查看: 1020|回复: 0
单片机停车场程序3
ID:918728 发表于 2024-3-27 11:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"ds1302.h"
//---DS1302写入和读取时分秒的地址命令---//
//---秒分时日月周年 最低位读写位;-------//
uchar code READ_RTC_ADDR[7] = {0x81, 0x83, 0x85, 0x87, 0x89, 0x8b, 0x8d};
uchar code WRITE_RTC_ADDR[7] = {0x80, 0x82, 0x84, 0x86, 0x88, 0x8a, 0x8c};
//---DS1302时钟初始化2024年3月25日星期一12点00分00秒。---//
//---存储顺序是秒分时日月周年,存储格式是用BCD码---//
uchar TIME[7] = {0, 0, 0x12, 0x00, 0x05, 0x00, 0x02};
uchar nian,yue,ri,shi,fen,miao;
* 函 数 名         : Ds1302Init
* 函数功能                   : 初始化DS1302.
* 输    入         : 无
* 输    出         : 无
void Ds1302Init()
    uchar n,temp;
    Ds1302Write(0x8E,0X00);                 //禁止写保护,就是关闭写保护功能
    for (n=0; n<7; n++)//读取7个字节的时钟信号:分秒时日月周年
                                temp=Ds1302Read(READ_RTC_ADDR[n]);
                                TIME[n]=temp/10*16+temp%10;
    Ds1302Write(0x8E,0x80);                 //打开写保护功能}
函 数 名         : Ds1302ReadTime
* 函数功能                   : 读取时钟信息
* 输    入         : 无
* 输    出         : 无
void Ds1302ReadTime()
    uchar n,temp;
                                TIME[n]=temp/16*10+temp%16;
//                nian=TIME[6]/10*16+TIME[6]%10;
//    yue=TIME[4]/10*16+TIME[4]%10;
//                ri=TIME[3]/10*16+TIME[3]%10;
//                shi=TIME[2]/10*16+TIME[2]%10;
//                fen=TIME[1]/10*16+TIME[1]%10;
//                miao=TIME[0]/10*16+TIME[0]%10;
oled。h
unsigned char code Hzk[][32]={
{0x80,0x60,0xF8,0x07,0x00,0x04,0x74,0x54,0x55,0x56,0x54,0x54,0x74,0x04,0x00,0x00},
{0x00,0x00,0xFF,0x00,0x03,0x01,0x05,0x45,0x85,0x7D,0x05,0x05,0x05,0x01,0x03,0x00},/*"停",0*/
/* (16 X 16 , 宋体 )*/         //0
{0x00,0x08,0x88,0x48,0x28,0x18,0x0F,0xE8,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00},
{0x08,0x08,0x09,0x09,0x09,0x09,0x09,0xFF,0x09,0x09,0x09,0x09,0x09,0x08,0x08,0x00},/*"车",0*/
/* (16 X 16 , 宋体 )*/         //1
{0x20,0x20,0xFF,0x20,0x20,0x00,0x42,0xE2,0x52,0x4A,0xC6,0x42,0x40,0xC0,0x00,0x00},
{0x10,0x30,0x1F,0x08,0x28,0x10,0x8C,0x43,0x20,0x18,0x47,0x80,0x40,0x3F,0x00,0x00},/*"场",1*/
/* (16 X 16 , 宋体 )*/         //2
{0x88,0x64,0x23,0xA2,0xA6,0xAA,0xA2,0xBA,0xA4,0xA3,0xA2,0x26,0x2A,0xA2,0x62,0x00},
{0x00,0x00,0x00,0xFF,0x4A,0x4A,0x4A,0x4A,0x4A,0x4A,0x4B,0xF8,0x00,0x00,0x00,0x00},/*"管",2*/
/* (16 X 16 , 宋体 )*/         //3
{0x04,0x84,0x84,0xFC,0x84,0x84,0x00,0xFE,0x92,0x92,0xFE,0x92,0x92,0xFE,0x00,0x00},
{0x20,0x60,0x20,0x1F,0x10,0x10,0x40,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x40,0x00},/*"理",3*/
/* (16 X 16 , 宋体 )*/         //4
{0x00,0x00,0x22,0x32,0x2A,0xA6,0xA2,0x62,0x21,0x11,0x09,0x81,0x01,0x00,0x00,0x00},
{0x00,0x42,0x22,0x13,0x0B,0x42,0x82,0x7E,0x02,0x02,0x0A,0x12,0x23,0x46,0x00,0x00},/*"系",4*/
/* (16 X 16 , 宋体 )*/         //5
{0x20,0x30,0xAC,0x63,0x30,0x00,0x88,0xC8,0xA8,0x99,0x8E,0x88,0xA8,0xC8,0x88,0x00},
{0x22,0x67,0x22,0x12,0x12,0x80,0x40,0x30,0x0F,0x00,0x00,0x3F,0x40,0x40,0x71,0x00},/*"统",5*/
/* (16 X 16 , 宋体 )*/         //6
{0x00,0x00,0x00,0xF1,0x12,0x14,0x10,0x10,0x10,0x14,0x12,0xF1,0x00,0x00,0x00,0x00},
{0x40,0x30,0x00,0x03,0x39,0x41,0x41,0x45,0x59,0x41,0x41,0x73,0x00,0x08,0x30,0x00},/*"总",0*/
/* (16 X 16 , 宋体 )*/         //7
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*":",1*/
/* (16 X 16 , 宋体 )*/         //8
{0x48,0x4A,0xFA,0x0A,0xFE,0x09,0xF9,0x49,0xA8,0x00,0x00,0xF0,0x00,0x00,0xFF,0x00},
{0x22,0x11,0x0B,0x04,0xFF,0x04,0x09,0x12,0x23,0x00,0x00,0x0F,0x40,0x80,0x7F,0x00},/*"剩",0*/
/* (16 X 16 , 宋体 )*/         //9
{0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x44,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x02,0x04,0x08,0x10,0x00,0x00,0x00},/*"卡",0*/
/* (16 X 16 , 宋体 )*/         //10
{0x80,0x80,0x80,0xBE,0xA2,0xA2,0xA2,0xA2,0xA2,0xA2,0xA2,0xBE,0x80,0x80,0x80,0x00},
{0x00,0x00,0x00,0x06,0x05,0x04,0x04,0x04,0x44,0x84,0x44,0x3C,0x00,0x00,0x00,0x00},/*"号",1*/
/* (16 X 16 , 宋体 )*/         //11
{0x40,0x42,0xCC,0x00,0x00,0x44,0x54,0x54,0x54,0x7F,0x54,0x54,0x54,0x44,0x40,0x00},
{0x00,0x00,0x7F,0x20,0x10,0x00,0xFF,0x15,0x15,0x15,0x55,0x95,0x7F,0x00,0x00,0x00},/*"请",4*/
/* (16 X 16 , 宋体 )*/         //12
{0x10,0x10,0x14,0xD4,0x54,0x54,0x54,0xFC,0x52,0x52,0x52,0xD3,0x12,0x10,0x10,0x00},
{0x40,0x40,0x50,0x57,0x55,0x55,0x55,0x7F,0x55,0x55,0x55,0x57,0x50,0x40,0x40,0x00},/*"重",5*/
/* (16 X 16 , 宋体 )*/         //13
{0x00,0x00,0xFE,0x12,0x12,0x12,0xF2,0x12,0x12,0x1E,0x00,0xF0,0x00,0x00,0xFF,0x00},
{0x10,0x0E,0x01,0x3F,0x01,0x01,0xFF,0x11,0x21,0x1F,0x00,0x0F,0x40,0x80,0x7F,0x00},/*"刷",6*/
/* (16 X 16 , 宋体 )*/         //14
{0x40,0x40,0x42,0xCC,0x00,0x40,0x40,0x40,0x40,0xFF,0x40,0x40,0x40,0x40,0x40,0x00},
{0x00,0x00,0x00,0x7F,0x20,0x10,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00},/*"计",0*/
/* (16 X 16 , 宋体 )*/         //15
{0x00,0xFC,0x84,0x84,0x84,0xFC,0x00,0x10,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x00},
{0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00,0x01,0x06,0x40,0x80,0x7F,0x00,0x00,0x00},/*"时",1*/
/* (16 X 16 , 宋体 )*/         //16
{0x00,0x00,0x00,0xFE,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0xFE,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0xFF,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x00,0x00,0x00,0x00},/*"日",0*/
/* (16 X 16 , 宋体 )*/      //17
{0x00,0x04,0xFF,0x24,0x24,0x24,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00},
{0x88,0x48,0x2F,0x09,0x09,0x19,0xAF,0x48,0x30,0x0F,0x02,0x42,0x82,0x7F,0x00,0x00},/*"期",1*/
/* (16 X 16 , 宋体 )*/      //18
{0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00,0x01,0x06,0x40,0x80,0x7F,0x00,0x00,0x00},/*"时",2*/
/* (16 X 16 , 宋体 )*/      //19
{0x00,0xF8,0x01,0x06,0x00,0xF0,0x12,0x12,0x12,0xF2,0x02,0x02,0x02,0xFE,0x00,0x00},
{0x00,0xFF,0x00,0x00,0x00,0x1F,0x11,0x11,0x11,0x1F,0x00,0x40,0x80,0x7F,0x00,0x00},/*"间",3*/
/* (16 X 16 , 宋体 )*/      //20
{0x40,0x40,0x42,0xCC,0x00,0x40,0xA0,0x9E,0x82,0x82,0x82,0x9E,0xA0,0x20,0x20,0x00},
{0x00,0x00,0x00,0x3F,0x90,0x88,0x40,0x43,0x2C,0x10,0x28,0x46,0x41,0x80,0x80,0x00},/*"设",0*/
/* (16 X 16 , 宋体 )*/      //21
{0x00,0x17,0x15,0xD5,0x55,0x57,0x55,0x7D,0x55,0x57,0x55,0xD5,0x15,0x17,0x00,0x00},
{0x40,0x40,0x40,0x7F,0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x7F,0x40,0x40,0x40,0x00},/*"置",1*/
/* (16 X 16 , 宋体 )*/      //22
{0x00,0x20,0x20,0xA8,0x6C,0x2A,0x39,0x28,0xA8,0x2A,0x6C,0xA8,0x20,0x20,0x00,0x00},
{0x02,0x82,0x81,0x90,0x92,0x4A,0x49,0x45,0x24,0x22,0x10,0x08,0x01,0x02,0x02,0x00},/*"参",2*/
/* (16 X 16 , 宋体 )*/      //23
{0x90,0x52,0x34,0x10,0xFF,0x10,0x34,0x52,0x80,0x70,0x8F,0x08,0x08,0xF8,0x08,0x00},
{0x82,0x9A,0x56,0x63,0x22,0x52,0x8E,0x00,0x80,0x40,0x33,0x0C,0x33,0x40,0x80,0x00},/*"数",3*/
/* (16 X 16 , 宋体 )*/      //24
{0x00,0x00,0xF8,0x49,0x4A,0x4C,0x48,0xF8,0x48,0x4C,0x4A,0x49,0xF8,0x00,0x00,0x00},
{0x10,0x10,0x13,0x12,0x12,0x12,0x12,0xFF,0x12,0x12,0x12,0x12,0x13,0x10,0x10,0x00},/*"单",0*/
/* (16 X 16 , 宋体 )*/      //25
{0x00,0x80,0x60,0xF8,0x07,0x40,0x20,0x90,0x0C,0x03,0x0C,0x90,0x20,0x40,0x40,0x00},
{0x01,0x00,0x00,0xFF,0x00,0x80,0x60,0x1F,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00},/*"价",1*/
/* (16 X 16 , 宋体 )*/      //26
{0x00,0x80,0x60,0xF8,0x07,0x10,0x90,0x10,0x11,0x16,0x10,0x10,0xD0,0x10,0x00,0x00},
{0x01,0x00,0x00,0xFF,0x40,0x40,0x41,0x5E,0x40,0x40,0x70,0x4E,0x41,0x40,0x40,0x00},/*"位",2*/
/* (16 X 16 , 宋体 )*/      //27
{0x22,0x11,0x0B,0x04,0xFF,0x04,0x09,0x12,0x23,0x00,0x00,0x0F,0x40,0x80,0x7F,0x00},/*"剩",3*/
/* (16 X 16 , 宋体 )*/      //28
{0x20,0x20,0x22,0x22,0x22,0xE2,0x22,0x22,0x22,0xE2,0x22,0x22,0x22,0x20,0x20,0x00},
{0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x78,0x00},/*"元",4*/
/* (16 X 16 , 宋体 )*/      //29
{0x80,0x40,0x20,0x90,0x88,0x86,0x80,0x80,0x80,0x83,0x8C,0x10,0x20,0x40,0x80,0x00},
{0x00,0x80,0x40,0x20,0x18,0x07,0x00,0x40,0x80,0x40,0x3F,0x00,0x00,0x00,0x00,0x00},/*"分",0*/
/* (16 X 16 , 宋体 )*/     //30
{0x00,0x00,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,0x00},
{0x00,0x04,0x84,0x44,0x24,0x17,0x04,0x04,0x04,0x04,0x17,0x24,0x44,0x84,0x04,0x00},/*"共",0*/
/* (16 X 16 , 宋体 )*/   //31
#endif
