查看: 2370|回复: 4
大唐AP R2000如何进入配置模式
回帖奖励 20 黑币 回复本帖可获得 20 黑币奖励! 每人限 1 次
家里光猫无线信号不好,就想着假期整个AP用用。设备淘回来试着登录192.168.100.100等管理IP地址,结果发现死活没反应。通过RS232口读取系统信息如下:
这是通过RS232读取出来的信息,没有找到登录IP地址。大家帮忙瞅瞅谢谢。
BootROM version 1.0.20 Build 291 (Release build) (Build time: Jul 16 2010 - 11:29:27)
Serial Buad Rate :115200
OCTEON CN5010-SCP pass 1.1, Core clock: 400 MHz, DDR clock: 200 MHz (400 Mhz data rate)
DRAM:  128 MB
Memory selftest
        Testing the data lines....................OK
        Testing the address lines.....................Ok
Flash: 16.5 MB
Clearing DRAM...... done
BIST check passed.
Starting PCI
PCI Status: PCI 32-bit
GPIO State:0x0000000000000F0F
MAC Address :  00:14:D5:FE:45:84
***SMI***
Check for Switch Chip.
Net:   octeth0, octeth1, octeth2
the ds1672 is  stopping! Now reset it.
twsii write (2byte) failed
USB:   Init: Power Port (0)
no usb device detected !
Press ENTER to enter BOOT MENU; Press SPACE to enter command line; Don't press any key to autoboot:  0
** Unable to use  **
## Booting image at 10040000 ...
Image header version: 0x1
   Image Name:   AP-OS
   Created:      2012-04-06   8:30:50 UTC
   Image Type:   MIPS Linux Kernel Image (gzip compressed)
   Data Size:    14227183 Bytes = 13.6 MB
   Load Address: 06000000
   Entry Point:  06000000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ...OK
Starting kernel ...
argv[2]: ethspd=1000
argv[3]: productplatform=apv14
ELF file is 64 bit
Attempting to allocate memory for ELF segment: addr: 0xffffffff80100000 (adjusted to: 0x0000000000100000), size 0x10a3b1f
Allocated memory for ELF segment: addr: 0xffffffff80100000, size 0x10a3b1f
Loading .text @ 0xffffffff80100000 (0x321168 bytes)
Loading __ex_table @ 0xffffffff80421170 (0x2f90 bytes)
Loading .rodata @ 0xffffffff80425000 (0x8eea4 bytes)
Loading .pci_fixup @ 0xffffffff804b3ea8 (0xb20 bytes)
Loading __ksymtab @ 0xffffffff804b49c8 (0x9140 bytes)
Loading __ksymtab_gpl @ 0xffffffff804bdb08 (0x22c0 bytes)
Loading __ksymtab_gpl_future @ 0xffffffff804bfdc8 (0x30 bytes)
Loading __ksymtab_strings @ 0xffffffff804bfdf8 (0xe8f8 bytes)
Loading __param @ 0xffffffff804ce6f0 (0x1400 bytes)
Loading .data @ 0xffffffff804d0000 (0x2ed40 bytes)
Loading .data.cacheline_aligned @ 0xffffffff804ff000 (0x7280 bytes)
Loading .init.text @ 0xffffffff80507000 (0x2e5a8 bytes)
Loading .init.data @ 0xffffffff805355a8 (0x5298 bytes)
Loading .init.setup @ 0xffffffff8053a840 (0x618 bytes)
Loading .initcall.init @ 0xffffffff8053ae58 (0x548 bytes)
Loading .con_initcall.init @ 0xffffffff8053b3a0 (0x18 bytes)
Loading .exit.text @ 0xffffffff8053b3b8 (0x1f10 bytes)
Loading .init.ramfs @ 0xffffffff8053e000 (0xc03f31 bytes)
Clearing .bss @ 0xffffffff81142000 (0x30ba0 bytes)
Clearing .cvmx_shared_bss @ 0xffffffff81172ba0 (0x310 bytes)
## Loading Linux kernel with entry point: 0x80507000 ...
Bootloader: Done loading app on coremask: 0x1
Linux version 2.6.21.7-Cavium-Octeon (shark@shark-linux) (gcc version 4.1.2 (Cavium Networks Version: 1_7_3, build 58)) #388 Fri Apr 6 16:30:41 CST 2012
CVMSEG size: 2 cache lines (256 bytes)
CPU revision is: 000d0601
Init gateway product power off feature
Determined physical RAM map:
memory: 0000000006c00000 @ 0000000001200000 (usable)
Wasting 258048 bytes for tracking 4608 unused pages
Initrd not found or empty - disabling initrd
Built 1 zonelists.  Total pages: 31815
Kernel command line:  bootm 0x10040000 ethspd=1000 productplatform=apv14 console=ttyS0,115200
Primary instruction cache 32kB, virtually tagged, 4 way, 64 sets, linesize 128 bytes.
Primary data cache 16kB, 64-way, 2 sets, linesize 128 bytes.
Synthesized TLB refill handler (49 instructions).
Synthesized TLB load handler fastpath (64 instructions).
Synthesized TLB store handler fastpath (67 instructions).
Synthesized TLB modify handler fastpath (64 instructions).
PID hash table entries: 512 (order: 9, 4096 bytes)
Using 400.000 MHz high precision timer.
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Inode-cache hash table entries: 8192 (order: 4, 65536 bytes)
Memory: 108544k/110592k available (3204k kernel code, 2000k reserved, 916k data, 12524k init, 0k highmem)
Calibrating delay using timer specific routine.. 800.33 BogoMIPS (lpj=1600670)
Mount-cache hash table entries: 256
Checking for the multiply/shift bug... no.
Checking for the daddi bug... no.
Checking for the daddiu bug... no.
NET: Registered protocol family 16
Enabling Octeon big bar support
PCI Clock: 33 MHz
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
slot:1,pin:1,interruptsACABAAAAAAAAAAAAAAAAAAAAAAAAAAAA,dev_num:1
slot:2,pin:1,interruptsACABAAAAAAAAAAAAAAAAAAAAAAAAAAAA,dev_num:2
NET: Registered protocol family 2
Time: MIPS clocksource has been installed.
IP route cache hash table entries: 1024 (order: 1, 8192 bytes)
TCP established hash table entries: 4096 (order: 4, 65536 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
/proc/octeon_perf: Octeon performace counter interface loaded
Octeon watchdog driver loaded with a timeout of 10737 ms.
Total HugeTLB memory allocated, 0
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler cfq registered (default)
[drm] Initialized drm 1.1.0 20060810
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
loop: loaded (max 8 devices)
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Fusion MPT base driver 3.04.04
Copyright (c) 1999-2007 LSI Logic Corporation
Fusion MPT SAS Host driver 3.04.04
slram: not enough parameters.
usbmon: debugfs is not available
dwc_otg: version 2.40a 10-APR-2006
DWC_otg: Using DMA mode
dwc_otg dwc_otg.0: DWC OTG Controller
dwc_otg dwc_otg.0: new USB bus registered, assigned bus number 1
dwc_otg dwc_otg.0: irq 64, io mem 0x00000000
DWC_otg: Init: Port Power? op_state=1
DWC_otg: Init: Power Port (0)
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for airprime
usbcore: registered new interface driver airprime
drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.1
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
TCP cubic registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
serial8250: ttyS0 at MMIO 0x1180000000800 (irq = 42) is a 16550A
Bootbus flash: Setting flash for 16MB flash at 0x1d000000
productplatform:apv14, gateway:0 ,ap:1
cfi->mfr:0x1,cfi->id0x7e
phys_mapped_flash: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
phys_mapped_flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Creating 7 MTD partitions on "phys_mapped_flash":
0x00000000-0x00020000 : "partiontable"
0x00020000-0x00040000 : "message"
0x00040000-0x00e40000 : "kernel1"
0x00040000-0x00e40000 : "kernel2"
0x00040000-0x00e40000 : "bigkernel"
0x00e40000-0x00f00000 : "reserved"
0x00f00000-0x01000000 : "config"
Freeing unused kernel memory: 12524k freed
init started:  BusyBox v1.4.2 (2012-04-05 18:26:47 CST) multi-call binary
mount: mounting none on /mnth failed
Device version is the newest.
AP
bm:register major dev [236] with debug_ioctl[0]
bm:loaded successfully.
AQ2000-E2AN2
ath_hal: module license 'Proprietary' taints kernel.
ath_hal: 0.9.17.1 (AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2316, RF2317, DEBUG, REGOPS_FUNC, WRITE_EEPROM, 11D)
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
wlan: 0.8.4.2 (Atheros/multi-bss)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_pci: 0.9.4.5 (Atheros/multi-bss)
PCI: Enabling device 0000:00:01.0 (0000 -> 0002)
dfs_init_radar_filters: Unknown dfs domain 0
wifi0: Atheros 9280: mem=0x11b00f0000000, irq=46 hw_base=0x90011b00f0000000
PCI: Enabling device 0000:00:02.0 (0000 -> 0002)
wifi1: Atheros 9280: mem=0x11b00f0010000, irq=44 hw_base=0x90011b00f0010000
wlan: mac acl policy registered
wlan_me: Version 0.1
Copyright (c) 2008 Atheros Communications, Inc. All Rights Reserved
wlan_sms4: Version 1.0.1
Copyright (c) 2001-2007 IWNCOMM Communications, Inc, All Rights Reserved
cavium-ethernet: Cavium Networks Octeon SDK version 1.7.3, build 264
Interface 0 has 1 ports (RGMII)
phy_id:1
priv-val:300
device eth0 entered promiscuous mode
interface eth1 does not exist!
default: port 1(eth0) entering learning state
socket: Address family not supported by protocol
/sbin/mini_httpd: started as root without requesting chroot(), warning only
+Avrmod_init
Cavium_V1
gpio init is ok
default: topology change detected, propagating
default: port 1(eth0) entering forwarding state
hostapd config dir ok
killall: udhcpc: no process killed
dev.wifi0.thinap = 0
crond[1395]: crond 2.3.2 dillon, started, log level 8
crond[1398]: crond 2.3.2 dillon, started, log level 8
11n
ioctl[IEEE80211_IOCTL_SETCHANLIST]: Invalid argument
device ath0 entered promiscuous mode
default: port 2(ath0) entering learning state
11n
default: port 2(ath0) entering forwarding state
Country ie is CN
/sbin/mini_httpd: exiting due to signal 15
sysctl: error: 'dev.wifi0.load_balancing' is an unknown key
sysctl: error: 'dev.wifi0.balance_threshold' is an unknown key
iptables v1.4.0: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
bind: Address already in use
/sbin/mini_httpd: can't bind to any address
    Company Name:DATANG TELECOM TECHNOLOGY CO.,LTD
              SN:01010185E14411500730
         Ap Mode:fatap
     Device Type:R2000 AP-IN(D)
        BASE MAC:0014D5FE4584
Software Version:V5.0.1.0
Hardware Version:1.2.0
system check:
mount check ok !
wireless device check ok, device count: 2!
Please press Enter to activate this console.
ID:447439 发表于 2023-10-11 10:52 | 只看该作者
通过搜索局域网IP设备,已获取到管理IP已经进去WEB界面。
ID:301191 发表于 2023-10-11 15:05 | 只看该作者
顶一下
ID:136013 发表于 2023-10-11 16:23 | 只看该作者
还有一个,很久没玩了。
ID:447439 发表于 2023-10-12 15:50 | 只看该作者
samsung9454 发表于 2023-10-11 16:23
还有一个,很久没玩了。
改胖模式吧,虽然有点年代感但是在家使用信号强度还是满满的。我的是两个网卡有个5.8G的网卡但是不知道怎么的只有2.4G的无线网。
