查看: 2002|回复: 5
单片机与pc串口通信,虚拟端口发送1接收却显示q,发送2接收显示r,求大佬帮帮
#include <REGX51.H>
sbit RS = P2^0;
sbit RW = P2^1;
sbit E = P2^2;
sbit KEY = P3^7;
uchar received_data;
void delayms(uint ms)
    uchar i;
    while (ms--)
        for (i = 0; i < 123; i++);
void w_com(uchar com)
    RS = 0;
    RW = 0;
    E = 1;
    P0 = com;
    E = 0;
    delayms(1);
void w_dat(uchar dat)
    RS = 1;
    RW = 0;
    E = 1;
    P0 = dat;
    E = 0;
    delayms(1);
void lcd_ini(void)
    delayms(10);
    w_com(0x38);
    delayms(10);
    w_com(0x0c);
    delayms(10);
    w_com(0x06);
    delayms(10);
    w_com(0x01);
    delayms(10);
    w_com(0x80);
    delayms(10);
void send_data(uchar data_to_send)
    SBUF = data_to_send;
    while (TI == 0);
    TI = 0;
void uart_init()
    // 9600bps 11.0592MHz
    SCON = 0x50;
    TMOD &= 0x0F;
    TMOD |= 0x20;
    TL1 = 0xFD;
    TH1 = 0xFD;
    ET1 = 0;
    TR1 = 1;
    EA = 1;
    ES = 1;
    uchar data_to_send[8] = "12345678";
    uchar i;
    lcd_ini();
    uart_init();
    while (1)
        if (KEY == 0)
            delayms(20);
            if (KEY == 0)
                for (i = 0; i < 8; i++)
                    send_data(data_to_send[ i]);
                while (KEY == 0);
void uart_interrupt() interrupt 4
    if (RI)
        RI = 0;
        received_data = SBUF;
        w_dat(received_data);
仿真图
仿真图
ID:860926 发表于 2024-12-18 08:27 | 只看该作者
发送的字符 +0x30 试试
ID:294886 发表于 2024-12-18 09:28 | 只看该作者
两边的格式不一样吧,都设置成16进制看看
ID:275826 发表于 2024-12-18 15:34 | 只看该作者
单片机与虚拟终端是同一个设备
ID:161164 发表于 2024-12-19 11:50 | 只看该作者
检查一下单片机晶振设置,如果也是11.0592Mhz
那就可能是电脑太慢引致仿真速度不匹配现实
ID:30165 发表于 2024-12-28 17:26 | 只看该作者
ASCII码  0 的ASCII码是 0X30  你发送 1   实际发送(1+0x30)试试
