查看: 578|回复: 0
这段代码烧入到PROTEUS仿真中,电机不能转动了,但是ADC的clock一直有脉冲,请大佬看
ID:531378 发表于 2025-8-18 15:50 | 显示全部楼层 |阅读模式
#include "reg51.h"
#include <intrins.h>
#define PULSES_PER_ROUND 1
#define Kt 0.01f
#define ACS712_SENSITIVITY 0.185f
#define LCD_DB_PORT P0
#define ADC_DATA_PORT P0
sbit mo_flyback = P2^0;
sbit IN1 = P1^0;
sbit IN2 = P1^1;
sbit ENA = P1^2;
sbit IN3 = P1^3;
sbit IN4 = P1^4;
sbit ENB = P1^5;
sbit encoder = P3^2;
sbit ADC_ALE  = P3^0;
sbit ADC_START = P3^1;
sbit ADC_EOC  = P3^3;
sbit ADC_OE   = P3^5;
sbit ADC_CLOCK = P3^4;
sbit LCD_RS = P2^3;
sbit LCD_RW = P2^4;
sbit LCD_E  = P2^5;
uchar count = 0;
char speed = 90;
volatile uint encoder_count = 0;
uchar state = 0;
uint cycle_count = 0;
uint second_count = 0;
uint adc_sample_interval = 0;
float current = 0.0f;
float torque = 0.0f;
uchar adc_current_val = 0;
void adc_init(void);
uchar adc_read(void);
void calculate_torque(void);
void delay_ms(uint t) {
    uint i, j;
    for(i = 0; i < t; i++)
        for(j = 0; j < 240; j++);
void delay_us(uchar t) {
    while(t--);
void timer1_isr(void) interrupt 3 {
    TH1 = 0xFF;
    TL1 = 0xFF;
    ADC_CLOCK = !ADC_CLOCK;
uchar adc_read(void) {
    uchar adc_value;
    uint timeout;
    ADC_ALE = 1;
    delay_us(2);
    ADC_ALE = 0;
    ADC_START = 1;
     delay_us(2);
    ADC_START = 0;
        timeout=0;
    while(ADC_EOC == 0){
                timeout++;
                        if(timeout > 20000)
                                return 0;
    ADC_OE = 1;
    delay_us(1);
    adc_value = ADC_DATA_PORT;
    ADC_OE = 0;
    return adc_value;
void calculate_torque(void) {
                        float voltage;
   voltage = (float)adc_current_val * 5.0f / 255.0f;
    current = (voltage - 2.5f) / ACS712_SENSITIVITY;
   if(current < 0) current = -current;
   torque = Kt * current;
void adc_init(void) {
    TMOD |= 0x10;
    TH1 = 0xFF;
    TL1 = 0xFF;
    ET1 = 1;
    TR1 = 1;
void init_system(void) {
    ENA = 0; IN1 = 0; IN2 = 0;
    ENB = 0; IN3 = 0; IN4 = 0;
    TMOD |= 0x01;
    TH0 = (65536 - 1000) / 256;
    TL0 = (65536 - 1000) % 256;
        EA=1;
        ET0 = 1;
    TR0=1;
    IT0 = 1;
    EX0 = 1;
adc_init();
    delay_ms(1000);
void timer0_isr(void) interrupt 1 {
    count = (count + 1) % 100;
    if(state == 1) {
        IN1 = (count < speed) ? 1 : 0;
        IN3 = (count < speed) ? 1 : 0;
        IN2 = 0; IN4 = 0;
    } else if(state == 2) {
        IN2 = (count < speed) ? 1 : 0;
        IN4 = (count < speed) ? 1 : 0;
        IN1 = 0; IN3 = 0;
    } else {
        IN1 = 0; IN2 = 0; IN3 = 0; IN4 = 0;
    cycle_count++;
    if(cycle_count >= 1000) {
        cycle_count = 0;
        second_count++;
                 adc_sample_interval++;
    if(adc_sample_interval >= 20) {
        adc_current_val = adc_read();
        calculate_torque();
void encoder_isr(void) interrupt 0 {
    encoder_count++;
        uint forward_target = 5 * PULSES_PER_ROUND;
uint reverse_target = forward_target + 20 * PULSES_PER_ROUND;
        init_system();
                ENA=0;
    IN1=0;
    IN2=0;
        ENB=0;
        IN3=0;
        IN4=0;
    while(1) {
        if(state == 0 && mo_flyback == 0) {
            delay_ms(10);
            while(mo_flyback == 0);
                                        state = 1;
            ENA = 1; ENB = 1;
            encoder_count = 0;
        if(state == 1 && encoder_count >= forward_target) {
                                        ENA = 0;
            IN1 = 0;
            IN2 = 0;
                                        ENB = 0;
            IN3 = 0;
            IN4 = 0;
            delay_ms(50);
            state = 2;
            ENA = 1; ENB = 1;
        if(state == 2 && encoder_count >= reverse_target) {
                                        ENA = 0;
            IN1 = 0;
            IN2 = 0;
                                        ENB = 0;
            IN3= 0;
            IN4= 0;
            delay_ms(50);
            state = 1;
            ENA = 1; ENB = 1;
            encoder_count = 0;
        if(second_count > 3600) {
            ENA = 0; ENB = 0;
            break;
                 delay_ms(10);
