查看: 1210|回复: 2
能找一下程序哪有问题吗?
ID:1128696 发表于 2024-7-10 20:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include <intrins.h>
#define TM1638_STB P1_2
#define TM1638_DIO P1_0
#define TM1638_CLK P1_1
#define TM1638_CMD_DATA 0x40
#define TM1638_CMD_ADDRESS 0xC0
#define TM1638_CMD_DISPLAY 0x80
#define TM1638_DISPLAY_ON 0x08
#define TM1638_DISPLAY_OFF 0x00
static unsigned char code SEG_PATTERN[] = {
    0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F
void TM1638_Init() {
    TM1638_STB = 1;
    TM1638_SendCommand(TM1638_CMD_DISPLAY | TM1638_DISPLAY_ON);
void TM1638_SendByte(unsigned char data) {
    unsigned char i;
    for (i = 0; i < 8; i++) {
        TM1638_CLK = 0;
        _nop_();
        TM1638_DIO = data & 0x01;
        data >>= 1;
        _nop_();
        TM1638_CLK = 1;
        _nop_();
void TM1638_SendCommand(unsigned char cmd) {
    TM1638_STB = 0;
    _nop_();
    TM1638_SendByte(cmd);
    TM1638_STB = 1;
    _nop_();
void TM1638_DisplayDigit(unsigned char digit, unsigned char num) {
    TM1638_SendCommand(TM1638_CMD_ADDRESS | (digit << 1));
    TM1638_STB = 0;
    _nop_();
    TM1638_SendByte(TM1638_CMD_DATA);
    TM1638_SendByte(SEG_PATTERN[num % 10]);
    TM1638_STB = 1;
void Delay50ms() {
    unsigned char i, j;
    for (i = 0; i < 90; i++) {
        for (j = 0; j < 163; j++);
void main() {
    unsigned int count = 0;
    unsigned char btn_status = 0;
    TM1638_Init();
    while (1) {
        TM1638_DisplayDigit(0, count % 10);
        TM1638_DisplayDigit(1, (count / 10) % 10);
        TM1638_DisplayDigit(2, (count / 100) % 10);
        TM1638_DisplayDigit(3, (count / 1000) % 10);
        btn_status = TM1638_ReadButtons();
        if (btn_status & 0x01) {
            Delay50ms();
            while (btn_status & 0x01);
            Delay50ms();
            count++;
        if (btn_status & 0x02) {
            Delay50ms();
            while (btn_status & 0x02);
            Delay50ms();
            count--;
        Delay50ms();
unsigned char TM1638_ReadButtons() {
    unsigned char i, btns = 0;
    TM1638_SendCommand(TM1638_CMD_ADDRESS | 0x02);
    TM1638_STB = 0;
    _nop_();
    TM1638_SendByte(0x42);
    _nop_();
    for (i = 0; i < 4; i++) {
        btns |= TM1638_DIO << i;
        TM1638_CLK = 0;
        _nop_();
        TM1638_CLK = 1;
        _nop_();
    TM1638_STB = 1;
    return btns;
ID:161164 发表于 2024-7-10 21:04 | 只看该作者
P1_2/P1_0/P1_1没有定义
ID:1109793 发表于 2024-7-11 07:15 | 只看该作者
编译时显示什么内容?不过那三个IO是不是应该用sbit,而不是define
