查看: 2514|回复: 0
gcvt函数源码 如果ccs的stdlib库函数中没有,可以看过来
ID:996033 发表于 2023-5-25 16:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#define PSH(X) (*(buf++)=(X))
#define PSH1(X) (*(buf--)=(X))
#define PEEK() buf[-1]
#define POP() *(--buf) = '\0'
#define PLUS 1
#define SPACE 2
char *gcvt(float f, uint16_t ndigit, char *buf)
     int i;
     uint32_t z,k;
     //int exp = 0;
     char *c = buf;
     float f2,t,scal;
     int   sign = 0;
     if((int)ndigit == -1)
       ndigit = 5;
     /* Unsigned long long only allows for 20 digits of precision
      * which is already more than double supports, so we limit the
      * digits to this.  long double might require an increase if it is ever
      * implemented.
     if (ndigit > 20)
         ndigit = 20;
     if (f < 0.0) {
       sign = 1;
       f = -f;
        buf++;
     scal = 1;
     for (i=ndigit; i>0; i--)
         scal *= 10;
     k = f + 0.1 / scal;
     f2 = f - k;
     if (!f) {
       PSH('0');
       if(ndigit > 0)
         PSH('.');
       for (i=0;i<ndigit;i++)
         PSH('0');
          PSH(0);
        return c;
     i = 1;
     while (f >= 10.0) {
       f /= 10.0;
       i++;
     buf += i + ndigit + 1;
     PSH1(0);
     if(ndigit > 0) {
         t = f2 * scal;
        z = t + 0.5;
       for (i = 0;i < ndigit;i++)
         PSH1('0'+ (z % 10));
          z /= 10;
       PSH1('.');
       PSH1(0);
     do {
       PSH1('0'+ (k % 10));
       k /= 10;
     }while (k);
     if (sign)
       PSH1('-');
     return c;
