查看: 742|回复: 0
单片机的指纹密码锁出错
做一个指纹密码锁,仿真方面老是出错,液晶也不显示字幕,是哪里的问题,恳请各位老师指出,程序如下:
#include <reg52.h>
#include <intrins.h>
#include"24C0x.h"
#include"LCD12864.h"
#define buffer1ID  0x01
#define buffer2ID  0x02
#define queren  0x88
#define tuichu  0x18
#define shanchu 0x82
#define User 1
void fan();
sbit B0=B^0;
sbit B7=B^7;
sbit k2=P3^7;
sbit jidianqi=P3^6;
sbit BUZZ=P2^0;
//extern unsigned char times[];
uchar  Member=1,sec;
uchar ERROR_TIME=0;
uchar  code buffer[User][6]=
{"000000"}
bit succeed_mm=0;
bit count_down=0;
bit alarm=0;
uchar dz[4];
uchar time[4];
uchar mima[6];
uchar mima_kai[6];
uchar mimag[6];
uchar mimaID[6]={1,2,3,4,5,6};
uchar out_time=0;
uchar Address1=20,tempx=20;
uchar Address2=20;
uchar data K;
uchar data Key;
uint PageID;
uchar data querenma=11;
uchar sum[2];
int summaf,summas;
uchar  xdata UserPassword[2][7]={0};//ÃÜÂë                0ÊǹÜÀíÔ±ÃÜÂ룬1ÊÇ¿ªËøÃÜÂë
uchar  xdata DSY_BUFFER[16] ={0};//»º´æ
void Red_Init(void);
//¼ì²âÂö³å¿í¶È
unsigned char check(void);
unsigned char redchange(unsigned char rednum);
void delayms(unsigned int z)
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
* Ãû³Æ : Chack(uchar User_Number)
* ¹¦ÄÜ : µ¥Ò»Óû§ÃÜÂë¼ì²â
* ÊäÈë : User_Number
* Êä³ö : ÃÜÂëÕýÈ·Óë´íÎ󣬴íÎó·µ»Ø0£¬ÕýÈ··µ»Ø1
uchar Chack(uchar User_Number)
        uchar flag, i,temp[6],Address;
        Address=User_Number*6;
        for(i=0;i<6;i++)
                temp=x24c02_read(Address);
                delayms(10);
                Address++;
        for(i=0;i<6;i++)
                if(temp==UserPassword[User_Number])
                        flag=1;
                         flag=0;
                        break;
//        flag=1;
                return flag;
* Ãû³Æ : PassWord_Chack()
* ¹¦ÄÜ : ËùÓÐÓû§ÃÜÂë¼ì²â
* ÊäÈë : ÎÞ
/*uchar PassWord_Chack()
        uchar i=0;
        while(i<User)
                if(Chack(i)==1)
                        Member=i+1;
                        return 1;
                i++;
        return 0;
* ÊäÈë : ÎÞ
/*uchar kaiPassWord_Chack()
        uchar i=1;
        while(i<superUser)
                if(kaiChack(i)==1)
        //                Member=i+1;
                        return 1;
                i++;
        return 0;
void delay(uint tt)
{  uchar i;
   while(tt--)
   for(i=0;i<125;i++);
* Ãû³Æ : UART_Init()
* ¹¦ÄÜ : µ¥Æ¬»ú´®¿Ú³õʼ»¯
* µ¥Æ¬»ú£º¾§Õñ11.0592MHz ²¨ÌØÂÊΪ9600bps
* Ö¸ÎÆÄ£¿é£º²¨ÌØÂÊΪ9600bps£¬
void UART_Init()
        SCON= 0x50;               //´®¿Ú·½Ê½1        //REN=1; ÔÊÐí½ÓÊÕ
        PCON=0x00;                //SMOD=0
        TMOD= 0x21;               //¶¨Ê±Æ÷1¶¨Ê±·½Ê½2
        TH1= 0xFD;                //11.0592MHz  Ä£¿éĬÈϲ¨ÌØÂÊΪ9600bps
        TL1= 0xFD;
        TR1= 1;                   //Æô¶¯¶¨Ê±Æ÷
        TH0=0x4b;
        TL0=0xff;
        ET0=1;
        TR0=1;
        EA=1;
unsigned char Keycan(void) //°´¼üɨÃè³ÌÐò P1.0--P1.3ΪÐÐÏß P1.4--P1.7ΪÁÐÏß
  unsigned char rcode, ccode;
  P1 = 0xF0;      // ·¢È«0ÐÐɨÃèÂ룬ÁÐÏßÊäÈë
  if((P1&0xF0) != 0xF0) // ÈôÓмü°´ÏÂ
    delay(1);// ÑÓʱȥ¶¶¶¯
    {  rcode = 0xFE;         // ÖðÐÐɨÃè³õÖµ
    while((rcode&0x10) != 0)
       P1 = rcode;         // Êä³öÐÐɨÃèÂë
      if((P1&0xF0) != 0xF0) // ±¾ÐÐÓмü°´ÏÂ
       ccode = (P1&0xF0)|0x0F;
           BUZZ=0;
           delayms(20);
           BUZZ=1;
       //do{;}
           while((P1&0xF0) != 0xF0); //µÈ´ý¼üÊÍ·Å
       return ((~rcode) + (~ccode)); // ·µ»Ø¼ü±àÂë
    rcode = (rcode<<1)|0x01; // ÐÐɨÃèÂë×óÒÆÒ»Î»
  return 0; // ÎÞ¼ü°´Ï£¬·µ»ØÖµÎª0
void KeyDeal(unsigned char Key)
{  //unsigned char n;
   if(Key!=0)
                   switch(Key)
                   case 0x11: K=1; break;
                   case 0x21: K=2; break;
                   case 0x41: K=3; break;
                   case 0x81:  break;
                   case 0x12: K=4; break;
                   case 0x22: K=5; break;
                   case 0x42: K=6; break;
                   case 0x82: K=34;break;        //ɾ³ý
                   case 0x14: K=7; break;
                   case 0x24: K=8; break;
                   case 0x44: K=9; break;
                   case 0x84:  break;                 //ÊäÈë¿ªËøÃÜÂë
                   case 0x18: K=35; break;        //Í˳ö
                   case 0x28: K=0; break;
                   case 0x48:  K=11; break;
                   case 0x88:  break;
                   default: break;
void SFG_GetEcho()                              //ÎÕÊÖ
   uchar i;
   SBUF=0xef;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0X03;
   while(TI==0);
   TI=0;
   SBUF=0X53;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   summaf=0x57;
   SBUF=summaf;
   while(TI==0);
   TI=0;
   for(i=0;i<9;i++)
    while(RI==0);
    RI=0;}
   while(RI==0);
   RI=0;
   querenma=SBUF;
   while(RI==0);
   RI=0;
   sum[1]=SBUF;
   while(RI==0);
   RI=0;
   sum[0]=SBUF;
   summas=(sum[1]<<8)+sum[0];
void SFG_getimage()                              //¼ÈëÖ¸ÎÆÍ¼Ïñ
   uchar i;
   SBUF=0xef;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0X03;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   summaf=0x05;
   SBUF=summaf;
   while(TI==0);
   TI=0;
   for(i=0;i<9;i++)
    while(RI==0);
    RI=0;}
   while(RI==0);
   RI=0;
   querenma=SBUF;
   while(RI==0);
   RI=0;
   sum[1]=SBUF;
   while(RI==0);
   RI=0;
   sum[0]=SBUF;
void SFG_genchar(uchar bufferID) //Éú³ÉÌØÕ÷²¢´æÓÚcharbuffer1/2  µ÷ÓÃºóµ¥Æ¬»ú²¨ÌØÂʱ仯@@@
   uchar i;
   SBUF=0xef;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0X04;
   while(TI==0);
   TI=0;
   SBUF=0X02;
   while(TI==0);
   TI=0;
   SBUF=bufferID;
   while(TI==0);
   TI=0;
   summaf=0x07+bufferID;
   sum[0]=summaf;
   sum[1]=summaf>>8;
   SBUF=sum[1];
   while(TI==0)
   TI=0;
   SBUF=sum[0];
   while(TI==0)
   TI=0;
   for(i=0;i<9;i++)
    while(RI==0);
    RI=0;}
   while(RI==0);
   RI=0;
   querenma=SBUF;
   while(RI==0);
   RI=0;
   sum[1]=SBUF;
   while(RI==0);
   RI=0;
   sum[0]=SBUF;
void SFG_fastsearch(uchar bufferID)  //ËÑË÷Ö¸ÎÆ·µ»ØÖ¸ÎÆIDºÅ   sum¡¢pagenum>255¶¼»áʹ³ÌÐò¿¨@@@
   uchar i,ID1,ID2;
   SBUF=0xef;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0X08;
   while(TI==0);
   TI=0;
   SBUF=0X1b;
   while(TI==0);
   TI=0;
   SBUF=bufferID;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=180;
   while(TI==0);
   TI=0;
   summaf=9+0x1b+bufferID+180;
   sum[0]=summaf;
   sum[1]=summaf>>8;
   SBUF=sum[1];
   while(TI==0);
   TI=0;
   SBUF=sum[0];
   while(TI==0);
   TI=0;
   for(i=0;i<9;i++)
    while(RI==0);
    RI=0;}
   while(RI==0);
   RI=0;
   querenma=SBUF;
   while(RI==0);
   RI=0;
   ID1=SBUF;
   while(RI==0);
   RI=0;
   ID2=SBUF;                                  //½ÓÊÕµ½µÄIDºÅ
   while(RI==0);
   RI=0;
   while(RI==0);
   RI=0;
   while(RI==0);
   RI=0;
   sum[1]=SBUF;
   while(RI==0);
   RI=0;
   sum[0]=SBUF;
   //PageID=ID1;
   PageID=(ID1<<8)+ID2;
void SFG_enroll()                                 //×Ô¶¯×¢²áÄ£°å·µ»Ø´æ´¢ID  =¼ͼÏñ+ºÏ²¢Éú³ÉÄ£°å+´¢´æÄ£°å
   uchar i,ID1,ID2;
   SBUF=0xef;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0X03;
   while(TI==0);
   TI=0;
   SBUF=0X10;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   summaf=0x14;
   SBUF=summaf;           //УÑéºÍ
   while(TI==0);
   TI=0;
   for(i=0;i<9;i++)
    while(RI==0);
    RI=0;}
   while(RI==0);
   RI=0;
   querenma=SBUF;
   while(RI==0);
   RI=0;
   ID1=SBUF;
   while(RI==0);
   RI=0;
   ID2=SBUF;
   while(RI==0);
   RI=0;
   sum[1]=SBUF;
   while(RI==0);
   RI=0;
   sum[0]=SBUF;
   //PageID=ID1;
void SFG_deletchar(uint pageID)   //ɾ³ýÖ¸ÎÆ                     Ð£ÑéºÍÔÚ2×Ö½ÚµÄÒ³Âë´¦Ó¦·Ö¸ßµÍ×Ö½ÚÏà¼Ó
   uchar i,ID1,ID2;
   SBUF=0xef;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0X07;
   while(TI==0);
   TI=0;
   SBUF=0X0c;
   while(TI==0);
   TI=0;
   ID1=pageID;ID2=pageID>>8;
   SBUF=ID2;
   while(TI==0);
   TI=0;
   SBUF=ID1;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=1;
   while(TI==0);
   TI=0;
   summaf=0x15+ID1+ID2;
   sum[0]=summaf;
   sum[1]=summaf>>8;
   SBUF=sum[1];
   while(TI==0);
   TI=0;
   SBUF=sum[0];
   while(TI==0);
   TI=0;
   for(i=0;i<9;i++)
    while(RI==0);
    RI=0;}
   while(RI==0);
   RI=0;
   querenma=SBUF;
   while(RI==0);
   RI=0;
   sum[1]=SBUF;
   while(RI==0);
   RI=0;
   sum[0]=SBUF;
void SFG_identify()                                //×Ô¶¯ÑéÖ¤Ö¸ÎÆ     Â¼Í¼Ïñ+Éú³ÉÌØÕ÷+ËÑË÷
   uchar i,ID1,ID2;
   SBUF=0xef;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0XFF;
   while(TI==0);
   TI=0;
   SBUF=0X01;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   SBUF=0X03;
   while(TI==0);
   TI=0;
   SBUF=0X11;
   while(TI==0);
   TI=0;
   SBUF=0X00;
   while(TI==0);
   TI=0;
   summaf=0x15;
   while(TI==0);
   TI=0;
   for(i=0;i<9;i++)
    while(RI==0);
    RI=0;}
   while(RI==0);
   RI=0;
   querenma=SBUF;
   while(RI==0);
   RI=0;
   ID1=SBUF;
   while(RI==0);
   RI=0;
   ID2=SBUF;
   while(RI==0);
   RI=0;
   while(RI==0);
   RI=0;                          //µÃ·Ö
   while(RI==0);
   RI=0;
   sum[1]=SBUF;
   while(RI==0);
   RI=0;
   sum[0]=SBUF;
   //PageID=ID1;
void shuazhiwen()
    uchar IDs1,IDs2,IDs3;
        LcmClearTXT();
        PutStr(1,1,"Çë°´ÊÖÖ¸¿ªËø");
        SFG_identify();
        count_down=1;
        while(querenma==2)
                SFG_identify();
                if(out_time>=10)
                        out_time=0;
                        count_down=0;
                        succeed_mm=0;
                        goto out_fingerprint;
        if(querenma==0)
                   out_time=0;
                count_down=0;
                ERROR_TIME=0;
                BUZZ=1;
                alarm=0;
                LcmClearTXT();
                PutStr(1,2,"ÃÅÒÑ´ò¿ª");
                IDs1=PageID/100;
                IDs2=PageID/10%10;
                IDs3=PageID%10;
                PutStr(2,1,"±àºÅΪ:");
                WriteCommand(0x8D);                //Ö¸¶¨µÚÈýÐÐÏÔʾλÖÃ
                WriteData(0x30+IDs1);
                WriteData(0x30+IDs2);
                WriteData(0x30+IDs3);
                jidianqi=0;
                delay(5000);
                jidianqi=1;
                succeed_mm=0;
           else if(querenma==9)
                        LcmClearTXT();
                        ERROR_TIME++;
                        if(ERROR_TIME>=3)
                        alarm=1;
                        PutStr(1,1,"ûËÑË÷µ½Ö¸ÎÆ");
                        PutStr(2,1,"ÇëÖØÐ°´ÊÖÖ¸");
                        out_time=0;
                        count_down=0;
                        LcmClearTXT();
                        PutStr(1,1,"½ÓÊÕ°ü³ö´í");
                        out_time=0;
                        count_down=0;
                delay(2000);
out_fingerprint:
        LcmClearTXT();
   //         while(Keycan()==0);
void addfinger()
        uchar IDa1,IDa2,IDa3;
        LcmClearTXT();
        PutStr(1,2,"Çë°´ÊÖÖ¸");
        SFG_getimage();
        while(querenma!=0)
        SFG_getimage();
        SFG_genchar(buffer1ID);
        UART_Init();
        SFG_fastsearch(buffer1ID);
        while(querenma==1)
        if(querenma==0)
                LcmClearTXT();
                PutStr(1,1,"¸ÃÖ¸ÎÆÒÑ´æ´¢");
                PutStr(3,0,"  °´ÈÎÒâ¼ü¼ÌÐø");
            while(Keycan()==0);
                        LcmClearTXT();
                        PutStr(1,1,"ÇëÔٴΰ´ÊÖÖ¸");
                        SFG_enroll();
                        while(querenma==2)
                        SFG_enroll();
                        LcmClearTXT();
                        if(querenma==0)
                                IDa1=PageID/100;IDa2=PageID/10%10;IDa3=PageID%10;
                                PutStr(1,1,"Ö¸ÎÆ²É¼¯³É¹¦");
                                WriteCommand(0x8D);
                                WriteData(0x30+IDa1);WriteData(0x30+IDa2);WriteData(0x30+IDa3);
                  else if(querenma!=0)
                                PutStr(1,1,"Ö¸ÎÆ²É¼¯Ê§°Ü");
                                PutStr(2,1,"ÇëÖØÐ²Ù×÷");
            while(Keycan()==0);
        LcmClearTXT();
void deletfinger()
        uchar i,j=0;
        LcmClearTXT();
        PutStr(1,0,"ÊäÈëɾȥµÄÖ¸ÎÆºÅ");
        PutStr(3,0," BÍ˸ñ     DÈ·ÈÏ");
        for(i=0;i<5;i++)dz=0;
           Key=Keycan();
           while(Key!=queren)
             Key=Keycan();
             KeyDeal(Key);
                 if(K==35) goto out2;
             delay(30);                                                              //°´¼üÓж¶¶¯@@@
             if(Key==0)K=10;
             if((K>=0)&&(K<=9))
              dz[j]=K;
                  if(j<3)
                                WriteCommand(0x88+j);                //Ö¸¶¨µÚÈýÐÐÏÔʾλÖÃ
                                WriteData(0x30+dz[j]);
              ++j;
                  if(j==4)
              j=3;        //@@#yinhuang
             }   //ÏÔʾLCD12864²¢ÐÐÏÔʾ
                 if(K==34)                //°´ÁËɾ³ý¼ü
                    if(j==0)
                                WriteCommand(0x88);                //Ö¸¶¨µÚÈýÐÐÏÔʾλÖÃ
                                WriteData(0x20);
                                --j;
                                WriteData(0x20);
        if(j>=2)
        PageID=dz[2]+dz[1]*10+dz[0]*100;
        if(j==1)
        PageID=dz[1]+dz[0]*10;
        if(j==0)
        PageID=dz[0];
        SFG_deletchar(PageID);
        if(querenma==0)
                LcmClearTXT();
                PutStr(1,1,"É¾È¥Ö¸ÎÆºÅ³É¹¦£¡");
                LcmClearTXT();
                PutStr(1,2,"É¾È¥Ö¸ÎÆºÅʧ°Ü£¡");
        PutStr(2,0,"  °´ÈÎÒâ¼ü¼ÌÐø");
        while(Keycan()==0);
out2:
        LcmClearTXT();
        K=0;
void gaimima()
        uchar i,j=0,mima1[6],mima2[6];
        uchar k,temp;
resum_modification:
        LcmClearTXT();
        PutStr(1,1,"ÇëÊäÈëÐÂÃÜÂë");
        for(i=0;i<6;i++)mima1=0;
           Key=Keycan();
      while(Key!=queren)
             Key=Keycan();
             KeyDeal(Key);
                 if(K==35) goto out3;
             delay(30);
             if(Key==0)K=10;
             if((K>=0)&&(K<=9))
              mima1[j]=K;
                  if(j<6)
                                WriteCommand(0x89+j);                //Ö¸¶¨µÚÈýÐÐÏÔʾλÖÃ
                                WriteData(0x0f);
              ++j;
                  if(j==7)
              j=6;        //@@#yinhuang
                    if(j==0)
                                WriteCommand(0x89);                //Ö¸¶¨µÚÈýÐÐÏÔʾλÖÃ
                                WriteData(0x20);
                                --j;
                                WriteData(0x20);
        LcmClearTXT();
        LcmClearTXT();
        j=0;
        PutStr(1,0,"ÇëÔÙ´ÎÊäÈëÐÂÃÜÂë");
        for(i=0;i<6;i++)mima2=0;
           Key=Keycan();
      while(Key!=queren)
             Key=Keycan();
             KeyDeal(Key);
             delay(30);
             if(Key==0)K=10;
             if((K>=0)&&(K<=9))
              mima2[j]=K;
                  if(j<6)
                                WriteData(0x0f);
              ++j;
                  if(j==7)
              j=6;        //@@#yinhuang
                    if(j==0)
                                WriteData(0x20);
                                --j;
                                WriteData(0x20);
        LcmClearTXT();
        if((mima1[0]==mima2[0])&&(mima1[1]==mima2[1])&&(mima1[2]==mima2[2])&&(mima1[3]==mima2[3])&&(mima1[4]==mima2[4])&&(mima1[5]==mima2[5]))
                for(i=0;i<6;i++)
                mimaID=mima1;
                for(i=0;i<6;i++)           //ÃÜÂëÏÞÖÆÔÚ6λÒÔÄÚ
                        UserPassword[0]=mima1;
                temp=(Member-1)*6;
                delayms(5);
                for(k=0;k<6;k++)
                        x24c02_write(temp,UserPassword[0][k]);
                        delayms(10);
                        temp++;
                PutStr(0,1,"ÃÜÂëÐ޸ijɹ¦");
                while(Keycan()==0);
                j=0;
                PutStr(0,0,"  ÃÜÂëÐÞ¸Äʧ°Ü  ");
                PutStr(1,0,"Á½´ÎÊäÈëµÄÃÜÂë²»");
                PutStr(2,0,"Ò»Ö£¬ÇëÖØÐ²Ù×÷");
                while(Keycan()==0);
                goto resum_modification;
out3:
        LcmClearTXT();
        K=0;
void gaimima_kaisuo()
        uchar k,temp;
resum_modification1:
        LcmClearTXT();
           Key=Keycan();
      while(Key!=queren)
             Key=Keycan();
             KeyDeal(Key);
                 if(K==35) goto out4;
             delay(30);
             if(Key==0)K=10;
             if((K>=0)&&(K<=9))
              mima1[j]=K;
                  if(j<6)
                                WriteData(0x0f);
              ++j;
                  if(j==7)
              j=6;        //@@#yinhuang
                    if(j==0)
                                WriteData(0x20);
                                --j;
                                WriteData(0x20);
        LcmClearTXT();
        LcmClearTXT();
        j=0;
           Key=Keycan();
      while(Key!=queren)
             Key=Keycan();
             KeyDeal(Key);
             delay(30);
             if(Key==0)K=10;
             if((K>=0)&&(K<=9))
              mima2[j]=K;
                  if(j<6)
                                WriteData(0x0f);
              ++j;
                  if(j==7)
              j=6;        //@@#yinhuang
                    if(j==0)
                                WriteData(0x20);
                                --j;
                                WriteData(0x20);
        LcmClearTXT();
                for(i=0;i<6;i++)
                mimaID=mima1;
                        UserPassword[1]=mima1;
                temp=(Member-1)*6;
                delayms(5);
                for(k=0;k<6;k++)
                        x24c02_write(temp,UserPassword[1][k]);
                        delayms(10);
                        temp++;
                while(Keycan()==0);
                j=0;
                while(Keycan()==0);
                goto resum_modification1;
out4:
        LcmClearTXT();
        K=0;
void zhu()
    LcmClearTXT();
           jidianqi=0;
        delay(5000);
        jidianqi=1;
//        PutStr(3,0,"  °´ÈÎÒâ¼ü¼ÌÐø");
        K=35;
void xiugaimima()
        LcmClearTXT();
        while(Keycan()!=tuichu)
                PutStr(0,0,"°´1:Ð޸ĿªËøÃÜÂë");
                PutStr(1,0,"°´2:Ð޸ĹÜÀíÃÜÂë");
                KeyDeal(Keycan());
                if(K==35) goto out5;
            switch(K)
                 case 1:        Member=2;gaimima_kaisuo();  break;
                 case 2:    Member=1;gaimima();        break;
             default: break;
out5:
          LcmClearTXT();
          K=0;
void guanliyuan()
{ uchar i,j=0,x=1;
           uchar Right_flag;
resum_guanliyuan:
    LcmClearTXT();
                PutStr(1,0,"ÇëÊäÈë¹ÜÀíÔ±ÃÜÂë");
           for(i=0;i<6;i++)mima=0;
           Key=Keycan();
      while(Key!=queren)
             Key=Keycan();
                 if(Key==tuichu) goto out1;
             KeyDeal(Key);
             delay(30);
             if(Key==0)K=10;
             if((K>=0)&&(K<=9))
              mima[j]=K;
                  if(j<6)
               WriteData(0x0f);
              ++j;
                  if(j==7)
              j=6;
                    if(j==0)
                  WriteData(0x20);
                          --j;
                  WriteData(0x20);
    LcmClearTXT();
          for(i=0;i<6;i++)
            UserPassword[0]=mima;
         if(j==6){Right_flag=Chack(0); }
          if (Right_flag==1)
                     Right_flag=0;
                  ERROR_TIME=0;
                  alarm=0;
                  BUZZ=1;
                PutStr(0,0,"°´1:  Ôö¼ÓÖ¸ÎÆ");
                PutStr(1,0,"°´2:  É¾È¥Ö¸ÎÆ");
                PutStr(2,0,"°´3:  ÐÞ¸ÄÃÜÂë");
                PutStr(3,0,"°´4:  ÊÖ¶¯¿ªËø");
                KeyDeal(Keycan());
                if(K==35) goto out1;
            switch(K)
             case 1:    addfinger();K=6; break;
             case 2:    deletfinger();    break;
                 case 3:        xiugaimima();  break;
                 case 4:    zhu();        break;
             default: break;
                j=0;
                ERROR_TIME++;
                if(ERROR_TIME>=3)
                        alarm=1;
                PutStr(1,2,"ÃÜÂë´íÎó");
                PutStr(2,0,"  ÇëÖØÐ²Ù×÷£¡");
             while(Keycan()==0);
                 goto resum_guanliyuan;
  Key=0;
out1:
  LcmClearTXT();
void kaisuomm()
{ uchar i,j=0,x=1;
           uchar Right_flag;
resume:           PutStr(1,0,"ÇëÊäÈë¿ªËøÃÜÂë  ");
           for(i=0;i<6;i++)mima_kai=0;
           Key=Keycan();
      while(Key!=queren)
             Key=Keycan();
                 if(Key==tuichu) goto out;
             KeyDeal(Key);
             delay(30);
             if(Key==0)K=10;
             if((K>=0)&&(K<=9))
              mima_kai[j]=K;
                  if(j<6)
               WriteData(0x0f);
              ++j;
                  if(j==7)
              j=6;
                    if(j==0)
                  WriteData(0x20);
                          --j;
                  WriteData(0x20);
//    LcmClearTXT();
          for(i=0;i<6;i++)
            UserPassword[1]=mima_kai;
         if(j==6){Right_flag=Chack(1); }
          if (Right_flag==1)
                     Right_flag=0;
                   succeed_mm=1;
                   ERROR_TIME=0;
                   BUZZ=1;
                   alarm=0;
//     while(Keycan()!=tuichu)
                PutStr(1,0,"  ÇëË¢ÊÖÖ¸¿ªËø");
                PutStr(3,0,"                ");
                j=0;
                ERROR_TIME++;
                if(ERROR_TIME>=3)
                        alarm=1;
//                PutStr(1,0,"                ");
                PutStr(1,0,"    ÃÜÂë´íÎó  ");
                PutStr(2,0,"  ÇëÖØÐÂÊäÈ룡");
                PutStr(3,0,"  °´ÈÎÒâ¼ü¼ÌÐø  ");
             while(Keycan()==0);
                 LcmClearTXT();
                 goto resume;
  Key=0;
out:
  LcmClearTXT();
void fan()
        if(succeed_mm==0)
                PutStr(0,2,"»¶Ó­Ê¹ÓÃ");
                PutStr(1,1,"Ö¸ÎÆÊ¶±ðϵͳ");
                PutStr(2,0,"                ");
                PutStr(3,0," A¹ÜÀí     C¿ªËø");
  Key=Keycan();
  if(Key==0x84)
          LcmClearTXT();
          kaisuomm();
        LcmClearTXT();
//        K=0;
if(/*k2==1&&*/succeed_mm==1)                //Ö¸ÎÆË¢»ú
          LcmClearTXT();
        shuazhiwen();
        LcmClearTXT();
  if(Key==0x81)                        //¹ÜÀíÔ±²Ù×÷
        LcmClearTXT();
        guanliyuan();
    LcmClearTXT();
//PSB=0;
        UART_Init();           //´®¿Ú³õʼ»¯
          x24c02_init();     //24C02³õʼ»¯
        LcmInit();               //LCD12864³õʼ»¯
        LcmClearTXT();           //LCD12864ÇåÆÁ
                        fan();
                        delay(100);
void T0_time() interrupt 1
        uchar jishi;
        TH0=0x4b;
        TL0=0xff;
        jishi++;
        if(jishi%2==0&&alarm==1)
                BUZZ=!BUZZ;
        if(jishi>=20)
                jishi=0;
                if(count_down==1)
                out_time++;
参与人数 1黑币 +12 收起 理由
cyh0157 + 12 很给力!
收藏收藏1 分享淘帖 顶 踩
