查看: 3523|回复: 6
单片机电饭煲程序
ID:918728 发表于 2024-4-29 10:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "includes.h"
uint temp;
uint count;
uint hour,minute,sec,oldsec=0;
uint hour1=0,minute1=0,sec1=0;   //时,分,秒
sbit green = P1^0;                         //工作指示灯
sbit red  = P1^1;                     //停止指示灯
sbit Cook = P1^2;                         //速煮米饭
sbit Soup  = P1^3;                     //精煮米饭
sbit congee = P1^7;                        //煮粥
sbit Stewed = P2^0;                        //煲汤
sbit KeepHeat = P1^4;            //保温
sbit menu = P1^5;                        //时间预约
sbit add = P1^6;                        //加
sbit dec = P2^1;                        //减
sbit Beep = P2^4;                        //蜂鸣器
sbit AddTemp = P3^7;  //加热
uint ModeFlag;
unsigned char mode;
void KeepTemp(void);
******          延时程序    ***************
void delay_ms(unsigned char ms)    // 延时毫秒@12M,ms最大值255
    unsigned char i;
    while(ms--)
        for(i = 0; i < 5; i++);
void delay00(unsigned int z)
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
******          设置工作模式    ***************
void SetMode()
        if(Cook == 0)        //速煮米饭
                delay_ms(5);
                while(!Cook);
                sec = 0;
                minute = 0;
                count = 0;
                ModeFlag = 1;
        else if(Soup == 0)            //精煮米饭
                delay_ms(5);
                while(!Soup);
                sec = 0;
                minute = 0;
                count = 0;
                ModeFlag = 2;
        else if(KeepHeat == 0)    //保温
                delay_ms(5);
                while(!KeepHeat);
                sec = 0;
                minute = 0;
                count = 0;
                ModeFlag = 5;
        else if(congee == 0)                //煮粥
                delay_ms(5);
                while(!congee);
                sec = 0;
                minute = 0;
                count = 0;
                ModeFlag = 3;
        else if(Stewed == 0)                //煲汤
                delay_ms(5);
                while(!Stewed);
                sec = 0;
                minute = 0;
                count = 0;
                ModeFlag = 4;
******          速煮米饭部分   ***************
void CookRice(void)                          //速煮米饭
        LCD_WriteString(0,0,"Cook Rice..");
        AddTemp = 0;//开始加热
        green = 0;
        red=1;
        if(temp >= 500)  //超过50度
                TR0 = 1;
                if(sec!=oldsec)
                        oldsec=sec;
                        LCD_SramChar(11,1,(3 - minute)%100/10+0x30);                  //4分钟
                        LCD_SramChar(12,1,(3 - minute)%10+0x30);
                        LCD_SramChar(13,1,':');
                        LCD_SramChar(14,1,(59 - sec)%100/10+0x30);
                        LCD_SramChar(15,1,(59 - sec)%10+0x30);
        TR0 = 0;
        if((1 - minute) == 0 && (59 - sec) == 0)
                TR0 = 0;
                AddTemp = 1;
                green = 1;
            red=0;
                Beep = 0;delay00(200);Beep = 1;delay00(200);
                ModeFlag=5;                 //保温
******          精煮米饭部分   ***************
void CookCong(void)
        LCD_WriteString(0,0,"Cook Cong..");
        AddTemp = ~AddTemp;//开始加热
        green = 0;
        red=1;
        if(temp >= 500)//超过50度
                TR0 = 1;
                if(sec!=oldsec)
                        oldsec=sec;
                        LCD_SramChar(11,1,(6 - minute)%100/10+0x30);                  //7分钟
                        LCD_SramChar(12,1,(6 - minute)%10+0x30);
        TR0 = 0;
                TR0 = 0;
                AddTemp = 1;
                green = 1;
            red=0;
                ModeFlag=5;
******          煮粥部分   ***************
void CookSoup(void)                        //煮粥
        LCD_WriteString(0,0,"Cook Soup..");
  delay00(200);
        green = 0;
        red=1;
        if(temp >= 450)//超过45度
                TR0 = 1;
                if(sec!=oldsec)
                        oldsec=sec;
                        LCD_SramChar(11,1,(3 - minute)%100/10+0x30);         //4 分钟
        TR0 = 0;
                TR0 = 0;
                AddTemp = 1;
                green = 1;
            red=0;
                //KeepTemp();
                ModeFlag=5;
******          煲汤部分   ***************
void Stewedsoup(void)                        //煲汤
        LCD_WriteString(0,0,"Stew soup..");
  delay00(800);
        green = 0;
        red=1;
        if(temp >= 400)//超过40度
                TR0 = 1;
                if(sec!=oldsec)
                        oldsec=sec;
                        LCD_SramChar(11,1,(5 - minute)%100/10+0x30);         //6分钟
                        LCD_SramChar(12,1,(5 - minute)%10+0x30);
        TR0 = 0;
                TR0 = 0;
                AddTemp = 1;
                green = 1;
            red=0;
                ModeFlag=5;
******          保温部分   ***************
void KeepTemp(void)
        LCD_WriteString(0,0,"Keep Temp..     ");
        AddTemp = 0;//开始加热
        green = 0;
        red=0;
        if(temp >= 300)//超过60度        30
                AddTemp = 1;//停止加热
else if(temp <= 300)           //开始加热 30度
                AddTemp = 0;
                green = 0;
            red=0;
******          按键部分   ***************
void key_scan()
        unsigned char s1num=0;
        if(menu==0)
       delay00(50);
           if(menu==0)
             while(!menu);
                  s1num++;
                command(0x01);
                TR0 = 0; hour=0;minute=0;sec=0;
                    if(menu==0)
                delay00(50);
                    if(menu==0)
                                     while(!menu);
                         s1num++;
                        if(s1num==1)
                                LCD_WriteString(0,0,"Set Mode:");
                                LCD_SramChar(9,0,mode/10+0x30);
                                LCD_SramChar(10,0,mode%10+0x30);
                           if(add==0)
                                         delay00(30);
                                         if(add==0)
                                                 {         while(!add);
        mode ++;
        if(mode >= 5)
        mode = 0;
                                 if(dec==0)
                                         delay00(30);
                                         if(dec==0)
                                                 {         while(!dec);
                                                        if(mode == 0)
        mode = 5;
        mode --;
                        if(s1num==2)
                                LCD_WriteString(0,0,"Set hour:");
                                LCD_SramChar(9,0,hour1/10+0x30);
                                LCD_SramChar(10,0,hour1%10+0x30);
                           if(add==0)
                                         delay00(30);
                                         if(add==0)
                                                 {         while(!add);
        hour1 ++;
        if(hour1 == 12)
        hour1 = 0;
                                 if(dec==0)
                                         delay00(30);
                                         if(dec==0)
                                                 {         while(!dec);
                                                        if(hour1 == 0)
        hour1 = 12;
        hour1 --;
                         if(s1num==3)
                                LCD_WriteString(0,0,"Set minute:");
                                LCD_SramChar(11,0,minute1/10+0x30);
                                LCD_SramChar(12,0,minute1%10+0x30);
                            if(add==0)
                               delay00(30);
                               if(add==0)
                                 {         while(!add);
                                        minute1 ++;
                                                        if(minute1 == 60)
        minute1 = 0;
                  if(dec==0)
                               delay00(30);
                               if(dec==0)
                                 {         while(!dec);
                                                if(minute1 == 0)
                                                        minute1 = 60;
                                                minute1 --;
                        if(s1num == 4)
                                s1num=0;//s1num清零//
                                command(0x01);   //清屏
                                ModeFlag = 6;
                                AddTemp = 1;
                                TR0 = 1;
                                break;
******     显示预约剩余时间部分   ***************
void SetTime(void)
        LCD_SramChar(0,1,(hour1 - hour)%100/10+0x30);           //hour1 是设定的时间,hour是正常走的时间
        LCD_SramChar(1,1,(hour1 - hour)%10+0x30);
        LCD_SramChar(2,1,':');
        if((minute1-minute)>0)
                LCD_SramChar(3,1,(minute1 - 1 - minute)%100/10+0x30);
                LCD_SramChar(4,1,(minute1 - 1 - minute)%10+0x30);
                LCD_SramChar(3,1,'0');
                LCD_SramChar(4,1,'0');
        LCD_SramChar(5,1,':');
        if(((hour1 - hour)>0)||((minute1-minute)>0))
                LCD_SramChar(6,1,(59 - sec)%100/10+0x30);
                LCD_SramChar(7,1,(59 - sec)%10+0x30);
                LCD_SramChar(6,1,'0');
                LCD_SramChar(7,1,'0');
        LCD_WriteString(8,1,"   ");
        if((minute1 - 1 - minute) == 0 && (59 - sec) == 0 &&(hour1 - hour) == 0)
                TR0 = 0;Beep = 0;delay00(200);Beep = 1;
                ModeFlag = mode;
******          主函数  ***************
         EA = 1;
         TMOD = 0X01;
         ET0 = 1;
         TH0 = 0X3C;
         TL0 = 0XB0;
         Beep = 1;
         AddTemp = 1;
         LCD_Initial();
         Init_DS18B20();
         temp = ReadTemperature();
         delay_ms(100);
                        LCD_WriteString(0,2,"NowTemp=");
                        LCD_SramChar(8,2,temp%10000/1000+0x30);
                        LCD_SramChar(9,2,temp%1000/100+0x30);
                        LCD_SramChar(10,2,temp%100/10+0x30);
                        LCD_SramChar(11,2,'.');
                        LCD_SramChar(12,2,temp%10+0x30);
                        LCD_SramChar(13,2,'C');
                        SetMode();
                        key_scan();
                        switch(ModeFlag)                //模式选择
                                case 1:        CookRice();break;
                                case 2: CookCong();break;
                                case 3:        CookSoup();break;
                                case 4:        Stewedsoup();break;
                                case 5:        KeepTemp();break;
                                case 6:        SetTime();break;
******         定时器定时部分   ***************
void t0() interrupt 1
         TH0 = 0X3C;
         TL0 = 0XB0;
         count ++;
         if(count >= 20)
                 count = 0;
                sec ++;
                if(sec == 60)
                        sec = 0;
                        minute ++;
                        if(minute == 60)
                                hour ++;
收藏收藏15 分享淘帖 顶1 踩
ID:23640 发表于 2024-5-20 14:37 | 只看该作者
居然没有PID控制
ID:287224 发表于 2024-6-21 11:18 | 只看该作者
有原理图不
ID:482794 发表于 2024-6-26 15:42 | 只看该作者
有图不?
ID:1042173 发表于 2024-7-24 20:44 | 只看该作者
#include "includes.h"这头文件在那?
ID:336378 发表于 2024-12-16 17:24 | 只看该作者
估计不完整的程序,半桶水。
ID:60178 发表于 2025-3-14 04:25 | 只看该作者
没有温度传感器啊
