查看: 4875|回复: 4
[萌新]STM32F103C8T6+OLED显示屏驱动
前言
在学习stm32中....
发现此站一篇文章 下载文件需要黑币 所以把做过像样的程序发上来 希望能帮到有需要的人
硬件连接
GND -- GND
VCC -- 3.3v
SCL -- B8
SDA -- B9
驱动代码
OLED.h头文件
  1. #ifndef __OLED_H
  2. #define __OLED_H
  3. void OLED_Init(void);
  4. void OLED_Clear(void);
  5. void OLED_ShowChar(uint8_t Line, uint8_t Column, char Char);
  6. void OLED_ShowString(uint8_t Line, uint8_t Column, char *String);
  7. void OLED_ShowNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
  8. void OLED_ShowSignedNum(uint8_t Line, uint8_t Column, int32_t Number, uint8_t Length);
  9. void OLED_ShowHexNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
  10. void OLED_ShowBinNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
  11. #endif
OLED.c
  1. #include "stm32f10x.h"
  2. #include "OLED_Font.h"
  3. /*引脚配置*/
  4. #define OLED_W_SCL(x)                GPIO_WriteBit(GPIOB, GPIO_Pin_8, (BitAction)(x))
  5. #define OLED_W_SDA(x)                GPIO_WriteBit(GPIOB, GPIO_Pin_9, (BitAction)(x))
  6. /*引脚初始化*/
  7. void OLED_I2C_Init(void)
  8. {
  9.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  10.
  11.         GPIO_InitTypeDef GPIO_InitStructure;
  12.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  14.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  15.          GPIO_Init(GPIOB, &GPIO_InitStructure);
  16.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  17.          GPIO_Init(GPIOB, &GPIO_InitStructure);
  18.
  19.         OLED_W_SCL(1);
  20.         OLED_W_SDA(1);
  21. }
  22. /**
  23.   * @brief  I2C开始
  24.   * @param  无
  25.   * @retval 无
  26.   */
  27. void OLED_I2C_Start(void)
  28. {
  29.         OLED_W_SDA(1);
  30.         OLED_W_SCL(1);
  31.         OLED_W_SDA(0);
  32.         OLED_W_SCL(0);
  33. }
  34. /**
  35.   * @brief  I2C停止
  36.   * @param  无
  37.   * @retval 无
  38.   */
  39. void OLED_I2C_Stop(void)
  40. {
  41.         OLED_W_SDA(0);
  42.         OLED_W_SCL(1);
  43.         OLED_W_SDA(1);
  44. }
  45. /**
  46.   * @brief  I2C发送一个字节
  47.   * @param  Byte 要发送的一个字节
  48.   * @retval 无
  49.   */
  50. void OLED_I2C_SendByte(uint8_t Byte)
  51. {
  52.         uint8_t i;
  53.         for (i = 0; i < 8; i++)
  54.         {
  55.                 OLED_W_SDA(Byte & (0x80 >> i));
  56.                 OLED_W_SCL(1);
  57.                 OLED_W_SCL(0);
  58.         }
  59.         OLED_W_SCL(1);        //额外的一个时钟,不处理应答信号
  60.         OLED_W_SCL(0);
  61. }
  62. /**
  63.   * @brief  OLED写命令
  64.   * @param  Command 要写入的命令
  65.   * @retval 无
  66.   */
  67. void OLED_WriteCommand(uint8_t Command)
  68. {
  69.         OLED_I2C_Start();
  70.         OLED_I2C_SendByte(0x78);                //从机地址
  71.         OLED_I2C_SendByte(0x00);                //写命令
  72.         OLED_I2C_SendByte(Command);
  73.         OLED_I2C_Stop();
  74. }
  75. /**
  76.   * @brief  OLED写数据
  77.   * @param  Data 要写入的数据
  78.   * @retval 无
  79.   */
  80. void OLED_WriteData(uint8_t Data)
  81. {
  82.         OLED_I2C_Start();
  83.         OLED_I2C_SendByte(0x78);                //从机地址
  84.         OLED_I2C_SendByte(0x40);                //写数据
  85.         OLED_I2C_SendByte(Data);
  86.         OLED_I2C_Stop();
  87. }
  88. /**
  89.   * @brief  OLED设置光标位置
  90.   * @param  Y 以左上角为原点,向下方向的坐标,范围:0~7
  91.   * @param  X 以左上角为原点,向右方向的坐标,范围:0~127
  92.   * @retval 无
  93.   */
  94. void OLED_SetCursor(uint8_t Y, uint8_t X)
  95. {
  96.         OLED_WriteCommand(0xB0 | Y);                                        //设置Y位置
  97.         OLED_WriteCommand(0x10 | ((X & 0xF0) >> 4));        //设置X位置高4位
  98.         OLED_WriteCommand(0x00 | (X & 0x0F));                        //设置X位置低4位
  99. }
  100. /**
  101.   * @brief  OLED清屏
  102.   * @param  无
  103.   * @retval 无
  104.   */
  105. void OLED_Clear(void)
  106. {
  107.         uint8_t i, j;
  108.         for (j = 0; j < 8; j++)
  109.         {
  110.                 OLED_SetCursor(j, 0);
  111.                 for(i = 0; i < 128; i++)
  112.                 {
  113.                         OLED_WriteData(0x00);
  114.                 }
  115.         }
  116. }
  117. /**
  118.   * @brief  OLED显示一个字符
  119.   * @param  Line 行位置,范围:1~4
  120.   * @param  Column 列位置,范围:1~16
  121.   * @param  Char 要显示的一个字符,范围:ASCII可见字符
  122.   * @retval 无
  123.   */
  124. void OLED_ShowChar(uint8_t Line, uint8_t Column, char Char)
  125. {
  126.         uint8_t i;
  127.         OLED_SetCursor((Line - 1) * 2, (Column - 1) * 8);                //设置光标位置在上半部分
  128.         for (i = 0; i < 8; i++)
  129.         {
  130.                 OLED_WriteData(OLED_F8x16[Char - ' '][i]);                        //显示上半部分内容
  131.         }
  132.         OLED_SetCursor((Line - 1) * 2 + 1, (Column - 1) * 8);        //设置光标位置在下半部分
  133.         for (i = 0; i < 8; i++)
  134.         {
  135.                 OLED_WriteData(OLED_F8x16[Char - ' '][i + 8]);                //显示下半部分内容
  136.         }
  137. }
  138. /**
  139.   * @brief  OLED显示字符串
  140.   * @param  Line 起始行位置,范围:1~4
  141.   * @param  Column 起始列位置,范围:1~16
  142.   * @param  String 要显示的字符串,范围:ASCII可见字符
  143.   * @retval 无
  144.   */
  145. void OLED_ShowString(uint8_t Line, uint8_t Column, char *String)
  146. {
  147.         uint8_t i;
  148.         for (i = 0; String[i] != '\0'; i++)
  149.         {
  150.                 OLED_ShowChar(Line, Column + i, String[i]);
  151.         }
  152. }
  153. /**
  154.   * @brief  OLED次方函数
  155.   * @retval 返回值等于X的Y次方
  156.   */
  157. uint32_t OLED_Pow(uint32_t X, uint32_t Y)
  158. {
  159.         uint32_t Result = 1;
  160.         while (Y--)
  161.         {
  162.                 Result *= X;
  163.         }
  164.         return Result;
  165. }
  166. /**
  167.   * @brief  OLED显示数字(十进制,正数)
  168.   * @param  Line 起始行位置,范围:1~4
  169.   * @param  Column 起始列位置,范围:1~16
  170.   * @param  Number 要显示的数字,范围:0~4294967295
  171.   * @param  Length 要显示数字的长度,范围:1~10
  172.   * @retval 无
  173.   */
  174. void OLED_ShowNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
  175. {
  176.         uint8_t i;
  177.         for (i = 0; i < Length; i++)
  178.         {
  179.                 OLED_ShowChar(Line, Column + i, Number / OLED_Pow(10, Length - i - 1) % 10 + '0');
  180.         }
  181. }
  182. /**
  183.   * @brief  OLED显示数字(十进制,带符号数)
  184.   * @param  Line 起始行位置,范围:1~4
  185.   * @param  Column 起始列位置,范围:1~16
  186.   * @param  Number 要显示的数字,范围:-2147483648~2147483647
  187.   * @param  Length 要显示数字的长度,范围:1~10
  188.   * @retval 无
  189.   */
  190. void OLED_ShowSignedNum(uint8_t Line, uint8_t Column, int32_t Number, uint8_t Length)
  191. {
  192.         uint8_t i;
  193.         uint32_t Number1;
  194.         if (Number >= 0)
  195.         {
  196.                 OLED_ShowChar(Line, Column, '+');
  197.                 Number1 = Number;
  198.         }
  199.         else
  200.         {
  201.                 OLED_ShowChar(Line, Column, '-');
  202.                 Number1 = -Number;
  203.         }
  204.         for (i = 0; i < Length; i++)
  205.         {
  206.                 OLED_ShowChar(Line, Column + i + 1, Number1 / OLED_Pow(10, Length - i - 1) % 10 + '0');
  207.         }
  208. }
  209. /**
  210.   * @brief  OLED显示数字(十六进制,正数)
  211.   * @param  Line 起始行位置,范围:1~4
  212.   * @param  Column 起始列位置,范围:1~16
  213.   * @param  Number 要显示的数字,范围:0~0xFFFFFFFF
  214.   * @param  Length 要显示数字的长度,范围:1~8
  215.   * @retval 无
  216.   */
  217. void OLED_ShowHexNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
  218. {
  219.         uint8_t i, SingleNumber;
  220.         for (i = 0; i < Length; i++)
  221.         {
  222.                 SingleNumber = Number / OLED_Pow(16, Length - i - 1) % 16;
  223.                 if (SingleNumber < 10)
  224.                 {
  225.                         OLED_ShowChar(Line, Column + i, SingleNumber + '0');
  226.                 }
  227.                 else
  228.                 {
  229.                         OLED_ShowChar(Line, Column + i, SingleNumber - 10 + 'A');
  230.                 }
  231.         }
  232. }
  233. /**
  234.   * @brief  OLED显示数字(二进制,正数)
  235.   * @param  Line 起始行位置,范围:1~4
  236.   * @param  Column 起始列位置,范围:1~16
  237.   * @param  Number 要显示的数字,范围:0~1111 1111 1111 1111
  238.   * @param  Length 要显示数字的长度,范围:1~16
  239.   * @retval 无
  240.   */
  241. void OLED_ShowBinNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
  242. {
  243.         uint8_t i;
  244.         for (i = 0; i < Length; i++)
  245.         {
  246.                 OLED_ShowChar(Line, Column + i, Number / OLED_Pow(2, Length - i - 1) % 2 + '0');
  247.         }
  248. }
  249. /**
  250.   * @brief  OLED初始化
  251.   * @param  无
  252.   * @retval 无
  253.   */
  254. void OLED_Init(void)
  255. {
  256.         uint32_t i, j;
  257.
  258.         for (i = 0; i < 1000; i++)                        //上电延时
  259.         {
  260.                 for (j = 0; j < 1000; j++);
  261.         }
  262.
  263.         OLED_I2C_Init();                        //端口初始化
  264.
  265.         OLED_WriteCommand(0xAE);        //关闭显示
  266.
  267.         OLED_WriteCommand(0xD5);        //设置显示时钟分频比/振荡器频率
  268.         OLED_WriteCommand(0x80);
  269.
  270.         OLED_WriteCommand(0xA8);        //设置多路复用率
  271.         OLED_WriteCommand(0x3F);
  272.
  273.         OLED_WriteCommand(0xD3);        //设置显示偏移
  274.         OLED_WriteCommand(0x00);
  275.
  276.         OLED_WriteCommand(0x40);        //设置显示开始行
  277.
  278.         OLED_WriteCommand(0xA1);        //设置左右方向,0xA1正常 0xA0左右反置
  279.
  280.         OLED_WriteCommand(0xC8);        //设置上下方向,0xC8正常 0xC0上下反置
  281.         OLED_WriteCommand(0xDA);        //设置COM引脚硬件配置
  282.         OLED_WriteCommand(0x12);
  283.
  284.         OLED_WriteCommand(0x81);        //设置对比度控制
  285.         OLED_WriteCommand(0xCF);
  286.         OLED_WriteCommand(0xD9);        //设置预充电周期
  287.         OLED_WriteCommand(0xF1);
  288.         OLED_WriteCommand(0xDB);        //设置VCOMH取消选择级别
  289.         OLED_WriteCommand(0x30);
  290.         OLED_WriteCommand(0xA4);        //设置整个显示打开/关闭
  291.         OLED_WriteCommand(0xA6);        //设置正常/倒转显示
  292.         OLED_WriteCommand(0x8D);        //设置充电泵
  293.         OLED_WriteCommand(0x14);
  294.         OLED_WriteCommand(0xAF);        //开启显示
  295.
  296.         OLED_Clear();                                //OLED清屏
  297. }
主函数main.c
  2. #include "OLED.h"
  3. #include "max30102.h"
  4. // 延时函数
  5. void delay_ms(uint32_t ms) {
  6.     uint32_t i;
  7.     for (i = 0; i < ms * 1000; i++) {
  8.         __NOP();
  9.     }
  10. }
  11. // LED 绿灯
  12. void LED_Init() {
  13.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  14.     GPIO_InitTypeDef GPIO_InitStruct;
  15.     GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
  16.     GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13;
  17.     GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
  18.     GPIO_Init(GPIOC, &GPIO_InitStruct);
  19.
  20. }
  21. void countTime() {
  22.         // 倒计时逻辑
  23.     for (int i = 0; i <= 10; i++) {
  24.         OLED_ShowNum(4, 7, i, 2); // 更新倒计时显示
  25.                 OLED_ShowString(4, 9, "s");
  26.                 delay_ms(7000);
  27.                 //if(i == 0) {
  28.                 //        i = 60;
  29.                 //}
  30.     }
  31.     // 倒计时结束,显示结束信息
  32.     OLED_Clear();
  33.     //OLED_ShowString(2, 1, "Time's up!");
  34.         OLED_ShowString(1, 2, "Case: Max30102");
  35.         OLED_ShowString(2, 4, "2024-04-07");
  36.         OLED_ShowString(3, 1, "HR:");
  37.         OLED_ShowString(4, 1, "SpO2:");
  38. }
  39. // OLED屏显示内容
  40. void showOLED() {
  41.         OLED_Init();
  42.         OLED_ShowString(1, 2, "Case: Max30102");
  43.         OLED_ShowString(2, 4, "2024-04-07");
  44.         OLED_ShowString(3, 1, "Put your finger");
  45.
  46.         if(MAX30102_INIT_FAILED) {
  47.                 countTime();
  48.         } else {
  49.                 OLED_ShowString(4, 4, "No finger");
  50.         }
  51. }
  52. int main(void) {
  53.         //LED_Init();
  54.
  55.         showOLED();
  56.
  57. }
收藏收藏1 分享淘帖 顶 踩
ID:205485 发表于 2024-4-8 11:52 | 只看该作者
这个不是江科大例程吗
ID:1118813 发表于 2024-4-29 11:29 | 只看该作者
这好像是江科大的例程吧?如果楼主可以改成Hal库的版本就好了
ID:1118867 发表于 2024-5-27 16:12 | 只看该作者
能解释一下第一个吗 刚学有点看不懂
ID:476284 发表于 2024-7-27 12:28 | 只看该作者
谢谢分享!有可直接调用的汉字库吗?
