查看: 1474|回复: 5
做红外感应开关,要如何避开红外干扰呢?
ID:1144894 发表于 2025-9-9 19:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用STC8G1K08A做的红外感应开关,用手机刘海的红外感应头对着单片机的红外感应头时,灯会一直在闪烁要如何避开,有没有大佬解答一下要如何处理呢,
#include "reg51.h"
#include "intrins.h"
/*************        本地常量声明        **************/
#define ADC_START        (1<<6)        /* 自动清0 */
#define ADC_FLAG        (1<<5)        /* 软件清0 */
#define        ADC_SPEED        1                /* 0~15, ADC时钟 = SYSclk/2/(n+1) */
#define        RES_FMT                (1<<5)        /* ADC结果格式 0: 左对齐, ADC_RES: D9 D8 D7 D6 D5 D4 D3 D2, ADC_RESL: D1 D0 0  0  0  0  0  0 */
                                                        /*             1: 右对齐, ADC_RES: 0  0  0  0  0  0  D9 D8, ADC_RESL: D7 D6 D5 D4 D3 D2 D1 D0 */
#define CSSETUP                (1<<7)        /* 0~1,  ADC通道选择时间      0: 1个ADC时钟, 1: 2个ADC时钟,  默认0(默认1个ADC时钟) */
#define CSHOLD                (2<<5)        /* 0~3,  ADC通道选择保持时间  (n+1)个ADC时钟, 默认1(默认2个ADC时钟)                */
#define SMPDUTY                20                /* 10~31, ADC模拟信号采样时间  (n+1)个ADC时钟, 默认10(默认11个ADC时钟)                                */
                                                        /* ADC转换时间: 10位ADC固定为10个ADC时钟, 12位ADC固定为12个ADC时钟.                                 */
#define MAIN_Fosc                22118400L        //定义主时钟
sfr     ADC_CONTR   =   0xbc;
sfr     ADC_RES     =   0xbd;
sfr     ADC_RESL    =   0xbe;
sfr     ADCCFG      =   0xde;
sfr     P_SW2   =   0xba;
#define ADCTIM  (*(unsigned char volatile xdata *)0xfea8)
sfr AUXR = 0x8E;
sfr INT_CLKO = 0x8F;
sfr P_SW1 = 0xa2;
sfr     CCON    =   0xd8;
sbit    CF      =   CCON^7;
sbit    CR      =   CCON^6;
sbit    CCF2    =   CCON^2;
sbit    CCF1    =   CCON^1;
sbit    CCF0    =   CCON^0;
sfr     CMOD    =   0xd9;
sfr     CL      =   0xe9;
sfr     CH      =   0xf9;
sfr     CCAPM0  =   0xda;
sfr     CCAP0L  =   0xea;
sfr     CCAP0H  =   0xfa;
sfr     PCA_PWM0 =  0xf2;
sfr     CCAPM1  =   0xdb;
sfr     CCAP1L  =   0xeb;
sfr     CCAP1H  =   0xfb;
sfr     PCA_PWM1 =  0xf3;
sfr     CCAPM2  =   0xdc;
sfr     CCAP2L  =   0xec;
sfr     CCAP2H  =   0xfc;
sfr     PCA_PWM2 =  0xf4;
sfr     P0M1    =   0x93;
sfr     P0M0    =   0x94;
sfr     P1M1    =   0x91;
sfr     P1M0    =   0x92;
sfr     P2M1    =   0x95;
sfr     P2M0    =   0x96;
sfr     P3M1    =   0xb1;
sfr     P3M0    =   0xb2;
sfr     P4M1    =   0xb3;
sfr     P4M0    =   0xb4;
sfr     P5M1    =   0xc9;
sfr     P5M0    =   0xca;
sfr P4   = 0xC0;
sfr P5   = 0xC8;
sfr P6   = 0xE8;
sfr P7   = 0xF8;
sbit    IR_OUT    =   P5^4;
sbit    IR_IN           =   P5^5;
typedef     unsigned char   u8;
typedef     unsigned int    u16;
typedef     unsigned long   u32;
#define         PCA0                        0
#define         PCA1                        1
#define         PCA2                        2
unsigned int ambient_light = 0;   // 环境光基准值
unsigned int ir_received        = 0;
#define EMIT_DURATION 20    // 发射持续时间(ms)
#define STOP_DURATION 10    // 停止持续时间(ms)
unsigned int emit_phase_samples = 0;  // 发射阶段采样值
unsigned int stop_phase_samples = 0;  // 停止阶段采样值
unsigned int net_ir_signal = 0;       // 净反射信号强度
bit emission_state = 0;               // 发射状态: 0=停止, 1=发射
unsigned int timer0_count = 0;        // 定时器0计数
void UpdatePcaPwm(u8 PCA_id, u16 pwm_value)
        if(PCA_id == PCA0)
                PCA_PWM0 = (PCA_PWM0 & ~0x32) | (u8)((pwm_value & 0x0300) >> 4) | (u8)((pwm_value & 0x0400) >> 9);
                CCAP0H = (u8)pwm_value;
        else if(PCA_id == PCA1)
                PCA_PWM1 = (PCA_PWM1 & ~0x32) | (u8)((pwm_value & 0x0300) >> 4) | (u8)((pwm_value & 0x0400) >> 9);
                CCAP1H = (u8)pwm_value;
        else if(PCA_id == PCA2)
                PCA_PWM2 = (PCA_PWM2 & ~0x32) | (u8)((pwm_value & 0x0300) >> 4) | (u8)((pwm_value & 0x0400) >> 9);
                CCAP2H = (u8)pwm_value;
void Timer0_Init(void)                //1毫秒@22.1184MHz
        //定时器0
        TMOD = 0x00;                                //模式0
        TL0  = 0xcd;                                 //[TH0,TL0]=65536-22.1184M*1000/12*1(1MS)
        TH0  = 0xf8;
        TR0  = 1;                                    //启动定时器
        ET0  = 1;                                    //使能定时器中断
        EA  = 1;
void TM0_Isr() interrupt 1        //1ms
        timer0_count++;
        // 控制发射时序: 发射20ms, 停止10ms
        if(emission_state)
                if(timer0_count >= EMIT_DURATION)
                        emission_state = 0;
                        timer0_count = 0;
                        IR_OUT = 0; // 停止发射
                if(timer0_count >= STOP_DURATION)
                        emission_state = 1;
                        timer0_count = 0;
                        IR_OUT = 1; // 开始发射
void Timer1_Init(void)
        AUXR &= 0xBF;                        //定时器时钟12T模式
        TMOD &= 0x0F;                        //设置定时器模式
        TL1 = 0xE8;                                //设置定时初始值
        TH1 = 0xFF;                                //设置定时初始值
        TF1 = 0;                                //清除TF1标志
        TR1 = 1;                                //定时器1开始计时
        ET1 = 1;                                //使能定时器1中断
void Timer1_Isr(void) interrupt 3
        // 不再使用Timer1控制发射,改为由Timer0控制
// 初始化ADC
void ADC_Init(void)
    P5M0 &= ~0x20; P5M1 |= 0x20; // P5.5设为高阻输入
    ADC_CONTR = 0x80 + 0;        //ADC on + channel
        ADCCFG = RES_FMT + ADC_SPEED;
        P_SW2 |=  0x80;        //访问XSFR
        ADCTIM = CSSETUP + CSHOLD + SMPDUTY;
u16        Get_ADC10bitResult(u8 channel)
        ADC_RES = 0;
        ADC_RESL = 0;
        ADC_CONTR = 0x80 | ADC_START | channel;
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        while((ADC_CONTR & ADC_FLAG) == 0)        ;        //等待ADC结束
        ADC_CONTR &= ~ADC_FLAG;
        #if ((RES_FMT & (1<<5)) != 0)
                return        ((u16)ADC_RES * 256 + (u16)ADC_RESL);        //右对齐
        #else
                return        ((u16)ADC_RES * 4 + (u16)(ADC_RESL >> 6));        //左对齐
        #endif
#define                SUM_LENGTH        16        /* 平均值采样次数 最大值16 */
查询方式做一次ADC, chn为通道号, chn=0~3通道对应P3.0~P3.3, 4通道-->P5.4, 5通道-->P5.5, 15通道为内部1.19V基准电压做输入的ADC值.
unsigned int        ADC_convert(u8 chn)
        u16        j;
        u8        k;                //平均值滤波时使用
        Get_ADC10bitResult(chn);                //参数i=0~11,15,查询方式做一次ADC, 切换通道后第一次转换结果丢弃. 避免采样电容的残存电压影响.
        Get_ADC10bitResult(chn);                //参数i=0~11,15,查询方式做一次ADC, 切换通道后第二次转换结果丢弃. 避免采样电容的残存电压影响.
        for(k=0, j=0; k<SUM_LENGTH; k++)
                j += Get_ADC10bitResult(chn);        // 采样累加和   参数0~15,查询方式做一次ADC, 返回值就是结果
        j = j / SUM_LENGTH;                // 求平均
        return j;
// 在全局变量中定义滤波系数和滤波后的值
#define ALPHA 0.2f  // 滤波系数 (0 < ALPHA < 1)。值越小越平滑,但响应也越慢。
unsigned int filtered_ir_value = 0;
        P0M0 = 0x00;
        P0M1 = 0x00;
        P1M0 = 0x00;
        P1M1 = 0x00;
        P2M0 = 0x00;
        P2M1 = 0x00;
        P3M0 = 0xe0;
        P3M1 = 0x00;
        P4M0 = 0x00;
        P4M1 = 0x00;
        P5M0 = 0x00;
        P5M1 = 0x00;
    P3M0 |= 0x08; P3M1 &= ~0x08; //P3.3推挽模式
        P3M0 |= 0x04; P3M1 &= ~0x04; //P3.2推挽模式
    P_SW1 = 0x00; //ECI/P1.2, CCP0/P1.1, CCP1/P1.0, CCP2/P3.7
        CCON = 0x00;
        CMOD = 0x08; //PCA 时钟为系统时钟
        CL = 0x00;
        CH = 0x00;
        //-- 10 位 PWM--
        CCAPM0 = 0x02;          //PCA 模块 0 为 PWM 工作模式
        PCA_PWM0 = 0xc0; //PCA 模块 0 输出 10 位 PWM
        CCAP0L = 0;
        CCAP0H = 0;
        CCAPM1 = 0x02;          //PCA 模块 1 为 PWM 工作模式
        PCA_PWM1 = 0xc0; //PCA 模块 1 输出 10 位 PWM
        CCAP1L = 0;
        CCAP1H = 0;
        CR = 1; //启动 PCA 计时器
        //定时器
        Timer0_Init();
        Timer1_Init();
        UpdatePcaPwm(PCA1,1023);
        UpdatePcaPwm(PCA0,1023);
        ADC_Init();
        ambient_light = ADC_convert(5);
    while (1)
                // 同步采样策略
                if(emission_state && timer0_count > EMIT_DURATION/2)
                        // 在发射阶段后期采样 (包含自身发射的反射信号 + 环境光)
                        emit_phase_samples = ADC_convert(5);
                else if(!emission_state && timer0_count > STOP_DURATION/2)
                        // 在停止发射阶段采样 (主要是环境光)
                        stop_phase_samples = ADC_convert(5);
                        // 计算净反射信号强度
                        if(emit_phase_samples > stop_phase_samples)
                                net_ir_signal = emit_phase_samples - stop_phase_samples;
                                net_ir_signal = 0;
                        // 使用净反射信号进行滤波
                        filtered_ir_value = (unsigned int)((1 - ALPHA) * filtered_ir_value + ALPHA * net_ir_signal);
                        // 环境光补偿:使用停止阶段的采样值作为环境光基准
                        ambient_light = stop_phase_samples;
                        // 手势检测:基于净反射信号
                        if(net_ir_signal > 83) // 阈值可能需要调整
                                UpdatePcaPwm(PCA1,0);
                                UpdatePcaPwm(PCA0,0);
收藏收藏2 分享淘帖 顶顶 踩踩
ID:879348 发表于 2025-9-10 07:53 | 只看该作者
加入简易自主协议,比如在发射信号加入50%方波,因为其他干扰不可能出现这种简单的波形
ID:648281 发表于 2025-9-10 22:14 | 只看该作者
在收发加入一个通讯协议,协议对的上感应才有效
ID:1034262 发表于 2025-9-11 12:11 | 只看该作者
使用类似红外遥控的数据编码
ID:879809 发表于 2025-9-11 17:33 | 只看该作者
用通讯协议会降低响应速度,一般调制成38k方波就可以了,外来干扰是38k的概率基本是零。
ID:1160416 发表于 2025-9-15 17:06 | 只看该作者
手机红外传感器的工作频率通常是固定的(如 38kHz 或特定载波频率),而你的红外接收头可能对所有红外信号都敏感。解决思路是让单片机只响应特定频率编码的红外信号,过滤掉手机的干扰信号。
