查看: 2141|回复: 0
九齐单片机定时器扫描按键程序
ID:1125252 发表于 2024-6-14 16:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/********************获取按键函数**********************/
unsigned char Get_keynum(void)
    unsigned char temp;
    temp=key_num;
    key_num=0;
    return temp;
unsigned char key_Getnum(void)
    unsigned keynum=0;
    if(K1==0){keynum=1;}
    return keynum;
void key_scan(void)
    static unsigned lastkey,nowkey;
    lastkey=nowkey;
    nowkey=key_Getnum();
    if(lastkey==1 && nowkey==0)
        key_num=1;
}/****************************配置定时器0********************************/
void Timer0_Init(void)
    PCON1 = C_TMR0_Dis;
    //1ms
    //TMRH = 0X30;
    TMR0 = 5;        //计算频率16M/2/2=4M=4000000HZ=4us   4us*(255-5)=1000us
    T0MD = C_PS0_TMR0 | C_PS0_Div2;
    INTE = C_INT_TMR0;
    PCON1 = C_TMR0_En;
#endif
/***************************中断************************************/
void isr(void) __interrupt(0)
    if(INTFbits.PBIF)
        INTFbits.PBIF = 0;                    // Clear PBIF(PortB input change interrupt flag bit)
        INTF= (unsigned char)~(C_INT_PBKey);// Clear PBIF(PortB input change interrupt flag bit)
    if(INTFbits.T0IF)
        tim++;
           if(tim>=25)
               key_scan();
               tim=0;
    INTF= (unsigned char)~(C_INT_TMR0);    // Clear T0IF flag bit
/***************************主函数************************************/
void main(void)
    GPIO_INIT();
    DISI();
    Timer0_Init();
    //Timer1_Init();
    ENI();
    //KEY1_INIT();
        CLRWDT();
        key=Get_keynum();
        if(key==1)
           num++;
           if(num>=10)
                num=0;
        if(num=1){}
        if(num=2){}
收藏收藏2 分享淘帖 顶顶 踩踩
