查看: 620|回复: 1
FM1821250CT6-00显示屏点不亮求助,VG接了104电容至GND,C+与C-间也是接了104电容
ID:334440 发表于 2025-8-19 09:19 | 显示全部楼层 |阅读模式
  1. #include <STC8G.H>
  2. #include <intrins.h>
  3. sbit LCD_CS  = P3^2;
  4. sbit LCD_RST = P3^3;
  5. sbit LCD_A0  = P3^4;
  6. sbit LCD_SCL = P3^5;
  7. sbit LCD_SDA = P3^6;
  8. void delay_ms(unsigned int ms) {
  9.     unsigned int i, j;
  10.     for(i=0; i<ms; i++)
  11.         for(j=0; j<1000; j++);
  12. }
  13. void SPI_WriteByte(unsigned char dat) {
  14.     unsigned char i;
  15.     LCD_CS = 0;
  16.     for(i=0; i<8; i++) {
  17.         LCD_SCL = 0;
  18.         if(dat & 0x80)
  19.             LCD_SDA = 1;
  20.         else
  21.             LCD_SDA = 0;
  22.         LCD_SCL = 1;
  23.         dat <<= 1;
  24.     }
  25.     LCD_CS = 1;
  26. }
  27. void LCD_WriteCmd(unsigned char cmd) {
  28.     LCD_A0 = 0;
  29.     SPI_WriteByte(cmd);
  30. }
  31. void LCD_WriteData(unsigned char dat) {
  32.     LCD_A0 = 1;
  33.     SPI_WriteByte(dat);
  34. }
  35. void LCD_Init() {
  36.     LCD_RST = 0;
  37.     delay_ms(100);
  38.     LCD_RST = 1;
  39.     delay_ms(100);
  40.
  41.
  42.
  43.         LCD_WriteCmd(0xE2);
  44.     delay_ms(100);
  45.     LCD_WriteCmd(0xA3);
  46.     LCD_WriteCmd(0xA0);
  47.     LCD_WriteCmd(0xC8);
  48.     LCD_WriteCmd(0x24);
  49.     LCD_WriteCmd(0x81);
  50.
  51.         LCD_WriteCmd(0x20);
  52.     LCD_WriteCmd(0x2F);
  53.     LCD_WriteCmd(0x40);
  54.
  55.         LCD_WriteCmd(0xA6);
  56.     LCD_WriteCmd(0xA4);
  57.     LCD_WriteCmd(0xAF);
  58. }
  59. void LCD_Clear() {
  60.     unsigned int i;
  61.     LCD_WriteCmd(0xB0);
  62.     LCD_WriteCmd(0x10);
  63.
  64.         LCD_WriteCmd(0x00);
  65.
  66.     for(i=0; i<1024; i++) {
  67.         LCD_WriteData(0x00);
  68.     }
  69. }
  70. void LCD_SetPos(unsigned char x, unsigned char y) {
  71.     LCD_WriteCmd(0xB0 + y);
  72.     LCD_WriteCmd(0x10 + (x >> 4));
  73.
  74.         LCD_WriteCmd(x & 0x0F);
  75.         }
  76. void main() {
  77.
  78.
  79.         P3M0 = 0x00;
  80.     P3M1 = 0x00;
  81.
  82.
  83.     LCD_Init();
  84.     LCD_Clear();
  85.
  86.
  87.
  88.         LCD_SetPos(10, 0);
  89.     LCD_WriteData(0xFF);
  90.     LCD_WriteData(0xFF);
  91.     LCD_WriteData(0xFF);
  92.
  93.     LCD_SetPos(20, 2);
  94.     LCD_WriteData(0x01);
  95.     LCD_WriteData(0x02);
  96.     LCD_WriteData(0x04);
  97.     LCD_WriteData(0x08);
  98.     LCD_WriteData(0x10);
  99.     LCD_WriteData(0x20);
  100.     LCD_WriteData(0x40);
  101.     LCD_WriteData(0x80);
  102.
  103.     while(1) {
  104.
  105.                 }
  106. }
ID:1064915 发表于 2025-8-19 14:26 | 显示全部楼层
厂家有亮屏程序
