查看: 2885|回复: 8
error C141: syntax error near 'int', expected ')'我找不到这个问题,怎么解决呀
ID:1095516 发表于 2023-10-9 19:40 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<intrins.h>
#define uint unsigened int
#define out P2
sbit RS=P3^0;
sbit RW=P3^1;
sbit E=P3^2;
void lcd_initial(void);
void check_busy(void);
void write_command(uchar com);
void write_data(uchar dat);
void string(uchar ad,uchar*s);
void delay (uint);        //LCD1602.C(14): error C141: syntax error near 'int', expected ')'
void main(void)
    lcd_initial();
           string(0x85,"Welcome To");
           string(0xc2,"Harbin Institute");
           Delay(100);
           write_command(0x01);
           Delay(100);
        void Delay(uint j)
           uchar i=250;
           for(;j>0;j--)
              while(--i);
                  i=249;
                  while(--i);
                  i=250;
                uchar dt;
                do
                   dt=0xff;
                   E=0;
                   RS=0;
                   RW=1;
                   E=1;
                   dt=out;
                }while(dt&0x80);
                        E=0;
                   check_busy();
                   E=0;
                   RS=0;
                   RW=0;
                   out=com;
               E=1;
               _nop_();
                   E=0;
                   delay(1);
                   check_busy();
                   E=0;
                   RS=1;
                   RW=0;
                   out=dat;
               E=1;
               _nop_();
                   E=0;
                   delay(1);
            write_command(0x38);
                write_command(0x0c);
                write_command(0x06);
                delay(1);
      write_command(ad);
          while(*s>0)
             write_data(*s++);
                 delay(100);
ID:883242 发表于 2023-10-9 20:53 | 显示全部楼层
#define uint unsigened int 这句话错了,具体怎么错了,瞪大眼睛仔细看。
ID:342822 发表于 2023-10-9 21:28 | 显示全部楼层
delay  Delay 要统一
ID:227393 发表于 2023-10-9 22:27 来自触屏版 | 显示全部楼层
def i ne  不是deflne
ID:213173 发表于 2023-10-10 05:45 | 显示全部楼层
#define uint unsigened int 多了个e
delay  Delay  大小写要统一
ID:829223 发表于 2023-10-10 09:00 | 显示全部楼层
#define uint unsigened int 这两个对比看看
ID:879348 发表于 2023-10-10 10:35 | 显示全部楼层
新手常犯毛病
ID:1095554 发表于 2023-10-10 10:49 | 显示全部楼层
把#define uint unsigened int声明修改成#define uint unsigned int即可
ID:1095554 发表于 2023-10-10 10:50 | 显示全部楼层
把#define uint unsigened int修改成#define uint unsigned int即可解决问题
