查看: 1639|回复: 0
HK32单片机按键扫描代码
ID:302293 发表于 2024-5-9 16:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  分高低电平两种
  1. void Keys_Scan_Periodic_Callback(void)
  2. {
  3.   static uint32_t key1_cnt = 0;
  4.   static uint32_t key2_cnt = 0;
  5.   static uint32_t key3_cnt = 0;
  6.   static uint32_t key4_cnt = 0;
  7.
  8.   if((GPIOC->IDR & GPIO_Pin_3) ) //高电平
  9.   {
  10.     key1_cnt ++;
  11.
  12.     if(T_50ms == key1_cnt)
  13.     {
  14.       key1_flag = SET;
  15.     }
  16.
  17.     if(key1_cnt > 0x0FFFFFFF)
  18.     {
  19.       key1_cnt = 0x0FFFFFFF;
  20.     }
  21.   }
  22.   else
  23.   {
  24.     key1_cnt = 0;
  25.   }
  26.
  27.   if( !(GPIOC->IDR & GPIO_Pin_4) )//低电平
  28.   {
  29.     key2_cnt ++;
  30.
  31.     if(T_50ms == key2_cnt)
  32.     {
  33.       key2_flag = SET;
  34.     }
  35.
  36.     if(key2_cnt > 0x0FFFFFFF)
  37.     {
  38.       key2_cnt = 0x0FFFFFFF;
  39.     }
  40.   }
  41.   else
  42.   {
  43.     key2_cnt = 0;
  44.   }
  45.
  46.   if( !(GPIOC->IDR & GPIO_Pin_5) )
  47.   {
  48.     key3_cnt ++;
  49.
  50.     if(T_50ms == key3_cnt)
  51.     {
  52.       key3_flag = SET;
  53.     }
  54.
  55.     if(key3_cnt > 0x0FFFFFFF)
  56.     {
  57.       key3_cnt = 0x0FFFFFFF;
  58.     }
  59.   }
  60.   else
  61.   {
  62.     key3_cnt = 0;
  63.   }
  64.
  65.   if( !(GPIOC->IDR & GPIO_Pin_6) )
  66.   {
  67.     key4_cnt ++;
  68.
  69.     if(T_50ms == key4_cnt)
  70.     {
  71.       key4_flag = SET;
  72.     }
  73.
  74.     if(key4_cnt > 0x0FFFFFFF)
  75.     {
  76.       key4_cnt = 0x0FFFFFFF;
  77.     }
  78.   }
  79.   else
  80.   {
  81.     key4_cnt = 0;
  82.   }
  83. }
  84. void ADC_Scan_Periodic_Callback(void)
  85. {
  86.
  87.         static uint32_t adc_cnt = 0;
  88.   if(ADC1->DR < ADC_Threshold_Value)
  89.   {
  90.     adc_cnt ++;
  91.
  92.     if(T_100ms == adc_cnt)
  93.     {
  94.       acd_power_down_flag = SET;
  95.     }
  96.
  97.     if(adc_cnt > 0x0FFFFFFF)
  98.     {
  99.       adc_cnt = 0x0FFFFFFF;
  100.     }
  101.   }
  102.   else
  103.   {
  104.     adc_cnt = 0;
  105.   }
  106. }
  107. void Key1_Process(void)
  108. {
  109.   if(SET == key1_flag)
  110.   {
  111.     /* Add code here */
  112.
  113. Power_OFF;delay_ms(1000);Power_ON;
  114.     /* code end */
  115.     key1_flag = RESET;
  116.         }else
  117.         Power_ON;
  118. }
  119. void Key2_Process(void)
  120. {
  121.   if(SET == key2_flag)
  122.   {
  123.     /* Add code here */
  124.
  125.
  126.     /* code end */
  127.     key2_flag = SET;
  128.   }
  129. }
  130. void Key3_Process(void)
  131. {
  132.   if(SET == key3_flag)
  133.   {
  134.     /* Add code here */
  135. //    L1_ON;
  136. //                L2_ON;
  137. //    delay_ms(100);
  138. //                L1_OFF;
  139. //                L2_OFF;
  140. //                charge();
  141. //                R1_ON;
  142. //                R2_ON;
  143. //        delay_ms(100);
  144. //                R1_OFF;
  145. //                R2_OFF;
  146. //        charge();
  147.
  148.     /* code end */
  149.     key3_flag = SET;
  150.   }
  151. }
  152. void Key4_Process(void)
  153. {
  154.   if(SET == key4_flag)
  155.   {
  156.     /* Add code here */
  157.
  158.
  159.     /* code end */
  160.     key4_flag = RESET;
  161.   }
  162. }
  163. void Adc_Process(void)
  164. {
  165.   if(SET == acd_power_down_flag)
  166.   {
  167.     /* Add code here */
  168. //    PC7_ON;
  169.
  170.     /* code end */
  171.
  172.     acd_power_down_flag = RESET;
  173.   }
  174. }
原理图: 无
仿真: 无
代码: HK32F030MF4P6_4xKeys_1xADC.7z (171.51 KB, 下载次数: 0)
