查看: 1452|回复: 4
Proteus仿真液晶显示花屏?
12864(1).zip (42.83 KB, 下载次数: 3)
液晶显示不理想,但编译是通过了的。也不知道哪里出错了。附源代码
#include<reg52.h>
#include<intrins.h>
#include <math.h> //Keil library
#include <stdio.h> //Keil library
#define LCD_databus P0 //LCD12864的8位数据口
uint heat=000,spurs=000;
uint c;
sbit EN=P2^2; //低电平写入高电平读取
sbit RS=P2^0; //高电平数据输入命令输入
sbit RW=P2^1; //高电平读取低电平写入
sbit CS2=P2^3; //
sbit CS1=P2^4;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit key5=P1^4;
sbit key6=P1^5;
sbit key7=P1^6;
sbit key8=P1^7;
sbit BEEP=P3^0;
char chang=48;
char xiaoshu=0;
char xiaoshu2=0;
uchar f2;
uchar m2;
uchar x2;
uchar count;
char fen=12;
char miao=0;
char flag=24;
unsigned char code time[][16]={
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//"0",
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//"1",
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//"2",
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//"3",
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//"4",
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//"5",
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//"6",
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//"7",
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//"8",
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//"9",
0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//"V",10
0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//"S",11
0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//":",12
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//".",13
0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//"T"14
0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//"N"15
0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//"D"16
0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//"R"17
0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//"H"18
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"空格"19
uchar code HZ[][32]={
0x00,0x08,0x08,0x08,0x08,0x08,0x09,0xFE,
0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
0x40,0x40,0x41,0x41,0x41,0x41,0x41,0x7F,
0x41,0x41,0x41,0x41,0x41,0x40,0x40,0x00,//"主"
0x00,0xFE,0x02,0x22,0xDA,0x06,0x00,0x00,
0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xFF,0x08,0x10,0x88,0x47,0x20,0x18,
0x07,0x00,0x07,0x18,0x20,0x40,0x80,0x00,// "队",
0x10,0x0C,0x84,0x44,0x3C,0x54,0x95,0x96,
0x94,0x54,0x34,0x14,0x04,0x14,0x0C,0x00,
0x04,0x04,0x02,0x02,0xFD,0x45,0x44,0x44,
0x44,0x45,0xFD,0x02,0x02,0x06,0x02,0x00,//“客”
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"一",
void delay_10us(uint n) //延时n个10us@12M晶振
         uint i;
        for(i=n;i>0;i--)
        _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void delay_50us(uint z)
         uint x,y; for(x=z;x>0;x--)
        for(y=19;y>0;y--);
void delay_ms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void delay(uint i)
while(--i);
} /**?延时函数?**/
void delay_1ms(uint x)
uint i,j;
for(j=0;j<x;j++)
for(i=0;i<110;i++);
void Read_busy()//读“忙”函数-----数据线的最高位DB71则busy
        P0=0x00;
        RS=0;
        RW=1;
        EN=1;
        while(P0 & 0x80);
        EN=0;
void write_LCD_command(uchar value) //写命令函数
        Read_busy(); //对LCD的每次读写都要读忙
        RS=0; //选择命令
        RW=0; //读操作
        LCD_databus=value;
        EN=1; //EN由1----0锁存有效数据
        _nop_();
        _nop_();
        EN=0;
void write_LCD_data(uchar value)//写数据函数
        Read_busy();
        RS=1; //选择数据
        RW=0;
        LCD_databus=value;
        _nop_();
        _nop_();
        EN=0;
void Set_page(uchar page) //设置“页”LCD12864共8页,一页是8行点阵点
        page=0xb8|page; //页的首地址为0xB8
        write_LCD_command(page);
void Set_line(uchar startline) //设置显示的起始行
        startline=0xC0|startline; //起始行地址为0xC0
        write_LCD_command(startline); //设置从哪行开始:共0--63;一般从0 行开始显示
void Set_column(uchar column) //设置显示的列
        column=column &0x3f; //列的最大值为64
        column= 0x40|column; //列的首地址为0x40
        write_LCD_command(column); //规定显示的列的位置
void SetOnOff(uchar onoff) //显示开关函数:0x3E是关显示,0x3F是开显示
        onoff=0x3e|onoff; //onoff:1---开显示;0---关显示
        write_LCD_command(onoff);
void SelectScreen(uchar screen) //选择屏幕
        switch(screen)
                case 0: CS1=0;CS2=0;break; //全屏
                case 1: CS1=0;CS2=1;break;//左半屏
                case 2: CS1=1;CS2=0;break;//右半屏
                default:break;
void ClearScreen(uchar screen) //清屏函数
        uchar i,j;
        SelectScreen(screen); //0--全屏;1---左半屏;2---右半屏
        for(i=0;i<8;i++) //控制页数0-7,共8页
                Set_page(i);
                Set_column(0);
                for(j=0;j<64;j++) //控制列数0-63,共64列
                        write_LCD_data(0x00); //写入0,地址指针自加1
void init_LCD() //LCD的初始化
        SetOnOff(1); //开显示
        SelectScreen(0);//
        ClearScreen(0); //清屏
        Set_line(0); //开始行:0
void Display_ASCII(uchar screen,uchar page,uchar column,uchar a[][16],uchar h)
        uchar i;
        Set_page(page);
        Set_column(column*8);
        for(i=0;i<8;i++) //显示字符上半部分:8*8
                write_LCD_data(*(a[h]+i));
        Set_page(page+1); //显示字符下半部分:8*8
        for(i=0;i<8;i++)
        write_LCD_data
        (*(a[h]+i+8));
void Display_HZ(uchar screen,uchar page,uchar column,uchar a[][32],uchar h)
        uchar i;
        Set_page(page); //写上半页:16*8
        Set_column(column*16); //控制列
        for(i=0;i<16;i++) //控制16列的数据输出
                write_LCD_data(*(a[h]+i)); //汉字的上半部分
        Set_page(page+1); //写下半页:16*8
        { write_LCD_data(*(a[h]+16+i)); //汉字的下半部分
void disp1()
        Display_HZ(1,0,2,HZ,0);//主
        Display_HZ(1,0,3,HZ,1);//队
        Display_ASCII(2,0,0,time,10);
        Display_ASCII(2,0,1,time,11);
        Display_HZ(2,0,1,HZ,3);//客
        Display_HZ(2,0,2,HZ,2);//队
void disp2() //
        Display_HZ(1,0,2,HZ,3);// 客
        Display_HZ(1,0,3,HZ,4);//         队
        Display_HZ(2,0,1,HZ,0);//主
        Display_HZ(2,0,2,HZ,1);//队
void disp3()
        if(chang>36)
                Display_ASCII(1,4,0,time,1);
                Display_ASCII(1,4,1,time,11);
                Display_ASCII(1,4,2,time,14);
        else if(chang>24)
                Display_ASCII(1,4,0,time,2);
                Display_ASCII(1,4,1,time,15);
                Display_ASCII(1,4,2,time,16);
        else if(chang>12)
                        Display_ASCII(1,4,0,time,3);
                        Display_ASCII(1,4,1,time,17);
        else if(chang>0)
        { while(1)
                        Display_ASCII(1,4,0,time,4);
                        Display_ASCII(1,4,1,time,14);
                        Display_ASCII(1,4,2,time,18);
void disp4()
        chang=24;
        fen=12;
        miao=0;
        xiaoshu=0;
        xiaoshu2=0;
        flag=0;
void disp5()
        if(fen==0&&miao==0&&xiaoshu==0)
                BEEP=0;
                delay_1ms(5000);
                fen=12;
                miao=0;
                xiaoshu=0;
                TR0=0;
                BEEP=1;
        if(flag==0&&xiaoshu2==0)
                BEEP=0;
                f2=fen;
                m2=miao;
                x2=xiaoshu;
                delay_1ms(5000);
                TR0=0;
                fen=f2;
                miao=m2;
                xiaoshu=x2;
                flag=24;
                xiaoshu2=0;
                BEEP=1;
void dingshiqi()
        TMOD=0X01; //T1 jishu T0 jishi
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=0;
void Key1()
        if(key1==0)
                delay_ms(10);
                if(key1==0)
                        while(!key1)
                                while(!key1)
                                disp2();
                                disp4();
                                c=spurs;
                                spurs=heat;
                                heat=c;
void Key2()
        if(key2==0)
                delay_ms(10);
                if(key2==0)
                        while(!key2)
                        { while(!key2)
                        heat++;
void Key3()
        if(key3==0)
                delay_ms(10);
                if(key3==0)
                        while(!key3)
                                while(!key3)
                                if (heat==0)
                                heat--;
void Key4()
        if(key4==0)
                delay_ms(10);
                if(key4==0)
                        while(!key4)
                                while(!key4)
                                spurs++;
void Key5()
        if(key5==0)
                delay_ms(10);
                if(key5==0)
                        while(!key5)
                                while(!key5){ }
                                if (spurs==0)
                                {spurs--;}
void Key6()
        if(key6==0)
                delay_ms(10);
                if(key6==0)
                        while(!key6)
                                while(!key6)
                                        TR0=0;
void Key7()
        if(key7==0)
        delay_ms(10);
        if(key7==0)
                        while(!key7)
                                while(!key7)
                                TR0=1;
void Key8()
        if(key8==0)
                delay_ms(10);
                if(key8==0)
                        while(!key8)
                                while(!key8)
                                flag=24;
                                xiaoshu2=0;
void main(void)
        uchar A,B,C,D,E,F;
        uchar G,H,I,J,K,L;
        init_LCD();
        dingshiqi();
        disp1();
        disp3();
                disp5();
                Key1();
                Key2();
                Key3();
                Key4();
                Key5();
                Key6();
                Key7();
                Key8();
                A=heat/100;
                B=heat/10%10;
                C=heat%10;
                D=spurs/100;
                E=spurs/10%10;
                F=spurs%10;
                G=fen/10;
                H=fen%10;
                I=miao/10;
                J=miao%10;
                K=flag/10;
                L=flag%10;
                Display_ASCII(1,2,5,time,A);
                Display_ASCII(1,2,6,time,B);
                Display_ASCII(1,2,7,time,C);//bifen
                Display_ASCII(2,2,1,time,12);
                Display_ASCII(2,2,3,time,D);
                Display_ASCII(2,2,4,time,E);
                Display_ASCII(2,2,5,time,F);
                Display_ASCII(1,4,4,time,G);
                Display_ASCII(1,4,5,time,H);
                Display_ASCII(1,4,6,time,12);
                Display_ASCII(1,4,7,time,I);
                Display_ASCII(2,4,0,time,J);
                Display_ASCII(2,4,1,time,13);
                Display_ASCII(2,4,2,time,xiaoshu);
                Display_ASCII(2,4,4,time,K);
                Display_ASCII(2,4,5,time,L);
                Display_ASCII(2,4,6,time,13);
                Display_ASCII(2,4,7,time,xiaoshu2);
void timer0() interrupt 1 //3定时器1的中断号1定时器0的中断号0外部中断1 2外部中 断2 4串口中断
        count++;
        if(count==2)
                count=0;
                xiaoshu--;
                if(xiaoshu==-1)
                { xiaoshu=9; miao--; } //计时时间小数
                if(miao==-1)
                                miao=59;
                                fen--;
                                chang--;
                                if(fen==-1)
                                        fen=12;
                        } //分钟跳动1st 2nd 3rd 4th
                                xiaoshu2--;
                        if(xiaoshu2==-1)
                                xiaoshu2=9;
                                flag--;
                        } //24秒时间小数
                        if(flag==-1)
                                flag=24;
                                xiaoshu2=0;
                        } //24秒重置
不排除proteus设置出错,但我也不清楚是哪里出错了
一般这种情况应该怎么处理?
ID:102963 发表于 2024-3-20 22:00 | 只看该作者
液晶控制口D1网络和数据口的D1网络重了,改下它试试。
ID:1107719 发表于 2024-3-20 22:20 | 只看该作者
按楼上所说弄了,但依然不理想。我再看看 可能是我哪里设置错了
ID:1107719 发表于 2024-3-21 09:59 | 只看该作者
现在是只显示场次和比赛双方,不显示比分了(比赛双方是我调用错了数组导致字不对)
ID:1107719 发表于 2024-3-21 13:06 | 只看该作者
        uchar i;
        Set_page(page);
        for(i=0;i<8;i++)
        write_LCD_data
        (*(a[h]+i+8));
下面的比分显示不出来。是哪里有问题???
