查看: 1448|回复: 4
求大神帮我改改这个程序
ID:78901 发表于 2024-11-6 23:02 | 显示全部楼层 |阅读模式
// Main.c
// Copyright (C) 2013 Shenyang JYXD.
// WEN BO RUI
// Tool chain: KEIL Full c
//#pragma CD OE DB SB // Compilation directives
#include <STC8G.H>
#include <intrins.h>
//#include
//#include
uint Period; //Period刷新周期
uint PWM;
uint Pulse; //脉冲个数
uchar Speed; //速度变量
uchar count;
uint excount;
bit Gra; //渐变/跳变总控制位
bit Gra7; //七彩渐亮渐灭控制位
bit Gra3; //红绿蓝渐亮渐灭控制位
bit BP; //亮到暗,暗到亮转换位
bit LEDdelay ; //LED定时到标志位
sbit key1 = P3^1; //花样组合键
sbit key2 = P3^5; //速度组合键
uchar led1[12]={0x10,0x030,0x20,0x60,0x40,0x50,0x70,0x50,0x40,0x60,0x20,0x30};//红、黄、绿、青、蓝、粉、白、粉、蓝、青、绿、黄
uchar led2[24]={0x10,0x00,0x30,0x00,0x20,0x00,0x60,0x00,0x40,0x00,0x50,0x00,
0x70,0x00,0x50,0x00,0x40,0x00,0x60,0x00,0x20,0x00,0x30,0x00};
uchar led3[3]={0x10,0x20,0x40}; //红、绿、蓝
uchar ledcount,ledcount1;
//以下定义函数
// 1毫秒延时函数delayms();花样及速度扫描函数keyscan();
/*void delayms(unsigned int ms)
unsigned char i ;
while(ms--)
for(i = 0 ; i < 120 ; i++) ;
void Pattern1(); //花样1函数--------->跳变无灭灯过程
void Pattern2(); //花样2函数--------->跳变有灭灯过程
void Pattern34();
void keyscan()
if(k1 = 0) {Speed = 20;Period = 25;} //预设4种速度200MS
if(k1 = 1) {Speed = 50;Period = 50;} //500MS
if(k1 = 2) {Speed = 100;Period = 100;} //1S
if(k1 = 3) {Speed = 150;Period = 200;} //1.5S
if(k2 = 0) {ledcount1 = 0;Pattern1();} //预设4种花样
if(k2 = 1) {ledcount1 = 0;Pattern2();}
if(k2 = 2) {ledcount = 0;Gra3 = 1;Pattern34();}
if(k2 = 3) {ledcount = 0;Gra7 = 1;Pattern34();}
void value()
if(Speed == 20) PWM = Pulse*8;
if(Speed == 50) PWM = Pulse*4; //脉冲个数
if(Speed == 100)PWM = Pulse*2;
if(Speed == 150)PWM = Pulse;
void Reset(void)
unsigned char code rst[ ]={0xe4,0xc0,0xe0,0xc0,0xe0,0x32};
(*((void (*)(void))(rst)))();
_nop_ ();
_nop_ ();
_nop_ ();
P1 = 0;
TMOD = 0x11; //11.0592M晶振的10ms定时初值(100分之一秒)
TH0 = 0x0db;
TL0 = 0x0ff;
TH1 = 0x0ff; //0.05ms(20000分之一秒)
TL1 = 0x0D1;
EA = 1; //开启总中断允许
ET0 = 1; //允许T0定时器中断
ET1 = 1; //允许T1定时器中断
TR0 = 1; //开启T0定时器
EX0=1; //开外部中断0
IT0=1; //下降沿触发
keyscan();
//Pattern1() 花样函数1-------------跳变无灭灯过程
void Pattern1()
//keyscan();
Gra = 0; //跳变位=0
if(LEDdelay)
LEDdelay = 0;
P1 = led1[ledcount];
ledcount++;
if(ledcount>11)
ledcount = 0;
//Pattern2() 花样函数2-------------跳变有灭灯过程
void Pattern2()
keyscan();
Gra = 0;
if(LEDdelay)
LEDdelay = 0;
P1 = led2[ledcount];
ledcount++;
if(ledcount>23)
ledcount = 0;
//Pattern3() 花样函数3-------------3彩渐变
void Pattern3()
keyscan();
if(Speed == 20) Period = 25;
if(Speed == 50) Period = 50;
if(Speed == 100)Period = 100;
if(Speed == 150)Period = 200;
Gra = 1;
Gra3 = 1;
//Pattern4() 花样函数4-------------7彩渐变
void Pattern34()
Gra = 1; //渐变位 = 1
// 定时器0中断服务程序
void time0(void) interrupt 1
TR1 =0;
TF0 =0;
TH0=0xdb; //重新写入初值
TL0=0xff;
if(!Gra) //执行跳变程序
count ++;
if(count > Speed)
LEDdelay = 1;
count = 0;
if(Gra)
TR1 = 1; //开启TR1;
if(!BP) //
if(Gra7)
P1 = led1[ledcount1]; //10ms到,亮相应的LED
if(Gra3)
P1 = led3[ledcount1]; //10ms到,亮相应的LED
Pulse++;
value();
if(Pulse >= Period)
Pulse = Period;
BP = 1; //一个周期完成转换模式
if(BP)
if(Gra7)
if(Gra3)
value();
Pulse--; //脉冲个数
if(Pulse == 0)
Pulse = 0;
BP = 0; //一个周期完成转换模式
ledcount1++;
if(Gra7)
if(ledcount1 > 11)
ledcount1 = 0;
Gra7 = 0;
if(Gra3)
if(ledcount1 > 2)
ledcount1 = 0;
Gra3 = 0;
// 定时器1中断服务程序
void timer1() interrupt 3
PWM --;
TH1 = 0xff; //0.05ms(20000分之一秒)
TL1 = 0xD1;
if(PWM == 0)
P1 = 0;
TR1 = 0;
// 外部中断0中断服务程序 下降沿触发
void extern0(void) interrupt 0
IE0 = 0; // 清标志位
excount++;
if(excount>50) // 50大约3秒
EA = 0;
//P1_5 = 1;
excount = 0;
Reset();
ID:161164 发表于 2024-11-7 09:39 | 显示全部楼层
什么乱七八糟的代码?
ID:404160 发表于 2024-11-7 11:05 | 显示全部楼层
```c
// Main.c
// WEN BO RUI
#include <STC8G.H>
// 全局变量定义
uint Period; // 刷新周期
uint PWM;
uint Pulse; // 脉冲个数
uchar Speed; // 速度变量
uchar count;
uint excount;
bit Gra; // 渐变/跳变总控制位
bit Gra7; // 七彩渐亮渐灭控制位
bit Gra3; // 红绿蓝渐亮渐灭控制位
bit BP; // 亮到暗,暗到亮转换位
bit LEDdelay; // LED定时到标志位
sbit key1 = P3^1; // 花样组合键
sbit key2 = P3^5; // 速度组合键
// LED灯光模式数组
uchar led1[12] = {0x10, 0x30, 0x20, 0x60, 0x40, 0x50, 0x70, 0x50, 0x40, 0x60, 0x20, 0x30}; // 红、黄、绿、青、蓝、粉、白、粉、蓝、青、绿、黄
uchar led2[24] = {0x10, 0x00, 0x30, 0x00, 0x20, 0x00, 0x60, 0x00, 0x40, 0x00, 0x50, 0x00,
                  0x70, 0x00, 0x50, 0x00, 0x40, 0x00, 0x60, 0x00, 0x20, 0x00, 0x30, 0x00};
uchar led3[3] = {0x10, 0x20, 0x40}; // 红、绿、蓝
uchar ledcount, ledcount1;
// 函数声明
void keyscan(void);
void value(void);
void Reset(void);
void Pattern1(void);
void Pattern2(void);
void Pattern34(void);
// 主函数
void main() {
    P1 = 0;
    TMOD = 0x11; // 11.0592M晶振的10ms定时初值
    TH0 = 0x0DB;
    TL0 = 0x0FF;
    TH1 = 0x0FF; // 0.05ms定时初值
    TL1 = 0xD1;
    EA = 1; // 开启总中断
    ET0 = 1; // 允许T0定时器中断
    ET1 = 1; // 允许T1定时器中断
    TR0 = 1; // 开启T0定时器
    EX0 = 1; // 开外部中断0
    IT0 = 1; // 下降沿触发
    while (1) {
        keyscan(); // 持续扫描键盘
// 键盘扫描函数
void keyscan(void) {
    // 使用'=='进行比较,而不是'='赋值操作符
    if (key1 == 0) { Speed = 20; Period = 25; }
    else if (key1 == 1) { Speed = 50; Period = 50; }
    else if (key1 == 2) { Speed = 100; Period = 100; }
    else if (key1 == 3) { Speed = 150; Period = 200; }
    if (key2 == 0) { ledcount1 = 0; Pattern1(); }
    else if (key2 == 1) { ledcount1 = 0; Pattern2(); }
    else if (key2 == 2) { ledcount = 0; Gra3 = 1; Pattern34(); }
    else if (key2 == 3) { ledcount = 0; Gra7 = 1; Pattern34(); }
// 计算PWM值
void value(void) {
    switch (Speed) {
        case 20: PWM = Pulse * 8; break;
        case 50: PWM = Pulse * 4; break;
        case 100: PWM = Pulse * 2; break;
        case 150: PWM = Pulse; break;
        default: PWM = 0; break;
// 花样1函数 - 跳变无灭灯过程
void Pattern1(void) {
    Gra = 0; // 跳变位=0
    if (LEDdelay) {
        LEDdelay = 0;
        ledcount = (ledcount + 1) % 12; // 循环计数
// 花样2函数 - 跳变有灭灯过程
void Pattern2(void) {
    Gra = 0;
    if (LEDdelay) {
        LEDdelay = 0;
        ledcount = (ledcount + 1) % 24; // 循环计数
// 花样3和4函数 - 渐变
void Pattern34(void) {
    Gra = 1;
// 重置函数
void Reset(void) {
    unsigned char code rst[] = {0xe4, 0xc0, 0xe0, 0xc0, 0xe0, 0x32};
    ((void (*)(void))(rst))();
// 定时器0中断服务程序
void time0(void) interrupt 1 {
    TR1 = 0;
    TF0 = 0;
    TH0 = 0xDB;
    TL0 = 0xFF;
    if (!Gra) { // 执行跳变程序
        count++;
        if (count > Speed) {
            LEDdelay = 1;
            count = 0;
    } else {
        TR1 = 1;
        if (!BP) {
            P1 = Gra7 ? led1[ledcount1] : led3[ledcount1];
            Pulse++;
            value();
            if (Pulse >= Period) {
                Pulse = Period;
                BP = 1;
        } else {
            value();
            Pulse--;
            if (Pulse == 0) {
                Pulse = 0;
                BP = 0;
                ledcount1 = (ledcount1 + 1) % (Gra7 ? 12 : 3);
                Gra7 = 0;
                Gra3 = 0;
// 定时器1中断服务程序
void timer1(void) interrupt 3 {
    PWM--;
    TH1 = 0xFF;
    TL1 = 0xD1;
    if (PWM == 0) {
        P1 = 0;
        TR1 = 0;
void extern0(void) interrupt 0 {
    IE0 = 0;
    excount++;
    if (excount > 50) { // 50大约3秒
        EA = 0;
        excount = 0;
        Reset();
### 优化内容和逻辑错误检查:
1. **比较操作符错误**:原代码中使用了赋值操作符`=`而不是比较操作符`==`,这会导致逻辑错误。已修正。
2. **循环计数**:使用取模运算符`%`来实现循环计数,避免数组越界。
3. **代码结构**:将全局变量和函数声明分开,提高代码可读性。
4. **条件判断**:优化了条件判断逻辑,使其更加清晰。
5. **定时器中断服务程序**:优化了定时器中断服务程序中的逻辑,使其更加简洁和易于理解。
6. **外部中断服务程序**:优化了外部中断服务程序,使其逻辑更加清晰。
7. **代码风格**:统一了代码风格,提高了代码的可读性。
ID:78901 发表于 2024-11-7 12:11 | 显示全部楼层
以下是对这段 C 语言代码的分析:
一、代码功能概述
这段代码是用 C 语言编写的,用于控制某种 LED 灯的显示模式和速度。主要功能包括以下几个方面:
通过不同的函数实现多种 LED 显示花样,如跳变无灭灯过程(Pattern1)、跳变有灭灯过程(Pattern2)、三彩渐变(Pattern3)和七彩渐变(Pattern4,Pattern34 可实现七彩渐变和三彩渐变)。
可以通过按键(key1 和 key2)选择不同的速度和花样组合。
使用定时器中断(T0 和 T1)来控制 LED 的显示时间和渐变效果,外部中断(INT0)用于系统复位。
二、主要变量和宏定义
Period:刷新周期变量,用于控制 LED 渐变或跳变的速度。
PWM:脉冲宽度调制变量,可能用于控制 LED 的亮度。
Pulse:脉冲个数变量,在渐变过程中用于控制 LED 的亮度变化。
Speed:速度变量,通过按键设置不同的值来改变 LED 显示的速度。
count、excount、ledcount、ledcount1:用于各种计数目的的变量。
Gra、Gra7、Gra3、BP、LEDdelay:标志位变量,用于控制渐变、七彩渐变、三彩渐变、亮暗转换以及 LED 定时标志。
key1和key2:定义为连接到 P3.1 和 P3.5 的按键。
led1、led2、led3:分别是不同花样的 LED 显示数据数组。
三、函数分析
delayms(unsigned int ms):注释掉的函数,可能是一个毫秒延时函数。
Pattern1():实现跳变无灭灯过程的花样函数。当LEDdelay标志位为真时,切换到下一个 LED 颜色显示,循环显示led1数组中的颜色。
Pattern2():实现跳变有灭灯过程的花样函数。与Pattern1()类似,但使用led2数组进行显示。
Pattern34():可以根据Gra7和Gra3标志位分别实现七彩渐变和三彩渐变。
keyscan():扫描按键状态,根据按键key1和key2的状态设置速度和选择不同的花样函数。
value():根据Speed的值设置PWM变量,可能用于控制 LED 的亮度。
Reset(void):系统复位函数,通过执行一段特定的代码来实现系统复位。
main():主函数,初始化定时器、中断和端口,然后进入一个无限循环,在循环中调用keyscan()函数扫描按键状态。
time0(void) interrupt 1:定时器 0 中断服务程序,根据Gra标志位执行不同的操作。如果Gra为假,执行跳变程序;如果Gra为真,根据BP标志位进行 LED 的渐变操作。
timer1() interrupt 3:定时器 1 中断服务程序,用于控制PWM变量递减,当PWM为 0 时关闭 LED。
extern0(void) interrupt 0:外部中断 0 中断服务程序,用于系统复位。当检测到下降沿触发时,计数变量excount递增,当excount大于 50(大约 3 秒)时,关闭总中断,执行系统复位操作。
四、代码执行流程
在main()函数中,进行初始化操作,包括设置端口状态、定时器模式、中断允许等。
进入无限循环,在循环中调用keyscan()函数扫描按键状态,根据按键选择不同的速度和花样。
当定时器 0 中断发生时,根据Gra标志位执行不同的操作。如果是跳变模式,根据count变量控制 LED 的跳变速度;如果是渐变模式,开启定时器 1,并根据BP标志位进行 LED 的渐变操作。
当定时器 1 中断发生时,递减PWM变量,当PWM为 0 时关闭 LED。
当外部中断 0 中断发生时,计数变量excount递增,当excount大于 50 时,执行系统复位操作。
五、总结
这段代码实现了一个较为复杂的 LED 控制程序,通过按键选择不同的速度和花样,利用定时器中断实现 LED 的跳变和渐变效果,同时还提供了系统复位功能。代码中使用了多个标志位和数组来控制 LED 的显示,需要仔细理解各个变量和函数的作用,以便更好地进行调试和扩展。
ID:78901 发表于 2024-11-7 20:06 | 显示全部楼层
谢谢坛友飞云居士 指导
