查看: 2557|回复: 1
编译错误error C141: syntax error near '=', expected '__asm'
ID:1109192 发表于 2024-3-10 11:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有没有大佬帮忙看一下怎么解决
#include <reg52.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
sbit KEY_OPEN = P3^3; //引脚定义
sbit KEY_CLOSE = P3^5;
sbit LED_GREEN = P2^1;
sbit LED_RED = P2^2;
sbit BUZZER = P2^0;
#define BUZZER_ON (BUZZER = 0)
#define BUZZER_OFF (BUZZER = 1)
sbit SHAKE_PIN = P1^1; //震动传感器
sbit HC_SR501 = P1^0; //人体活动传感器
sbit RELAY_LOCK = P2^3; //电磁锁
bit g_irFlag = 0; //红外接收标志,收到一帧正确数据后置1
unsigned char g_irCode[4];
unsigned char refreshFlag = 0; //更新显示标志
unsigned char setFlag = 0; //设置参数标志
bit lockFlag = 1; //锁的状态标志
bit monitorFlag = 0; //监控标志
bit alarmFlag = 0; //报警标志
unsigned char time500msCnt = 0;
unsigned char time500msCnt2 = 0;
bit oldPinState = 0;
bit nowPinState = 0;
char dis0[16]; //定义显示区域临时存储数组
void CheckKey(void);
void CheckBluetooth(void);
void Timer1_Init(void); //定时器初始化
void main(void)
    IR_INPUT = 1;      110.c(49): error C141: syntax error near '=', expected 'hdata'   ,110.c(49): error C141: syntax error near '=', expected '__asm'
    Timer1_Init();
    IR_Init();
    Uart_Init();
    LCD_Init();   //初始化液晶
    DelayMs(200); //延时有助于稳定
    LCD_Clear();  //清屏
    LCD_DispStr(0, 0, "    Welcome!    ");
    DelayS(1);
    LCD_DispStr(0, 0, "   Waiting...   ");
    DelayS(5);
    err_num = GSM_Init(); //GSM初始化
    DelayMs(10);
    if (gsm_init_flag) //初始化完成
        err_num = GSM_Text_Mode(); //GSM 设置Text模式
    DelayMs(10);
    if (gsm_config_flag)
        err_num = GSM_Delete_Sms("1"); //删除短信1
    DelayMs(10);
    if (!(gsm_init_flag || gsm_config_flag || gsm_delete_flag)) // AT命令报错
        BUZZER_ON;
        LCD_DispStr(0, 0, " Init Err Num  ");
        LCD_WriteData((int)err_num+'0');
        DelayS(1);
        BUZZER_OFF;
        LCD_DispStr(0, 0, "    Init OK!    ");
    DelayS(3);
    EEPROM52_Init(); //初始化电话号码
    LCD_DispStr(0, 0, "     Status     ");
    while (1) //主循环
        gsm_receive_process(); //gsm接收处理
        if (lockFlag == 1) //已上锁
            LED_RED = 0;
            LED_GREEN = 1;
            RELAY_LOCK = 1; //关闭锁
            if (alarmFlag == 0)
                if (HC_SR501 == 0 && SHAKE_PIN == 0) //有人且震动
                    monitorFlag = 1;
                if (monitorFlag == 1) //进入监控状态
                    if (time500msCnt >= 10 && time500msCnt <= 20) //进入监控模式后的5s~10s,持续监测
                        if (HC_SR501 == 0 && SHAKE_PIN == 0) //再次检测到有人且震动
                            alarmFlag = 1;
                            time500msCnt = 0;
                            BUZZER_ON;
                            LCD_DispStr(0, 1, "    Warning!    ");
                            GSM_Send_Sms(phone1, "Please pay attention to your car!");
                            DelayMs(10);
                    else if (time500msCnt > 20) //超过10s没检测到
                        monitorFlag = 0; //退出监控
                        time500msCnt = 0;
                    time500msCnt = 0;
                    BUZZER_OFF;
            else //报警模式
                if (time500msCnt >= 120) //响铃1分钟退出报警模式
                    alarmFlag = 0;
            LED_RED = 1;
            LED_GREEN = 0;
            alarmFlag = 0;
            monitorFlag = 0;
            RELAY_LOCK = 0; //打开锁
            BUZZER_OFF;
        if (refreshFlag == 1) //刷新界面
            refreshFlag = 0;
            TR1 = 0;
                if (alarmFlag == 0)
                        time500msCnt++;
                        time500msCnt = 0;
                        LCD_DispStr(0, 1, "      Lock      ");
                else //报警模式
                    time500msCnt++;
                LCD_DispStr(0, 1, "      Open      ");
                if (time500msCnt2 > 0)
                    time500msCnt2--;
                    RELAY_LOCK = 0; //关闭锁
                    LED_RED = 0;
                    LED_GREEN = 1;
                    lockFlag = 1;
            TR1 = 1;
        CheckKey();       //检测按键
void CheckKey(void)
    static unsigned char rekey = 0;
    if ((KEY_OPEN == 0) || (KEY_CLOSE == 0)) //检测到按键按下
        DelayMs(10); //小抖动
        if (rekey == 0)
            if (KEY_OPEN == 0) //检测是否按下
                rekey = 1;
                lockFlag = 0;
                time500msCnt2 = 20; //开锁20*500ms=10s
            else if (KEY_CLOSE == 0) //
                rekey = 1;
                lockFlag = 1;
        rekey = 0; //防止重复检测到按键
    if (g_irFlag == 1 && g_irCode[2] == IRCodeMap[0][0])
        lockFlag = 0;
        g_irFlag = 0;
    else if (g_irFlag == 1 && g_irCode[2] == IRCodeMap[2][0])
        lockFlag = 1;
        g_irFlag = 0;
*************************************红外解码定时器程序********************************************
//外部中断解码程序_外部中断0
void Ext0_Interrupt(void) interrupt 0
    unsigned char i, j;
    unsigned char byt;
    unsigned int time;
    time = IR_GetLowTime();
    if ((time < 7833) || (time > 8755))
        IE0 = 0;
        return;
    } //找到启始码
    time = IR_GetHighTime();
    if ((time < 3686) || (time > 4608)) //时间判定范围为4.0~5.0ms,
    {                                   //超过此范围则说明为误码,直接退出
        IE0 = 0;
        return;
    //接收并判定后续的4 字节数据
    for (i = 0; i < 4; i++) //循环接收4 个字节
        for (j = 0; j < 8; j++) //循环接收判定每字节的8 个bit
            //接收判定每bit 的560us 低电平
            if ((time < 313) || (time > 718)) //时间判定范围为340~780us,
                IE0 = 0;
                return;
            //接收每bit 高电平时间,判定该bit 的值
            if ((time > 313) && (time < 718)) //时间判定范围为340~780us,
            {                                 //在此范围内说明该bit 值为0
                byt >>= 1;                    //因低位在先,所以数据右移,高位为0
            else if ((time > 1345) && (time < 1751)) //时间判定范围为1460~1900us,
            {                                        //在此范围内说明该bit 值为1
                byt |= 0x80;                         //高位置1
            else //不在上述范围内则说明为误码,直接退出
                IE0 = 0;
                return;
        g_irCode[ i] = byt; //接收完一个字节后保存到缓冲区
    g_irFlag = 1; //接收完毕后设置标志
    IE0 = 0;    //退出前清零INT0 中断标志
                    定时器初始化子程序
    TMOD &= 0x0F; //使用模式1,16位定时器,使用"|"符号可以在使用多个定时器时不受影响
    TMOD |= 0x10; //使用模式1,16位定时器,使用"|"符号可以在使用多个定时器时不受影响
    TH1 = (65536 - 18432) / 256; //重新赋值 20ms
    TL1 = (65536 - 18432) % 256;
    EA = 1;  //总中断打开
    ET1 = 1; //定时器中断打开
    TR1 = 1; //定时器开关打开
                定时器中断子程序
void Timer1_Interrupt(void) interrupt 3
    static unsigned char time20ms  = 0;
    time20ms++;
    if (time20ms >= 25)
        refreshFlag = 1;
        time20ms = 0;
ID:883242 发表于 2024-3-10 14:54 | 只看该作者
IR_INPUT没有定义。
