查看: 1360|回复: 7
stm32串口DMA问题
ID:929517 发表于 2024-7-14 16:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近在学习串口的DMA接收,发现一个问题,就是RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); 这条时钟无论是否开启,都能正常接收,有没有高手能解释下这条语句。具体程序我压缩包上传,经过测试串口助手是可以发送并将收到的信息发回。请大师们指正,这个工程未完工,阶段测试可以。
void Serial_Init(void)
        GPIO_InitTypeDef GPIO_InitStructure;
  USART_InitTypeDef USART_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  DMA_InitTypeDef DMA_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
//  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);// ???
  USART_DeInit(USART1);  //复位串口1
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  //Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子优先级3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
  //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_Init(USART1, &USART_InitStructure); //初始化串口
  USART_ITConfig(USART1, USART_IT_IDLE, ENABLE);//开启空闲中断
  USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);   //使能串口1 DMA接收
  USART_Cmd(USART1,ENABLE);                    //使能串口
  DMA_DeInit(DMA1_Channel5);   //将DMA的通道5寄存器重设为缺省值  串口1对应的是DMA通道5
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&USART1->DR;  //DMA外设ADC基地址
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)DMA_RX_Buf;  //DMA内存基地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //数据传输方向,从外设读取发送到内存
  DMA_InitStructure.DMA_BufferSize = DMA_Max_Size;  //DMA通道的DMA缓存的大小
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外设地址寄存器不变
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址寄存器递增
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;  //数据宽度为8位
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //数据宽度为8位
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;  //工作在正常缓存模式
  DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x拥有中优先级
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
  DMA_Init(DMA1_Channel5, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道
  USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);
  DMA_Cmd(DMA1_Channel5, ENABLE);  //正式驱动DMA传输
未完工的DMA.zip
323.42 KB, 下载次数: 2
ID:267719 发表于 2024-7-16 15:13 | 只看该作者
引脚复用 进行重映射时 需要开启AFIO 时钟。你没有remap,所以没有必要开启。
ID:929517 发表于 2024-7-16 15:42 | 只看该作者
PA9 PA10用作串口 不算引脚复用吗?
ID:267719 发表于 2024-7-18 10:04 | 只看该作者
没有重新映射,没有用到remap
ID:267719 发表于 2024-7-18 10:25 | 只看该作者
当把 GPIO 用作 EXTI 外部中断或使用重映射功能的时候,必须开启 AFIO 时钟,而在使用默认复用功能的时候,就不必开启 AFIO 时钟了。
ID:267719 发表于 2024-7-18 10:53 | 只看该作者
当把 GPIO 用作 EXTI 外部中断或使用重映射功能的时候,必须开启 AFIO 时钟,而在使用默认复用功能的时候,就不必开启 AFIO 时钟了。PA9 PA10用作串口算默认复用功能,所以不必开启AFIO 时钟。
ID:1043262 发表于 2024-7-18 12:09 | 只看该作者
那个引脚IO本来就有串口的功能,AFIO一般用于引脚复用的,我个人是这么理解的
ID:929517 发表于 2024-7-18 15:27 | 只看该作者
懂了 谢谢
