查看: 1390|回复: 5
在原理图基础上添加蜂鸣器 怎么修改电路以及单片机代码?
ID:1125014 发表于 2025-12-21 14:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
80黑币
在原图基础上添加蜂鸣器,运行完蜂鸣器报警,代码:
  1. #include <reg52.H>#include <intrins.h>
  2. #define uchar   unsigned char
  3. #define uint    unsigned int
  4. sbit LCD_RS = P2^0;
  5. sbit LCD_RW = P2^1;
  6. sbit LCD_EN = P2^2;
  7. #define LCD_DATA P0
  8. void delayms(unsigned int x);
  9. uint key(void);
  10. void deplay(uchar j_p);
  11. void deplay_s(long a);
  12. void lcd_wcmd(uchar cmd);
  13. void lcd_wdat(uchar dat);
  14. void lcd_init(void);
  15. void lcd_clr(void);
  16. void show_error(void);
  17. long  a = 0, b = 0;
  18. uchar flat = 0;
  19. bit   neg_flag = 0;
  20. void delayms(unsigned int x)
  21. {
  22.     uchar i;
  23.     while(x--)
  24.     {
  25.         for(i = 0; i < 120; i++);
  26.     }
  27. }
  28. void lcd_wcmd(uchar cmd)
  29. {
  30.     LCD_RS = 0;
  31.     LCD_RW = 0;
  32.     LCD_DATA = cmd;
  33.     delayms(1);
  34.     LCD_EN = 1;
  35.     delayms(1);
  36.     LCD_EN = 0;
  37. }
  38. void lcd_wdat(uchar dat)
  39. {
  40.     LCD_RS = 1;
  41.     LCD_RW = 0;
  42.     LCD_DATA = dat;
  43.     delayms(1);
  44.     LCD_EN = 1;
  45.     delayms(1);
  46.     LCD_EN = 0;
  47. }
  48. void lcd_init(void)
  49. {
  50.     delayms(10);
  51.     lcd_wcmd(0x38);
  52.     lcd_wcmd(0x0c);
  53.     lcd_wcmd(0x06);
  54.     lcd_wcmd(0x01);
  55.     delayms(2);
  56. }
  57. void lcd_clr(void)
  58. {
  59.     lcd_wcmd(0x01);
  60.     delayms(2);
  61.     lcd_wcmd(0x80);
  62.     neg_flag = 0;
  63. }
  64. void show_error(void)
  65. {
  66.     lcd_clr();
  67.     lcd_wdat('e');
  68.     lcd_wdat('r');
  69.     lcd_wdat('r');
  70.     lcd_wdat('o');
  71.     delayms(1000);
  72.     lcd_clr();
  73.     a = 0; b = 0; flat = 0; neg_flag = 0;
  74. }
  75. uint key(void)
  76. {
  77.     uchar h = 0, l = 0;
  78.     uchar j_p = -1;
  79.     P1 = 0x0f;
  80.     if(P1 != 0x0f)
  81.     {
  82.         delayms(5);
  83.         if(P1 != 0x0f)
  84.         {
  85.             l = P1 & 0x0f;
  86.             P1 = 0xf0;
  87.             delayms(2);
  88.             h = P1 & 0xf0;
  89.             switch(l | h)
  90.             {
  91.                 case 0x7e: j_p = 0;    break;
  92.                 case 0x7d: j_p = 1;    break;
  93.                 case 0x7b: j_p = 2;    break;
  94.                 case 0x77: j_p = 3;    break;
  95.                 case 0xbe: j_p = 4;    break;
  96.                 case 0xbd: j_p = 5;    break;
  97.                 case 0xbb: j_p = 6;    break;
  98.                 case 0xb7: j_p = 7;    break;
  99.                 case 0xde: j_p = 8;    break;
  100.                 case 0xdd: j_p = 9;    break;
  101.                 case 0xdb: j_p = '+';  break;
  102.                 case 0xd7: j_p = '-';  break;
  103.                 case 0xee: j_p = '=';  break;
  104.                 case 0xed: j_p = '*';  break;
  105.                 case 0xeb: j_p = '/';  break;
  106.                 case 0xe7: j_p = 'c';  break;
  107.                 case 0xec: j_p = '±';  break;
  108.                 default:   j_p = -1;   break;
  109.             }
  110.             P1 = 0x0f;
  111.             while(P1 != 0x0f)
  112.             {
  113.                 delayms(1);
  114.             }
  115.         }
  116.     }
  117.     return j_p;
  118. }
  119. void deplay(uchar j_p)
  120. {
  121.     if(j_p != -1)
  122.     {
  123.         if(j_p >= 0 && j_p <= 9)
  124.         {
  125.             j_p += 48;
  126.         }
  127.         lcd_wdat(j_p);
  128.     }
  129. }
  130. void deplay_s(long a)
  131. {
  132.     int n[20] = {0};
  133.     uint i = 0;
  134.     bit is_neg = 0;
  135.     if(a < 0)
  136.     {
  137.         is_neg = 1;
  138.         a = -a;
  139.     }
  140.     if(a == 0)
  141.     {
  142.         deplay(0);
  143.         return;
  144.     }
  145.     while(a)
  146.     {
  147.         n[i] = a % 10;
  148.         a /= 10;
  149.         i++;
  150.     }
  151.     if(is_neg)
  152.     {
  153.         lcd_wdat('-');
  154.     }
  155.     while(i > 0)
  156.     {
  157.         deplay(n[--i]);
  158.     }
  159. }
  160. void main(void)
  161. {
  162.     uchar jp = -1;
  163.     delayms(20);
  164.     lcd_init();
  165.     lcd_clr();
  166.     while(1)
  167.     {
  168.         jp = -1;
  169.         while(jp == -1)
  170.         {
  171.             jp = key();
  172.         }
  173.         if(jp == 'c')
  174.         {
  175.             a = 0;
  176.             b = 0;
  177.             flat = 0;
  178.             neg_flag = 0;
  179.             lcd_clr();
  180.             jp = -1;
  181.             continue;
  182.         }
  183.         if(jp != '±')
  184.         {
  185.             deplay(jp);
  186.         }
  187.         switch(jp)
  188.         {
  189.             case '=':
  190.                 switch(flat)
  191.                 {
  192.                     case '+': a = b + a; break;
  193.                     case '-': a = b - a; break;
  194.                     case '*': a = (long)b * a; break;
  195.                     case '/':
  196.                         if(a != 0)
  197.                             a = b / a;
  198.                         else
  199.                             show_error();
  200.                         break;
  201.                     default: break;
  202.                 }
  203.                 deplay_s(a);
  204.                 neg_flag = 0;
  205.                 break;
  206.             case '+': flat = '+'; b = a; a = 0; neg_flag = 0; break;
  207.             case '-': flat = '-'; b = a; a = 0; neg_flag = 0; break;
  208.             case '*': flat = '*'; b = a; a = 0; neg_flag = 0; break;
  209.             case '/': flat = '/'; b = a; a = 0; neg_flag = 0; break;
  210.             case '±':
  211.                 neg_flag = !neg_flag;
  212.                 a = -a;
  213.                 lcd_clr();
  214.                 deplay_s(a);
  215.                 break;
  216.             case 0: case 1: case 2: case 3: case 4:
  217.             case 5: case 6: case 7: case 8: case 9:
  218.                 if(!neg_flag && a >= 100)
  219.                 {
  220.                     show_error();
  221.                     break;
  222.                 }
  223.                 if(neg_flag && a <= -100)
  224.                 {
  225.                     show_error();
  226.                     break;
  227.                 }
  228.                 if(neg_flag)
  229.                 {
  230.                     a = a * 10 - jp;
  231.                 }
  232.                 else
  233.                 {
  234.                     a = a * 10 + jp;
  235.                 }
  236.                 break;
  237.             default: break;
  238.         }
  239.         jp = -1;
  240.     }
  241. }
ID:235200 发表于 2025-12-21 16:25 | 只看该作者
你这个运行完就没有描述清楚,单片机程序是循环运行的,永远不会运行完成,只是在运行时不断检测状态的变化,加上蜂鸣器报警,报什么警呢?也许你想的情况是单片机不运行了(死机)报警,而报警也是只有单片机运行时才能报警(控制蜂鸣器的驱动电流发生变化),所以你这样的问题无解
ID:1159343 发表于 2025-12-22 08:08 | 只看该作者
应该是按键有输入时蜂鸣器响一下吧,拿一个输出接蜂鸣器,程序里检测到按键有动作就给蜂鸣器一个短时间的信号。
ID:1125014 发表于 2025-12-22 15:04 | 只看该作者
不用了,我自己昨天改完了
ID:584814 发表于 2025-12-22 15:52 | 只看该作者
mjnwlp 发表于 2025-12-22 15:04
不用了,我自己昨天改完了
是猴子派来一逗13的么
ID:877505 发表于 2025-12-23 15:03 | 只看该作者
是不是可以加个三极管,一头接所有按键,一头接蜂鸣器,只要有一个按键按下,硬件那一块就导通了,然后蜂鸣器就通电叫起来,所有按键都么按下,蜂鸣器断开不叫
