查看: 1548|回复: 0
单片机四路抢答器程序
ID:1107662 发表于 2024-1-3 12:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
简单四路抢答
源代码
#include <reg52.h>
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit key4=P3^3;
sbit key5=P3^7;
sbit BEEP=P2^0;
bit flag;
unsigned char temp;
unsigned char pulse_number1=9;
unsigned char code TAB[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay_100ms(unsigned int t)
  unsigned char i,j,k;
  for(i=t;i>0;i--)
  for(j=200;j>0;j--);
  for(k=248;k>0;k--);
void beep()
BEEP=1;
delay_100ms(100);
BEEP=0;
void T0_int() interrupt 1
  static unsigned char count;
  unsigned char a=1;
  count++;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  if(count==20)
   count=0;
    P0=TAB[pulse_number1--];
    beep();
  if(pulse_number1==0)
     P0=TAB[0];
     TR0=0;
     while(a)
      beep();
      if(!key5)a=0;
  temp=0x00;
  P2=temp;
  P0=0x3f;
  TMOD=0x01;
  ET0=1;
  EA=1;
  TR0=1;
while(!flag)
    if(!key1){P0=0x06;beep();flag=1;TR0=0;}
  else if(!key2){P0=0x5b;beep();flag=1;TR0=0;}
  else if(!key3){P0=0X4f;beep();flag=1;TR0=0;}
  else if(!key4){P0=0x66;beep();flag=1;TR0=0;}
while(flag);
