查看: 1056|回复: 0
51单片机+Proteus仿真的座位号举手应答器程序设计
ID:1162842 发表于 2025-11-11 11:22 | 显示全部楼层 |阅读模式
  1. #include <reg51.h>
  2. #define uint unsigned int
  3. #define uchr unsigned char
  4. sbit led0=P2^2;
  5. sbit buzzer=P2^3;
  6. sbit dula=P2^6;                //声明段选线选通端
  7. sbit wela=P2^7;                //声明位选线选通端
  8. sbit clear=P3^4;
  9. uchr key,shi,ge,count;
  10. uchr code tab[]={
  11. 0x3f,0x06,0x5b,0x4f,
  12. 0x66,0x6d,0x7d,0x07,
  13. 0x7f,0x6f,0x77,0x7c,
  14. 0x39,0x5e,0x79,0x71,
  15. 0x76,0x79,0x38,0x3f};
  16. /*延时子函数,xms为形参*/
  17. void delay(uint xms)
  18. {
  19.     uint x,y;
  20.     for(x=xms;x>0;x--)
  21.         for(y=110;y>0;y--);
  22. }
  23. /*矩阵键盘扫描子程序*/
  24. void matrixkeyscan()
  25. {
  26.     uint temp;
  27.     P3=0xf7;                             //给P3口赋值
  28.     temp=P3;
  29.     temp=temp&0xf0;
  30.     if(temp!=0xf0)                       //检测是否有键按下
  31.     {
  32.         delay(6);                       //延时去抖
  33.         temp=P3;
  34.         temp=temp&0xf0;
  35.         if(temp!=0xf0)                   //再次检测是否有键按下
  36.         {
  37.             temp=P3;
  38.             switch(temp)
  39.             {
  40.                 case 0x77:
  41.                     key=1;
  42.                     break;
  43.                 case 0xb7:
  44.                     key=2;
  45.                     break;
  46.                 case 0xd7:
  47.                     key=3;
  48.                     break;
  49.                 case 0xe7:
  50.                     key=4;
  51.                     break;              //判断按下的是哪个键
  52.             }
  53.             while(temp!=0xf0)
  54.             {
  55.                 temp=P3;
  56.                 temp=temp&0xf0;
  57.             }                           //等待按键释放
  58.         }
  59.     }
  60.     P3=0xfb;
  61.     temp=P3;
  62.     temp=temp&0xf0;
  63.     if(temp!=0xf0)
  64.     {
  65.         delay(6);
  66.         temp=P3;
  67.         temp=temp&0xf0;
  68.         if(temp!=0xf0)
  69.         {
  70.             temp=P3;
  71.             switch(temp)
  72.             {
  73. case 0x7b:
  74.                     key=5;
  75.                     break;
  76.                 case 0xbb:
  77.                     key=6;
  78.                     break;
  79.                 case 0xdb:
  80.                     key=7;
  81.                     break;
  82.                 case 0xeb:
  83.                     key=8;
  84.                     break;
  85.             }
  86.             while(temp!=0xf0)
  87.             {
  88.                 temp=P3;
  89.                 temp=temp&0xf0;
  90.             }
  91.         }
  92.     }
  93.     P3=0xfd;
  94.     temp=P3;
  95.     temp=temp&0xf0;
  96.     if(temp!=0xf0)
  97.     {
  98.         delay(6);
  99.         temp=P3;
  100.         temp=temp&0xf0;
  101.         if(temp!=0xf0)
  102.         {
  103.             temp=P3;
  104.             switch(temp)
  105.             {
  106.                 case 0x7d:
  107.                     key=9;
  108.                     break;
  109.                 case 0xbd:
  110.                     key=10;
  111.                     break;
  112.                case 0xdd:
  113.                     key=11;
  114.                     break;
  115.                 case 0xed:
  116.                     key=12;
  117.                     break;
  118.             }
  119.             while(temp!=0xf0)
  120.             {
  121.                 temp=P3;
  122.                 temp=temp&0xf0;
  123.             }
  124.         }
  125.     }
  126.     P3=0xfe;
  127.     temp=P3;
  128.     temp=temp&0xf0;
  129.     if(temp!=0xf0)
  130.     {
  131.         delay(6);
  132.         temp=P3;
  133.         temp=temp&0xf0;
  134.         if(temp!=0xf0)
  135.         {
  136.             temp=P3;
  137.             switch(temp)
  138.             {
  139.                 case 0x7e:
  140.                     key=13;
  141.                     break;
  142.                 case 0xbe:
  143.                     key=14;
  144.                     break;
  145.                 case 0xde:
  146.                     key=15;
  147.                     break;
  148.                 case 0xee:
  149.                     key=16;
  150.                     break;
  151.             }
  152.             while(temp!=0xf0)
  153.             {
  154.                 temp=P3;
  155.                 temp=temp&0xf0;
  156.             }
  157.         }
  158.     }
  159. }
  160. /*主函数*/
  161. void alarm()
  162. {
  163.         buzzer=~buzzer;
  164.         led0=~led0;
  165.         delay(30);
  166. }
  167.     void display(uchr num)
  168.         {
  169.                 if(key!=0)             //若有键按下,则进入该循环进行处理
  170.         {
  171.
  172.             dula=1;
  173.             P0=tab[num/10];
  174.             dula=0;
  175.              P0=0x00;
  176.             wela=1;
  177.             P0=0xfe;
  178.             wela=0;
  179.             delay(100);
  180.             dula=1;
  181.             P0=tab[num%10];
  182.             dula=0;
  183.            P0=0x00;
  184.                   wela=1;
  185.                    P0=0xfd;
  186.                    wela=0;
  187.                    delay(100);
  188.                    alarm();
  189.                 }
  190.         }
  191.         void main()
  192.         {
  193.         P0=0x00;
  194.         while(1)
  195.         {
  196.         matrixkeyscan();
  197.         display(key);
  198.         }
  199.         }
下载: 座位号举手应答器.7z (113.8 KB, 下载次数: 0)
