查看: 1959|回复: 4
单片机程序 怎么把倒计时变成正计时?
ID:1096516 发表于 2023-10-22 13:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
char code tabledp[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef,0xf7,0xfc,0xb9,0xde,0xf9,0xf1};
unsigned char num[2];
char miao=0;
sbit key1=P3^5;
sbit key2=P3^6;
sbit key3=P3^7;
sbit beep=P1^4;
sbit w1=P1^0;
sbit w2=P1^1;
char menu=0;
char flag=0;
void delay(unsigned int z)
        unsigned int i,j;
        for(i=0;i<z;i++)
        for(j=0;j<621;j++);
void TimerInit()
        TMOD = 0x11;
        TH0 = (65536-50000)/256;
        TL0 = (65536-50000)%256;;
        ET0  = 1;
        TR0         = 1;
        TH1 = (65536-50000)/256;
        TL1 = (65536-50000)%256;;
        ET1 = 1;
        TR1 = 0;
        EA   = 1;
void display()
        num[0]=miao%10;
        num[1]=miao/10;
        if(menu==1)
                if(flag==0)
                        num[0]=10;
                        num[1]=10;
        w1=1;
        w2=0;
        P2=table[num[0]];
        delay(1);
        w1=w2=1;
        w1=0;
        w2=1;
        P2=table[num[1]];
        delay(1);
        w1=w2=1;
void key()
        if(key1==0)
                while(key1==0);
                menu++;
                if(menu==1){TR0=1;TR1=0;}
                if(menu==2){TR0=0;menu=0;}
        if(menu==1)
                if(key2==0)
                        while(key2==0);
                        miao++;
                        if(miao>99)miao=99;
                if(key3==0)
                        while(key3==0);
                        miao--;
                        if(miao<0)miao=0;
        TimerInit();
        P0=0X55;
                key();
                display();
                if(menu==0)
                        if(key2==0)
                                while(key2==0);
                                if(miao>0)
                                        TR1=1;
                        if(key3==0)
                                while(key3==0);
                                TR1=0;
char jishu;
void Timer0(void) interrupt 1
        jishu++;
        if(jishu==10)
                jishu=0;
                flag++;
                if(flag==2)flag=0;
char value;
void time1_int() interrupt 3
        value++;
        if(value ==20)
                value =0;
                if(miao>0)miao--;
                if(miao==0)
                        TR1=0;miao=0;
                if(miao<10)beep=0;
                else beep=1;
ID:883242 发表于 2023-10-22 18:00 | 只看该作者
把miao--;改成miao++;
ID:584814 发表于 2023-10-23 09:27 | 只看该作者
改初始化值,变加为减就可以。
ID:1083996 发表于 2023-10-23 09:58 | 只看该作者
那一个时钟,时:分:秒这种,把秒弄成60秒倒计时,时:分,正常显示,这样效果是不是就能感觉生命正在流失的紧张感了
ID:1097455 发表于 2023-10-27 10:47 | 只看该作者
value++;
        if(value ==20)
                value =0;
                if(miao>0)miao;
                if(miao>=60)
                        TR1=0;miao=0;
                if(miao<10)beep=0;
                else beep=1;
