查看: 1681|回复: 9
STC8Hec11单片机控制电子音量M62429基础版刚调通 KEIL5程序
#define KEY_COUNT_DESHAKING 15//按键消抖时间15MS
#define KEY_COUNT_LONGT 1500//长按按键判断时间1500MS
#define KEY_COUNT_DUAL 180//双击按键判断时间180MS
#define KEY_LONG_REPEAT 200//长按按键时响应的时间间隔200MS
#define I2C_SCL P3_2
#define I2C_SDA P3_3
#define led P5_4
#include <STC8HX.h>
uint32 sys_clk = 12000000;//设置PWM、定时器、串口、EEPROM频率参数
#include "Lib/EC11_51.h"//声明库头文件
#include "delay.h"
uint8 i = 0;
uint8 j = 0;
uint8 k = 20;
uint16 vol = 0;
uint8 flag = 0;
uint8 cnt = 0;
uint16 mylist[21]={0x88aa,0x8aa,0xa0aa,0x20aa,0x80aa,0xaa,0xaa2a,0x2a2a,0x8a2a,0xa2a,0xa22a, 0x222a,0x822a,0x22a,0xa82a,0xa282a,0x882a,0x82a,0xa02a,0x202a,0x802a};
uint8 dat = 0x2f;
uint16 scl_dat = 0xaa;
uint8 scl_dat2 = 0x01;
uint8 LR = 0x02;
uint8 jianhc_A1;
void sendbyte_LR();
void sendbyte_dat();
void sendbyte_3();
void Timer1Init(void)        //1000微秒@12.000MHz
  AUXR &= 0xbf;                //定时器时钟12T模式
  TMOD &= 0x0f;                //设置定时器模式
  TL1 = 0x18;                        //设定定时初值
  TH1 = 0xfc;                        //设定定时初值
void Timer0Init(void)        //1000微秒@12.000MHz
  AUXR &= 0x7f;                //定时器时钟12T模式
  TMOD &= 0xf0;                //设置定时器模式
  TL0 = 0x18;                        //设定定时初值
  TH0 = 0xfc;                        //设定定时初值
void T_IRQ0(void) interrupt 1 using 1{
  cnt = cnt + 1;
xdata tongdaoHC HC_A1 = {0,0,0,0,0,0,0};//声明A1通道全局结构体缓存
void T_IRQ1(void) interrupt 3 using 2{
   HC_A1.EC11_A_dq = P3_5;
   HC_A1.EC11_B_dq = P3_6;
   HC_A1.EC11_D_dq = P3_4;
   jianhc_A1 = Encoder_EC11_Scan(&HC_A1);
   switch ( jianhc_A1)
      case 1:
         if(k >= 1){
      k = k - 1;
    else{
      k = k - 0;
       break;
      case 2:
         if(k >= 1){
      k = k - 1;
    else{
      k = k - 0;
       break;
      case 3:
         if(k <= 20){
      k = k + 1;
    else{
      k = k + 0;
       break;
      case 4:
         if(k <= 20){
      k = k + 1;
    else{
      k = k + 0;
       break;
      case 5:
         led = !led;
    if(k >= 1){
      k = k - 1;
    else{
      k = k - 0;
       break;
      case 6:
            break;
      case 7:
            break;
      case 8:
            break;
/*描述该功能...
void sendbyte_LR(){
  for (i = 0; i < 1; i = i + 1) {
    I2C_SDA = 1;
    delay5us();
    I2C_SCL = 1;
    delay5us();
    I2C_SDA = 0;
    delay5us();
    I2C_SCL = 0;
    delay5us();
    delay5us();
    I2C_SCL = 1;
    delay5us();
    delay5us();
    I2C_SCL = 0;
    delay5us();
/*描述该功能...
void sendbyte_dat(){
  EA = 0;
  sendbyte_LR();
  for (j = 0; j < 16; j = j + 1) {
    if((vol&0x8000) != 0){
      P3_3 = 1;
    else{
      P3_3 = 0;
    vol = (vol<<1);
    delay1us();
    delay1us();
    if((scl_dat&0x8000) != 0){
      P3_2 = 1;
    else{
      P3_2 = 0;
    scl_dat = (scl_dat<<1);
    delay5us();
  sendbyte_3();
  EA = 1;
/*描述该功能...
void sendbyte_3(){
  I2C_SCL = 0;
  delay1us();
  delay1us();
  I2C_SDA = 1;
  delay1us();
  delay1us();
  I2C_SCL = 1;
  delay5us();
  I2C_SDA = 1;
  delay5us();
  I2C_SCL = 0;
  delay1us();
  delay1us();
  I2C_SDA = 0;
  delay5us();
void setup()
  P3M1&=~0x04;P3M0|=0x04;//推挽输出
  P3M1&=~0x08;P3M0|=0x08;//推挽输出
  P3M1&=~0x10;P3M0&=~0x10;//双向IO口
  P5M1&=~0x10;P5M0|=0x10;//推挽输出
  P3_3 = 0;
  P5_4 = 1;
  Timer1Init();
  EA = 1; // 控制总中断
  ET1 = 1; // 控制定时器中断
  TR1 = 1;// 定时器1开始计时
  Timer0Init();
  EA = 1; // 控制总中断
  ET0 = 1; // 控制定时器中断
  TR0 = 1;// 定时器0开始计时
  P3M1|=0x10;P3M0&=~0x10;//P3_4高阻输入
  P3M1|=0x40;P3M0&=~0x40;//P3_6高阻输入
  P3M1|=0x20;P3M0&=~0x20;//P3_5高阻输入
void loop()
  if(cnt >= 200){
    cnt = 0;
    vol = mylist[(int)(k)];
    scl_dat = 0xaaaa;
    sendbyte_dat();
void main(void)
  setup();
  while(1){
    loop();
以上代码下载: M62429.zip (143.64 KB, 下载次数: 0)
参与人数 2黑币 +20 收起 理由
lisky123 + 10 共享资料的奖励!
jialishoushi + 10 共享资料的奖励!
收藏收藏5 分享淘帖 顶 踩
ID:303735 发表于 2026-1-13 11:00 | 只看该作者
开始时序没弄好一直没反应,还有数据转换一直没办法,只能写数组调用,先将就21个档用吧,如果网友有更好的办法欢迎指导
ID:303735 发表于 2026-1-13 11:12 | 只看该作者
现在能控制音量,首次上电音量最小,可以按按键P3.4慢慢增加到-0dB音量最大。后续再增加功能。
ID:303735 发表于 2026-1-13 13:49 | 只看该作者
EC11反转写的有误作修改
   switch ( jianhc_A1)
      case 1:
         if(k >= 1){
      k = k - 1;
    else{
      k = k - 0;
       break;
      case 2:
         if(k <= 20){
      k = k + 1;
    else{
      k = k + 0;
       break;
      case 3:
         if(k >= 1){
      k = k - 1;
    else{
      k = k - 0;
       break;
      case 4:
         if(k <= 20){
      k = k + 1;
    else{
      k = k + 0;
       break;
      case 5:
         led = !led;
    if(k >= 1){
      k = k - 1;
    else{
      k = k - 0;
       break;
      case 6:
            break;
      case 7:
            break;
      case 8:
            break;
ID:876947 发表于 2026-1-14 09:14 | 只看该作者
这个有创意非常适用
ID:303735 发表于 2026-1-14 09:23 | 只看该作者
白水大虾2016 发表于 2026-1-14 09:14
这个有创意非常适用
以前是个老音响DIY发烧友,DIY很多功放包括数字功放,音量电位器一直是个软肋,一直想搞个数字音量电位器不会写程序,这两年学了单片机后才把这个梦想实现了。
ID:876947 发表于 2026-1-15 09:00 | 只看该作者
liqingyong 发表于 2026-1-14 09:23
以前是个老音响DIY发烧友,DIY很多功放包括数字功放,音量电位器一直是个软肋,一直想搞个数字音量电位器 ...
咱俩同行
ID:303735 发表于 2026-1-15 10:05 | 只看该作者
ID:996773 发表于 2026-2-28 14:03 | 只看该作者
编程天才路过,我目前为止只学了四五年,这是两年前完工的,也是m62429,共80级数控,楼主在程序上可以
做个定时五分钟将音量数值写入掉电存储的eeprom,这样下回通电就是常用音量值,最人性化还可以限制在50级以下
存储,防止开机最大音量
ID:996773 发表于 2026-2-28 14:13 | 只看该作者
补上主板图,这是三年前刚学打板,现在看来已经很土冒了,直角走线是不规范的,当时不懂,
24c02是个摆设不中用,已经使用单片机的eeprom存储,三菱的M62429
