查看: 1653|回复: 7
可以接收到码值,为什么LED点不亮?
  1. #include "reg51.h"
  2. sbit IR_INPUT = P3^2;  //红外接口标志
  3. sbit LED0 = P1^0;
  4. sbit LED1 = P1^1;
  5. sbit LED2 = P1^2;
  6. sbit LED3 = P1^3;
  7. bit irflag = 0;
  8. unsigned int ircode[4];
  9. void InitInfrared();
  10. unsigned int GetHighTime();
  11. unsigned int GetLowTime();
  12. void main()
  13. {
  14.     InitInfrared();
  15.     while(1)
  16.     {
  17.         if(irflag)  //如果接收到红外数据
  18.         {
  19.             irflag = 0;  //清除标志
  20.             //根据接收到的键值控制LED
  21.             switch(ircode[2])  //通常键值在ircode[2]中
  22.             {
  23.                 case 0x44:LED0 = ~LED0;break;
  24.                 case 0x45:LED1 = ~LED1;break;
  25.                 case 0x46:LED2 = ~LED2;break;
  26.                 case 0x47:LED3 = ~LED3;break;
  27.                 default:break;
  28.             }
  29.         }
  30.     }
  31. }
  32. void InitInfrared()
  33. {
  34.     IR_INPUT = 1;
  35.     //TMOD &= 0xF0;
  36.     TMOD |= 0x01;   //设置T0 工作方式1
  37.     EA = 1;         //开总中断
  38.     ET0 = 1;
  39.     EX0 = 1;
  40.     IT0 = 1;
  41. }
  42. unsigned int GetHighTime()
  43. {
  44.   TH0=0;
  45.   TL0=0;
  46.   TR0=1;
  47.   while(IR_INPUT) //12/11.0592*16384=18ms
  48.   {
  49.     if(TH0>=0x40)
  50.     {
  51.       break;
  52.     }
  53.   }
  54.   TR0=0;
  55.   return(TH0 * 256 + TL0); //高电平的时间us
  56. }
  57. unsigned int GetLowTime()
  58. {
  59.   TH0=0;
  60.   TL0=0;
  61.   TR0=1;
  62.   while(!IR_INPUT) //12/11.0592*16384=18ms
  63.   {
  64.     if(TH0>=0x40)
  65.     {
  66.       break;
  67.     }
  68.   }
  69.   TR0=0;
  70.   return(TH0 * 256 + TL0); //低电平的时间us
  71. }
  72. void EXINT1_ISR() interrupt 0
  73. {
  74.     unsigned char i,j;
  75.     unsigned int time;
  76.     unsigned char byt;
  77.     EX0 = 0;
  78.     time = GetLowTime();
  79.     if((time < 7833) || (time > 8755)) //8.5ms-9.5ms之间,12/11.0592*x=8500us,x=7833;
  80.     {
  81.       EX0 = 1;
  82.       return;
  83.     }
  84.     time = GetHighTime();
  85.     if((time < 3686) || (time > 4608)) //4.5ms-5.5ms之间,12/11.0592*x=8500us,x=3686;
  86.     {
  87.       EX0 = 1;
  88.       return;
  89.     }
  90.     for(i=0;i<4;i++) //接收4个字节的数据
  91.     {
  92.         for(j=0;j<8;j++) //接收一个字节 8bit
  93.         {
  94.           time = GetLowTime();
  95.           if((time < 313) || (time > 718))
  96.           {
  97.             EX0 = 1;
  98.             return;
  99.           }
  100.           time = GetHighTime();
  101.           if((time > 313) && (time < 718))
  102.           {
  103.             byt >>= 1;
  104.           }
  105.           else if((time > 1345) && (time < 1751))
  106.           {
  107.             byt >>= 1;
  108.             byt |= 0x80;
  109.           }
  110.           else
  111.           {
  112.             EX0 = 0;
  113.             return;
  114.           }
  115.         }
  116.         ircode[i] = byt;
  117.     }
  118.     irflag = 1;
  119.     EX0 = 0;
  120. }
ID:584814 发表于 2025-5-5 08:33 | 只看该作者
因为LED没有接上
ID:469589 发表于 2025-5-5 09:20 | 只看该作者
因为时间太短,来不及亮就又灭了。
你应该点亮后计数至少10到30个脉冲数后再光端,这样就可能看见了。
ID:1109793 发表于 2025-5-5 11:29 | 只看该作者
GlenXu 发表于 2025-5-5 09:20
因为时间太短,来不及亮就又灭了。
每次反转,至少应该看到,虽然亮度可能低点。再说遥控器的发射并不快。
我觉得是解码不对,解出来的不是一样的
ID:272119 发表于 2025-5-5 22:19 | 只看该作者
亲,保留P30/P31用串口输出读一读解出来的是啥吧...
ID:136485 发表于 2025-5-6 08:10 | 只看该作者
switch(ircode[2]) 你这条语句是不是有问题,还有硬件有没有问题
ID:1109793 发表于 2025-5-6 13:43 | 只看该作者
或者板子上有显示的话,显示到板子上也行。
ID:1091344 发表于 2025-5-6 14:48 | 只看该作者
while(1)里面的ircode数组数据没有更新,要写获取相关数据后更新数组,不然switch里面数组一直是初始值,进不了翻转灯
