就运行不起来了怎么回事啊……求解
#include<reg52.h>
sbit lcdrs=P1^0;
sbit lcdrw=P1^1;
sbit lcden=P2^5;
sbit dula=P2^6;
sbit wela=P2^7;
sbit K1=P3^4;
sbit K2=P3^5;
sbit K3=P3^6;
uchar code table[]="    now is";
uchar code table1[]="   00:00:00" ;
uchar aa,shi,fen,miao,shiw,gew;
void write_sfm(uchar wei,uchar shu);
void delay(uint z)
uint x;
uchar y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_con(uchar com)
lcdrw=0;
    lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar dat)
  lcdrw=0;
lcdrs=1;
P0=dat;
delay(5);
lcden=1;
delay(5);
lcden=0;
void keyscan()
uchar key;
if(K1==0)
   delay(50);
   if(K1==0)
    while(!K1);
    key++;
    if(key==1)
      TR0=0;
      write_con(0x0f);
      write_con(0x80+0x40+10) ;
    if(key==2)
      write_con(0x80+0x40+7);
    if(key==3)
      write_con(0x80+0x40+4);
    if(key==4)
      key=0;
      write_con(0x0c);
      TR0=1;
  if(key!=0)
   if(K2==0)
     delay(50);
     if(K2==0)
          while(!K2);
       if(key==1)
         miao++;
         if(miao==60)  miao=0;
         write_sfm(9,miao);
         write_con(0x80+0x40+10);
       if(key==2)
         fen++;
         if(fen==60)  fen=0;
         write_sfm(6,fen);
       if(key==3)
         shi++;
         if(shi==24)  shi=0;
         write_sfm(3,shi);
   if(K3==0)
     delay(50);
     if(K3==0)
       while(!K3);
       if(key==1)
         miao--;
         if(miao==-1)  miao=0;
         write_sfm(9,miao);
       if(key==2)
         fen--;
         if(fen==-1)  fen=0;
         write_sfm(6,fen);
       if(key==3)
         shi--;
         if(shi==-1)  shi=0;
         write_sfm(3,shi);
void init()
{ uchar i;
dula=0;
wela=0;
write_con(0x38);   //4位总线  双行显示 5*7点阵
write_con(0x0f);   //显示开  无光标 无闪烁
write_con(0x06);   // 光标右移  字符不移动
write_con(0x01); //清屏
write_con(0x80+17);   //将数据写到隐藏地方
for(i=0;i<10;i++)
   write_data(table[i]);
   delay(5);
    write_con(0x80+0x40+17);   //第二行数据
delay(50);
for(i=0;i<11;i++)
   write_data(table1[i]);
   delay(50);
for(i=0;i<16;i++)
  write_con(0x18);
  delay(500);
TMOD=0x01;
TH0=(65535-50000)/256;
    TL0=(65535-50000)%256;
TR0=1;
EA=1;
ET0=1;
void time_()   interrupt 1
aa++;
void write_sfm(uchar wei,uchar shu)    //在wei 处写数据 shu
uchar shiw,gew;
write_con(0x80+0x40+wei);
shiw=shu/10;
gew=shu%10;
write_data(0x30+shiw);
    write_data(0x30+gew);
main()
{  init();
   keyscan();
   if(aa==20)
    aa=0;
    miao++;
    if(miao==60)
      miao=0;
      fen++;
      if(fen==60)
        fen=0;
        shi++;
        if(shi==24)
          shi=0;
        write_sfm(3,shi);
      write_sfm(6,fen);
    write_sfm(9,miao);
ID:1 发表于 2013-11-23 19:57 | 只看该作者
现在运行是什么情况?
ID:153199 发表于 2016-12-24 09:24 | 只看该作者
你好你的问题解决了吗,求分享
