查看: 1118|回复: 0
基于51单片机的智能温湿度大棚程序Proteus仿真设计
  1. #include "main.h"
  2. #include "LCD1602.h"
  3. #include "keyScan.h"
  4. #include "bsp_timer.h"
  5. #include "bsp_uart.h"
  6. #include "dht11.h"
  7. // 变量定义
  8. sbit reduce_temp = P2^3;    //控制降温机
  9. sbit add_temp    = P2^2;    //控制升温机
  10. sbit reduce_hum  = P2^1;    //控制减湿器
  11. sbit add_hum     = P2^0;    //控制加湿器
  12. sbit LED = P1^7;            //心跳灯
  13. uint8_t  g_key_value = 0;                // 按键按下的值
  14. uint8_t  hum_high  = 30,  hum_low     = 25;//设置的湿度最大值和最小值
  15. uint8_t  temp_high = 35,  temp_low    = 25;//设置的温度最大值和最小值
  16. uint8_t  humidity  = 0 ,  temperature =  0;//实际的湿度值和温度值
  17. uint8_t  ui_page   = 0 ;                //显示页面
  18. uint8_t  set_pos   = 0 ;                //设置序号 0:设置hum_high 1:设置hum_low 2:设置temp_high 3:设置temp_low
  19. uint8_t  read_dht11_flag = 0;           //读取DHT11的标志位。
  20. uint8_t  ui_refresh_flag = 0;           //界面刷新的标志位。
  21. void main()
  22. {
  23.         uint8_t  ret;
  24.         uint8_t  blink_count = 0;
  25.         uint8_t  lcdShowBuff[16] = {0};
  26.
  27.         EA = 0;                 //关闭所有中断
  28.         LcdInit();            // LCD显示初始化
  29.         key_init();
  30.         LED = 0;
  31.         bsp_timer_set_ms_IT(Timer0,5);
  32.         Uart1_Init();
  33.         EA = 1;                 //打开所有中断
  34.
  35.         while(1)
  36.         {
  37.                 if(read_dht11_flag == 1)
  38.                 {
  39.                         EA = 0;
  40.                         ret = DHT11_Get_Data(&humidity, &temperature) ;
  41.                         EA = 1;
  42.                         printf("hum :%2d  temp:%2d\r\n",(int)humidity,(int)temperature); //发送一次温湿度
  43.                         read_dht11_flag = 0;
  44.                 }
  45.
  46.                 if( ui_refresh_flag == 1)
  47.                 {
  48.                         if(ui_page == 0)
  49.                         {
  50.                                 sprintf((char*)lcdShowBuff,"  real  data    ");
  51.                                 LcdShowStr(0, 0, lcdShowBuff);
  52.                                 sprintf((char*)lcdShowBuff,"hum :%2d  temp:%2d",(int)humidity,(int)temperature);
  53.                                 LcdShowStr(0, 1, lcdShowBuff);
  54.                         }else if(ui_page == 1)
  55.                         {
  56.                                 blink_count ++;
  57.
  58.                                 sprintf((char*)lcdShowBuff,"HumH:%2d  HumL:%2d",(int)hum_high, (int)hum_low);
  59.                                 LcdShowStr(0, 0, lcdShowBuff);
  60.                                 sprintf((char*)lcdShowBuff,"TmpH:%2d  TmpL:%2d",(int)temp_high,(int)temp_low);
  61.                                 LcdShowStr(0, 1, lcdShowBuff);
  62.
  63.                                 // 计数值为偶数的时候闪烁
  64.                                 if(blink_count % 2 == 0)
  65.                                 {
  66.                                         switch(set_pos)
  67.                                         {
  68.                                                 case 0:LcdShowStr(5,0,"  ");break;
  69.                                                 case 1:LcdShowStr(14,0,"  ");break;
  70.                                                 case 2:LcdShowStr(5,1,"  ");break;
  71.                                                 case 3:LcdShowStr(14,1,"  ");break;
  72.                                         }
  73.                                 }
  74.                         }
  75.                         ui_refresh_flag = 0;
  76.                 }
  77.         }
  78. }
  79. /**
  80.   * @brief   根据按键值决定当前的功能处理
  81.   * @param
  82.   * @retval  void
  83. **/
  84. void KeyControlFunction(uint8_t key_value)
  85. {
  86.         if(key_value == KEY1_VALUE)
  87.         {
  88.                 if(ui_page == 1)
  89.                 {
  90.                         if(set_pos == 0) hum_high++;
  91.                         else if(set_pos == 1) hum_low++;
  92.                         else if(set_pos == 2) temp_high++;
  93.                         else if(set_pos == 3) temp_low++;
  94.                 }
  95.         }
  96.         else if(key_value == KEY2_VALUE)
  97.         {
  98.                 if(ui_page == 1)
  99.                 {
  100.                         if(set_pos == 0) hum_high--;
  101.                         else if(set_pos == 1) hum_low--;
  102.                         else if(set_pos == 2) temp_high--;
  103.                         else if(set_pos == 3) temp_low--;
  104.                 }
  105.         }
  106.         else if(key_value == KEY3_VALUE)
  107.         {
  108.                 if(ui_page == 0)
  109.                         ui_page = 1;
  110.                 else if(ui_page == 1)
  111.                         ui_page = 0;
  112.         }
  113.         else if(key_value == KEY4_VALUE)
  114.         {
  115.                 if(ui_page == 1)
  116.                 {
  117.                         set_pos ++;
  118.                         if(set_pos > 3)
  119.                                 set_pos = 0;
  120.                 }
  121.         }
  122. }
  123. /**
  124.   * @brief   检查当前温湿度的状态
  125.   *          如果温度大于设定值,控制减温器继电器打开,如果温度小于设定值,控制升温器继电器打开。
  126.   *          如果湿度大于设定值,控制减湿器继电器打开,如果湿度小于设定值,控制加湿器继电器打开。
  127.   * @param
  128.   * @retval  void
  129. **/
  130. void ControlRelay()
  131. {
  132.         if(temperature > temp_high)
  133.         {
  134.                 reduce_temp = 1;add_temp = 0;
  135.         }else if(temperature < temp_low)
  136.         {
  137.                 reduce_temp = 0;add_temp = 1;
  138.         }else
  139.         {
  140.                 reduce_temp = 0;add_temp = 0;
  141.         }
  142.
  143.         if(humidity > hum_high)
  144.         {
  145.                 reduce_hum = 1;add_hum = 0;
  146.         }else if(humidity < hum_low)
  147.         {
  148.                 reduce_hum = 0;add_hum = 1;
  149.         }else
  150.         {
  151.                 reduce_hum = 0;add_hum = 0;
  152.         }
  153. }
仿真程序下载: 基于51单片机的智能温湿度大棚设计.7z (98.87 KB, 下载次数: 0)
收藏收藏3 分享淘帖 顶 踩
