查看: 2483|回复: 6
51单片机c语言 这个中断里的循环老是进不去
ID:1094287 发表于 2023-10-6 12:41 来自触屏版 | 显示全部楼层 |阅读模式
大佬们,这个中断里的循环老是进不去是怎么回事啊
include <REGX52.H>
unsigned  char key=0;
unsigned int led[8]={
        0x9F,0x07,0x01,0x80,0x80,0x01,0x07,0x9F};
        sbit ADDR0=P1^0;
        sbit ADDR1=P1^1;
        sbit ADDR2=P1^2;
        sbit ADDR3=P1^3;
        sbit ADDR4=P1^4;
        sbit ADDR5=P1^5;
        sbit ADDR6=P1^6;
        sbit ADDR7=P1^7;
        ADDR3=1;
        ADDR4=0;
        TMOD=0x01;
        TH0=0xfc;
        TL0=0x66;
        EA=1;
        ET0=1;
        TR0=1;
void interruptTimer0() interrupt 1
        TH0=0xdb;
        P2=0xff;
        TL0=0Xff;
        switch(key)
                case0:ADDR0=0;ADDR1=0;ADDR2=0;key++;P2=led[0];break;
                case1:ADDR0=1;ADDR1=0;ADDR2=0;key++;P2=led[1];break;
                case2:ADDR0=0;ADDR1=1;ADDR2=0;key++;P2=led[2];break;
                case3:ADDR0=0;ADDR1=0;ADDR2=0;key++;P2=led[3];break;
                case4:ADDR0=1;ADDR1=1;ADDR2=0;key++;P2=led[4];break;
                case5:ADDR0=1;ADDR1=0;ADDR2=1;key++;P2=led[5];break;
                case6:ADDR0=0;ADDR1=1;ADDR2=1;key++;P2=led[6];break;
                case7:ADDR0=1;ADDR1=1;ADDR2=1;key++;P2=led[7];break;
                default: break;
ID:883242 发表于 2023-10-6 14:32 | 显示全部楼层
1)中断里面没有循环,2)key的值没有改变。
ID:1094287 发表于 2023-10-6 15:53 来自触屏版 | 显示全部楼层
对对对,这个说错了是选择进不去
ID:213173 发表于 2023-10-6 16:34 | 显示全部楼层
完成一轮扫描key没有清0。
  1. #include <REG51.H>
  2. unsigned  char key=0;
  3. unsigned char led[8]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07};
  4.
  5. sbit ADDR0=P1^0;
  6. sbit ADDR1=P1^1;
  7. sbit ADDR2=P1^2;
  8. sbit ADDR3=P1^3;
  9. sbit ADDR4=P1^4;
  10. sbit ADDR5=P1^5;
  11. sbit ADDR6=P1^6;
  12. sbit ADDR7=P1^7;
  13. void main()
  14. {
  15.         ADDR3=1;
  16.         ADDR4=0;
  17.         TMOD=0x01;
  18.         TH0=0xfc;
  19.         TL0=0x66;
  20.         EA=1;
  21.         ET0=1;
  22.         TR0=1;
  23.         while(1)
  24.         {
  25.         }
  26. }
  27. void interruptTimer0() interrupt 1
  28. {
  29.         TH0=0xfc;
  30.         TL0=0x66;
  31.         P2=0x00;
  32.         switch(key)
  33.         {
  34.                 case 0:ADDR0=0;ADDR1=0;ADDR2=0;key++;P2=led[0];break;
  35.                 case 1:ADDR0=1;ADDR1=0;ADDR2=0;key++;P2=led[1];break;
  36.                 case 2:ADDR0=0;ADDR1=1;ADDR2=0;key++;P2=led[2];break;
  37.                 case 3:ADDR0=1;ADDR1=1;ADDR2=0;key++;P2=led[3];break;
  38.                 case 4:ADDR0=0;ADDR1=0;ADDR2=1;key++;P2=led[4];break;
  39.                 case 5:ADDR0=1;ADDR1=0;ADDR2=1;key++;P2=led[5];break;
  40.                 case 6:ADDR0=0;ADDR1=1;ADDR2=1;key++;P2=led[6];break;
  41.                 case 7:ADDR0=1;ADDR1=1;ADDR2=1;key=0;P2=led[7];break;
  42.                 default: break;
  43.         }
  44. }
ID:108361 发表于 2023-10-26 19:02 | 显示全部楼层
case7里key不能++,要key=0,不然就只扫一遍然后key=8了,这辈子就不会进了,这也是stc的51不能仿真的悲哀
ID:883242 发表于 2023-10-26 19:18 | 显示全部楼层
如果我写会把key++放switch后面,8种条件都有key++写到8种条件里面太foolish,把switch(key)改成switch(key&7)就行了。
ID:1097455 发表于 2023-10-27 08:56 | 显示全部楼层
key值加完清0  default: key=0;break;
