查看: 1756|回复: 4
求51单片机的智能台灯的原理图和代码
ID:1121518 发表于 2024-5-22 08:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
由于本论坛禁止直接求程序,禁止伸手党,所以向大家请教一下大致的实现方法与思路,理清头绪后我自己来写程序去实现,谢谢大家
ID:277550 发表于 2024-5-22 15:27 | 只看该作者
你想做到什么程度,调光?  人在灯亮、人走灯灭?湿温度?还想什么功能呢
调光 pwm
自动亮灭,现在使用雷达模块
ID:961114 发表于 2024-5-22 16:02 | 只看该作者
先去学着看懂程序  ,MCU厂家都提供范例程序了  从呼吸灯学起
ID:961114 发表于 2024-5-22 16:03 | 只看该作者
#include "reg51.h"
#include "intrins.h"
#define CYCLE       0x1000
sfr     P_SW2   =   0xba;
sfr     PWMSET      =   0xF1;
sfr     PWMCFG01    =   0xF6;
sfr     PWMCFG23    =   0xF7;
sfr     PWMCFG45    =   0xFE;
#define PWM0C       (*(unsigned int  volatile xdata *)0xFF00)
#define PWM0CH      (*(unsigned char volatile xdata *)0xFF00)
#define PWM0CL      (*(unsigned char volatile xdata *)0xFF01)
#define PWM0CKS     (*(unsigned char volatile xdata *)0xFF02)
#define PWM0TADC    (*(unsigned int  volatile xdata *)0xFF03)
#define PWM0TADCH   (*(unsigned char volatile xdata *)0xFF03)
#define PWM0TADCL   (*(unsigned char volatile xdata *)0xFF04)
#define PWM0IF      (*(unsigned char volatile xdata *)0xFF05)
#define PWM0FDCR    (*(unsigned char volatile xdata *)0xFF06)
#define PWM00T1     (*(unsigned int  volatile xdata *)0xFF10)
#define PWM00T1H    (*(unsigned char volatile xdata *)0xFF10)
#define PWM00T1L    (*(unsigned char volatile xdata *)0xFF11)
#define PWM00T2H    (*(unsigned char volatile xdata *)0xFF12)
#define PWM00T2     (*(unsigned int  volatile xdata *)0xFF12)
#define PWM00T2L    (*(unsigned char volatile xdata *)0xFF13)
#define PWM00CR     (*(unsigned char volatile xdata *)0xFF14)
#define PWM00HLD    (*(unsigned char volatile xdata *)0xFF15)
sfr     P0M1    =   0x93;
sfr     P0M0    =   0x94;
sfr     P1M1    =   0x91;
sfr     P1M0    =   0x92;
sfr     P2M1    =   0x95;
sfr     P2M0    =   0x96;
sfr     P3M1    =   0xb1;
sfr     P3M0    =   0xb2;
sfr     P4M1    =   0xb3;
sfr     P4M0    =   0xb4;
sfr     P5M1    =   0xc9;
sfr     P5M0    =   0xca;
void PWM0_Isr() interrupt 22
    static bit dir = 1;
    static int val = 0;
    if (PWMCFG01 & 0x08)
        PWMCFG01 &= ~0x08;                      //清中断标志
        if (dir)
            val++;
            if (val >= CYCLE) dir = 0;
            val--;
            if (val <= 1) dir = 1;
        _push_(P_SW2);
        P_SW2 |= 0x80;
        PWM00T2 = val;
        _pop_(P_SW2);
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    PWMSET = 0x01;                              //使能PWM0模块(必须先使能模块后面的设置才有效)
    P_SW2 = 0x80;
    PWM0CKS = 0x00;                             // PWM0时钟为系统时钟
    PWM0C = CYCLE;                              //设置PWM0周期
    PWM00T1= 0x0000;
    PWM00T2= 0x0001;
    PWM00CR= 0x80;                              //使能PWM00输出
    P_SW2 = 0x00;
    PWMCFG01 = 0x05;                            //启动PWM0模块并使能PWM0中断
    EA = 1;
    while (1);
ID:1121518 发表于 2024-5-23 21:55 来自触屏版 | 只看该作者
调光 pwm
自动亮灭,现在使用雷 ...
可以调光、可以使用wifi模块连接云智能、人靠近灯亮,没人就灭
