查看: 2214|回复: 0
TLC5620 DA芯片使用说明
ID:830387 发表于 2024-8-29 09:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TLC5620 是TI出品的四路DA输出芯片,以下是其驱动代码,供参考。
#define TLC5620Data_Pin GPIO_PIN_3
#define TLC5620Data_GPIO_Port GPIOE
#define TLC5620CLK_Pin GPIO_PIN_4
#define TLC5620CLK_GPIO_Port GPIOE
#define TLC5620LODA_Pin GPIO_PIN_5
#define TLC5620LODA_GPIO_Port GPIOE
#define TLC5620LDAC_Pin GPIO_PIN_6
#define TLC5620LDAC_GPIO_Port GPIOE
#define MinZFLimit                        2
#define ZhenFuRange                        200
uint16_t ZhenFuBuffer[4];
void ZhenFuAdjust(uint8_t channel)
    uint8_t zhenfu,a;
    zhenfu=(uint8_t)(MinZFLimit+ZhenFuBuffer[channel]*ZhenFuRange/100);//Count zhenfu----
    HAL_GPIO_WritePin(TLC5620LODA_GPIO_Port,TLC5620LODA_Pin,GPIO_PIN_SET);
    HAL_GPIO_WritePin(TLC5620LDAC_GPIO_Port,TLC5620LDAC_Pin,GPIO_PIN_SET);
    //A1---------------------------------------------------------------------------------
    HAL_GPIO_WritePin(TLC5620CLK_GPIO_Port,TLC5620CLK_Pin,GPIO_PIN_SET);
    if((channel&0x02)==0x02)
        HAL_GPIO_WritePin(TLC5620Data_GPIO_Port,TLC5620Data_Pin,GPIO_PIN_SET);
        HAL_GPIO_WritePin(TLC5620Data_GPIO_Port,TLC5620Data_Pin,GPIO_PIN_RESET);
    HAL_GPIO_WritePin(TLC5620CLK_GPIO_Port,TLC5620CLK_Pin,GPIO_PIN_RESET);
    //A0---------------------------------------------------------------------------------
    if((channel&0x01)==0x01)
    //REN---------------------------------------------------------------------------------
    HAL_GPIO_WritePin(TLC5620Data_GPIO_Port,TLC5620Data_Pin,GPIO_PIN_SET);//1
    //HAL_GPIO_WritePin(TLC5620Data_GPIO_Port,TLC5620Data_Pin,GPIO_PIN_RESET);//0
    //for(a=0;a<8;a++)HAL_GPIO_WritePin(TLC5620CLK_GPIO_Port,TLC5620CLK_Pin,GPIO_PIN_RESET);//delay
    for(a=0;a<8;a++)
        if((zhenfu&0x80)==0x80)
        zhenfu<<=1;
    HAL_GPIO_WritePin(TLC5620LODA_GPIO_Port,TLC5620LODA_Pin,GPIO_PIN_RESET);
    HAL_GPIO_WritePin(TLC5620LDAC_GPIO_Port,TLC5620LDAC_Pin,GPIO_PIN_RESET);
void main ()
{   ZhenFuBuffer[0]=32;
   ZhenFuAdjust(0);   ZhenFuBuffer[1]=64;
   ZhenFuAdjust(1);   ZhenFuBuffer[2]=96;
   ZhenFuAdjust(2);
   ZhenFuBuffer[3]=128;
   ZhenFuAdjust(3);
