查看: 972|回复: 2
大佬帮忙看一下,我这个代码到底哪里写错了?智能小车它一直运行的非常卡顿
ID:1164343 发表于 2025-12-27 19:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include <intrins.h>
sbit Trig2 = P2^5;
sbit Echo2 = P2^4;
sbit Trig1 = P2^7;
sbit Echo1 = P2^6;
sbit Trig3 = P2^3;
sbit Echo3 = P2^2;
sbit AIN1 = P0^0;
sbit AIN2 = P0^1;
sbit PWMA = P1^0;
sbit BIN1 = P0^2;
sbit BIN2 = P0^3;
sbit PWMB = P1^1;
sbit AIN1_Front = P0^5;
sbit AIN2_Front = P0^4;
sbit PWMA_Front = P1^2;
sbit BIN1_Front = P0^7;
sbit BIN2_Front = P0^6;
sbit PWMB_Front = P1^3;
#define STOP_DISTANCE 20
#define MAX_DISTANCE 400
void Delay10us(unsigned int us)
    while(us--) {
        _nop_(); _nop_(); _nop_(); _nop_(); _nop_();
void Timer0_Init(void)
    TMOD &= 0xF0;
    TMOD |= 0x01;
    TH0 = 0;
    TL0 = 0;
    ET0 = 0;
    TR0 = 0;
        void Delay_ms(unsigned int ms) {
    unsigned int i, j;
    for(i = 0; i < ms; i++) {
        for(j = 0; j < 120; j++) {
void Delay_ms(unsigned int ms);
unsigned int Get_Distance2(void);
unsigned int Get_Distance1(void);
unsigned int Get_Distance3(void);
void Motor_Stop(void);
void Turn1(void);
void Turn3(void);
void Motor_Forward(void);
unsigned int Get_Distance2(void) {
    unsigned int time_val = 0;
    unsigned int timeout = 50000;
    Trig2 = 1;
    Delay10us(2);
    Trig2 = 0;
    while(!Echo2 && timeout--) {
        if(timeout == 0) return MAX_DISTANCE;
    TR0 = 1;
    TH0 = 0;
    TL0 = 0;
    timeout = 50000;
    while(Echo2 && timeout--) {
        if(timeout == 0) {
            TR0 = 0;
    TR0 = 0;
    time_val = (TH0 << 8) | TL0;
    TH0 = 0;
    TL0 = 0;
    time_val = time_val / 63;
    if(time_val > MAX_DISTANCE) time_val = MAX_DISTANCE;
    return time_val;
unsigned int Get_Distance1 (void) {
    Trig1 = 1;
    Delay10us(2);
    Trig1 = 0;
    while(!Echo1 && timeout) {
        timeout--;
    if(timeout == 0) {
        TR0 = 0;
    TH0 = 0; TL0 = 0; TF0 = 0;
    TR0 = 1;
    timeout = 50000;
    while(Echo1 && timeout) {
        timeout--;
    TR0 = 0;
    TH0 = 0; TL0 = 0;
    return time_val;
unsigned int Get_Distance3(void) {
    Trig3 = 1;
    Delay10us(2);
    Trig3 = 0;
    while(!Echo3 && timeout) {
        timeout--;
    if(timeout == 0) {
        TR0 = 0;
    TR0 = 1;
    timeout = 50000;
    while(Echo3 && timeout) {
        timeout--;
    TR0 = 0;
    TH0 = 0; TL0 = 0;
    return time_val;
void Turn1(void) {
    AIN1 = 0; AIN2 = 0; PWMA = 0;
    BIN1 = 1; BIN2 = 0; PWMB = 1;
    AIN1_Front = 0; AIN2_Front = 1; PWMA_Front = 1;
    BIN1_Front = 1; BIN2_Front = 0; PWMB_Front = 1;
void Turn3(void) {
    AIN1 = 1; AIN2 = 0; PWMA = 1;
    BIN1 = 0; BIN2 = 0; PWMB = 0;
    AIN1_Front = 1; AIN2_Front = 0; PWMA_Front = 1;
    BIN1_Front = 0; BIN2_Front = 1; PWMB_Front = 1;
void Motor_Forward(void) {
    AIN1 = 0; AIN2 = 0;
    BIN1 = 0; BIN2 = 0;
    PWMA = 0; PWMB = 0;
    AIN1_Front = 0; AIN2_Front = 0;
    BIN1_Front = 0; BIN2_Front = 0;
    PWMA_Front = 0; PWMB_Front = 0;
void main(void) {
    unsigned int dist1, dist2, dist3;
    Timer0_Init();
    Motor_Stop();
    Delay_ms(1000);
    while(1) {
        dist2 = Get_Distance2();
        Delay_ms(30);
        dist1 = Get_Distance1();
        Delay_ms(30);
        dist3 = Get_Distance3();
        Delay_ms(30);
        if(dist2 < STOP_DISTANCE) {
            Motor_Stop();
            Delay_ms(200);
            if(dist1 > dist3) {
                Turn1();
                Delay_ms(400);
                Motor_Stop();
                Delay_ms(100);
            } else {
                Turn3();
                Delay_ms(400);
                Motor_Stop();
                Delay_ms(100);
            Motor_Forward();
            Delay_ms(500);
        } else if(dist1 < (STOP_DISTANCE / 2))
            Turn3();
            Delay_ms(100);
        } else if(dist3 < (STOP_DISTANCE / 2))
            Turn1();
            Delay_ms(100);
        } else {
            Motor_Forward();
        Delay_ms(100);
ID:857072 发表于 2025-12-28 08:38 来自触屏版 | 只看该作者
Delay_ms()不要用了就好99%了。
ID:1164343 发表于 2025-12-28 13:46 | 只看该作者
能具体讲一下是哪个有问题吗
