查看: 415|回复: 0
AD7799驱动函数 和头文件
ID:1169190 发表于 2026-4-3 11:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*   @file   ad7779.c
#include <stdio.h>
#include <stdlib.h>
#include "ad7779.h"
#include "no_os_util.h"
#include "no_os_error.h"
#include "no_os_alloc.h"
const uint8_t pin_mode_options[16][4] = {
        /*GAIN_1, GAIN_2, GAIN_4, GAIN_8 */
        {0x03,        0xFF,        0x07,        0xFF},        // DEC_RATE_128, HIGH_RES, EXT_REF
        {0x0A,        0xFF,        0xFF,        0xFF},        // DEC_RATE_128, HIGH_RES, INT_REF
        {0x0D,        0xFF,        0xFF,        0xFF},        // DEC_RATE_128, LOW_PWR, EXT_REF
        {0x0E,        0xFF,        0xFF,        0xFF},        // DEC_RATE_128, LOW_PWR, INT_REF
        {0x02,        0x04,        0x06,        0xFF},        // DEC_RATE_256, HIGH_RES, EXT_REF
        {0x09,        0xFF,        0xFF,        0xFF},        // DEC_RATE_256, HIGH_RES, INT_REF
        {0x0C,        0xFF,        0xFF,        0xFF},        // DEC_RATE_256, LOW_PWR, EXT_REF
        {0x0F,        0xFF,        0xFF,        0xFF},        // DEC_RATE_256, LOW_PWR, INT_REF
        {0x01,        0xFF,        0x05,        0xFF},        // DEC_RATE_512, HIGH_RES, EXT_REF
        {0x08,        0xFF,        0xFF,        0xFF},        // DEC_RATE_512, HIGH_RES, INT_REF
        {0x08,        0xFF,        0xFF,        0xFF},        // DEC_RATE_512, LOW_PWR, EXT_REF
        {0xFF,        0xFF,        0xFF,        0xFF},        // DEC_RATE_512, LOW_PWR, INT_REF
        {0x00,        0xFF,        0xFF,        0xFF},        // DEC_RATE_1024, HIGH_RES, EXT_REF
        {0xFF,        0xFF,        0xFF,        0xFF},        // DEC_RATE_1024, HIGH_RES, INT_REF
        {0xFF,        0xFF,        0xFF,        0xFF},        // DEC_RATE_1024, LOW_PWR, EXT_REF
        {0xFF,        0xFF,        0xFF,        0xFF},        // DEC_RATE_1024, LOW_PWR, INT_REF
* Compute CRC8 checksum.
* @param data - The data buffer.
* @param data_size - The size of the data buffer.
* @return CRC8 checksum.
uint8_t ad7779_compute_crc8(uint8_t *data,
                            uint8_t data_size)
        uint8_t i;
        uint8_t crc = 0;
        while (data_size) {
                for (i = 0x80; i != 0; i >>= 1) {
                        if (((crc & 0x80) != 0) != ((*data & i) != 0)) {
                                crc <<= 1;
                                crc ^= AD7779_CRC8_POLY;
                        } else
                                crc <<= 1;
                data++;
                data_size--;
        return crc;
* SPI internal register read from device.
* @param dev - The device structure.
* @param reg_addr - The register address.
* @param reg_data - The register data.
* @return 0 in case of success, negative error code otherwise.
int32_t ad7779_spi_int_reg_read(ad7779_dev *dev,
                                uint8_t reg_addr,
                                uint8_t *reg_data)
        uint8_t buf[3];
        uint8_t buf_size = 2;
        uint8_t crc;
        int32_t ret;
        buf[0] = 0x80 | (reg_addr & 0x7F);
        buf[1] = 0x00;
        buf[2] = 0x00;
        if (dev->spi_crc_en == AD7779_ENABLE)
                buf_size = 3;
        ret = no_os_spi_write_and_read(dev->spi_desc, buf, buf_size);
        *reg_data = buf[1];
        if (dev->spi_crc_en == AD7779_ENABLE) {
                crc = ad7779_compute_crc8(&buf[0], 2);
                if (crc != buf[2]) {
                        printf("%s: CRC Error.\n", __func__);
                        ret = -1;
        return ret;
* SPI internal register write to device.
int32_t ad7779_spi_int_reg_write(ad7779_dev *dev,
                                 uint8_t reg_addr,
                                 uint8_t reg_data)
        uint8_t buf[3];
        int32_t ret;
        buf[0] = 0x00 | (reg_addr & 0x7F);
        buf[1] = reg_data;
                buf[2] = ad7779_compute_crc8(&buf[0], 2);
                buf_size = 3;
        dev->cached_reg_val[reg_addr] = reg_data;
        return ret;
* SPI internal register read from device using a mask.
* @param mask - The mask.
* @param data - The register data.
int32_t ad7779_spi_int_reg_read_mask(ad7779_dev *dev,
                                     uint8_t reg_addr,
                                     uint8_t mask,
                                     uint8_t *data)
        uint8_t reg_data;
        int32_t ret;
        ret = ad7779_spi_int_reg_read(dev, reg_addr, &reg_data);
        *data = (reg_data & mask);
        return ret;
* SPI internal register write to device using a mask.
int32_t ad7779_spi_int_reg_write_mask(ad7779_dev *dev,
                                      uint8_t reg_addr,
                                      uint8_t mask,
                                      uint8_t data)
        uint8_t reg_data;
        int32_t ret;
        reg_data = dev->cached_reg_val[reg_addr];
        reg_data &= ~mask;
        reg_data |= data;
        ret = ad7779_spi_int_reg_write(dev, reg_addr, reg_data);
        return ret;
* SPI SAR conversion code read.
* @param mux_next_conv - The SAR mux input configuration for the next
*                          conversion.
*                          Accepted values: AD7779_AUXAINP_AUXAINN
*                                           AD7779_DVBE_AVSSX
*                                           AD7779_REF1P_REF1N
*                                           AD7779_REF2P_REF2N
*                                           AD7779_REF_OUT_AVSSX
*                                           AD7779_VCM_AVSSX
*                                           AD7779_AREG1CAP_AVSSX_ATT
*                                           AD7779_AREG2CAP_AVSSX_ATT
*                                           AD7779_DREGCAP_DGND_ATT
*                                           AD7779_AVDD1A_AVSSX_ATT
*                                           AD7779_AVDD1B_AVSSX_ATT
*                                           AD7779_AVDD2A_AVSSX_ATT
*                                           AD7779_AVDD2B_AVSSX_ATT
*                                           AD7779_IOVDD_DGND_ATT
*                                           AD7779_AVDD4_AVSSX
*                                           AD7779_DGND_AVSS1A_ATT
*                                           AD7779_DGND_AVSS1B_ATT
*                                           AD7779_DGND_AVSSX_ATT
*                                           AD7779_AVDD4_AVSSX_ATT
*                                           AD7779_REF1P_AVSSX
*                                           AD7779_REF2P_AVSSX
*                                           AD7779_AVSSX_AVDD4_ATT
* @param sar_code - SAR conversion code.
int32_t ad7779_spi_sar_read_code(ad7779_dev *dev,
                                 ad7779_sar_mux mux_next_conv,
                                 uint16_t *sar_code)
        uint8_t buf[3];
        uint8_t crc;
        int32_t ret;
        buf[0] = 0x00 | (AD7779_REG_GLOBAL_MUX_CONFIG & 0x7F);
        buf[1] = AD7779_GLOBAL_MUX_CTRL(mux_next_conv);
                buf_size = 3;
        dev->cached_reg_val[AD7779_REG_GLOBAL_MUX_CONFIG] =
        buf[0] = buf[0] & 0x0F;
        *sar_code = (buf[0] << 8) | buf[1];
                        ret = -1;
        return ret;
* Set SPI operation mode.
* @param mode - The SPI operation mode.
*                 Accepted values: AD7779_INT_REG
*                                  AD7779_SD_CONV
*                                  AD7779_SAR_CONV
int32_t ad7779_set_spi_op_mode(ad7779_dev *dev,
                               ad7779_spi_op_mode mode)
        int32_t ret;
        uint8_t cfg_2;
        uint8_t cfg_3;
        switch (mode) {
        case AD7779_SD_CONV:
                cfg_2 = 0;
                cfg_3 = AD7779_SPI_SLAVE_MODE_EN;
                break;
        case AD7779_SAR_CONV:
                cfg_2 = AD7779_SAR_DIAG_MODE_EN;
                cfg_3 = 0;
                break;
        default:        // AD7779_INT_REG
                cfg_2 = 0;
                cfg_3 = 0;
        ret = ad7779_spi_int_reg_write_mask(dev,
                                            AD7779_REG_GENERAL_USER_CONFIG_2,
                                            AD7779_SAR_DIAG_MODE_EN,
                                            cfg_2);
        ret |= ad7779_spi_int_reg_write_mask(dev,
                                             AD7779_REG_GENERAL_USER_CONFIG_3,
                                             AD7779_SPI_SLAVE_MODE_EN,
                                             cfg_3);
        dev->spi_op_mode = mode;
        return ret;
* Get SPI operation mode.
int32_t ad7779_get_spi_op_mode(ad7779_dev *dev,
                               ad7779_spi_op_mode *mode)
        int32_t ret;
        uint8_t cfg_2;
        uint8_t cfg_3;
        uint8_t reg_data;
        if (!dev->read_from_cache) {
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_GENERAL_USER_CONFIG_2, &reg_data);
                if (ret)
                        return ret;
                cfg_2 = no_os_field_get(AD7779_SAR_DIAG_MODE_EN, reg_data);
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_GENERAL_USER_CONFIG_3,
                                              &reg_data);
                if (ret)
                        return ret;
                cfg_3 = no_os_field_get(AD7779_SPI_SLAVE_MODE_EN, reg_data);
                if ((cfg_2 == 0) && (cfg_3 == 1))
                        *mode = AD7779_SD_CONV;
                else if ((cfg_3 == 0) && (cfg_2 == 1))
                        *mode = AD7779_SAR_CONV;
                        *mode = AD7779_INT_REG;
        } else {
                *mode = dev->spi_op_mode;
        return 0;
* Update the state of the MODEx pins according to the settings specified in
* the device structure.
int32_t ad7779_do_update_mode_pins(ad7779_dev *dev)
        int32_t ret;
        uint8_t option_index;
        uint8_t mode;
        if (!(dev->gain[AD7779_CH0] == dev->gain[AD7779_CH1] &&
              dev->gain[AD7779_CH1] == dev->gain[AD7779_CH2] &&
              dev->gain[AD7779_CH2] == dev->gain[AD7779_CH3] &&
              dev->gain[AD7779_CH3] == AD7779_GAIN_1))
                goto error;
        if (!(dev->gain[AD7779_CH4] == dev->gain[AD7779_CH5] &&
              dev->gain[AD7779_CH5] == dev->gain[AD7779_CH6] &&
              dev->gain[AD7779_CH6] == dev->gain[AD7779_CH7]))
                goto error;
        switch (dev->dec_rate_int) {
        case 128:
                option_index = 0;
                break;
        case 256:
                option_index = 4;
                break;
        case 512:
                option_index = 8;
                break;
        case 1024:
                option_index = 12;
                break;
        default:
                goto error;
        if (dev->pwr_mode == AD7779_HIGH_RES)
                if (dev->ref_type == AD7779_EXT_REF)
                        mode = pin_mode_options[option_index + 0][dev->gain[AD7779_CH4]];
                        mode = pin_mode_options[option_index + 1][dev->gain[AD7779_CH4]];
        else if (dev->ref_type == AD7779_EXT_REF)
                mode = pin_mode_options[option_index + 2][dev->gain[AD7779_CH4]];
                mode = pin_mode_options[option_index + 3][dev->gain[AD7779_CH4]];
        if (mode == 0xFF)
                goto error;
        ret = no_os_gpio_set_value(dev->gpio_mode0,
                                   ((mode & 0x01) >> 0));
        ret |= no_os_gpio_set_value(dev->gpio_mode1,
                                    ((mode & 0x02) >> 1));
        ret |= no_os_gpio_set_value(dev->gpio_mode2,
                                    ((mode & 0x04) >> 2));
        ret |= no_os_gpio_set_value(dev->gpio_mode3,
                                    ((mode & 0x08) >> 3));
        /* All the pins that define the AD7779 configuration mode are re-evaluated
         * every time SYNC_IN pin is pulsed. */
        ret |= no_os_gpio_set_value(dev->gpio_sync_in, NO_OS_GPIO_LOW);
        no_os_mdelay(10);
        ret |= no_os_gpio_set_value(dev->gpio_sync_in, NO_OS_GPIO_HIGH);
        return ret;
error:
        printf("%s: This setting can't be set in PIN control mode.\n",
               __func__);
        return -1;
* Set the state (enable, disable) of the channel.
* @param ch - The channel number.
*               Accepted values: AD7779_CH0
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
* @param state - The channel state.
*                  Accepted values: AD7779_ENABLE
*                                   AD7779_DISABLE
int32_t ad7779_set_state(ad7779_dev *dev,
                         ad7779_ch ch,
                         ad7779_state state)
        int32_t ret;
                                            AD7779_REG_CH_DISABLE,
                                            AD7779_CH_DISABLE(ch),
                                            state ? AD7779_CH_DISABLE(ch) : 0);
        dev->state[ch] = state;
        return ret;
* Get the state (enable, disable) of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
int32_t ad7779_get_state(ad7779_dev *dev,
                         ad7779_ch ch,
                         ad7779_state *state)
        int32_t ret;
        uint8_t reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_DISABLE, &reg_data);
                if (ret)
                        return ret;
                *state = no_os_field_get(AD7779_CH_DISABLE(ch), reg_data);
        } else {
                *state = dev->state[ch];
        return 0;
* Set the gain of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
* @param gain - The gain value.
*                 Accepted values: AD7779_GAIN_1
*                                  AD7779_GAIN_2
*                                  AD7779_GAIN_4
*                                  AD7779_GAIN_8
int32_t ad7779_set_gain(ad7779_dev *dev,
                        ad7779_ch ch,
                        ad7779_gain gain)
        int32_t ret;
        if (dev->ctrl_mode == AD7779_PIN_CTRL) {
                if (ch <= AD7779_CH3) {
                        dev->gain[AD7779_CH0] = gain;
                        dev->gain[AD7779_CH1] = gain;
                        dev->gain[AD7779_CH2] = gain;
                        dev->gain[AD7779_CH3] = gain;
                } else {
                        dev->gain[AD7779_CH4] = gain;
                        dev->gain[AD7779_CH5] = gain;
                        dev->gain[AD7779_CH6] = gain;
                        dev->gain[AD7779_CH7] = gain;
                ret = ad7779_do_update_mode_pins(dev);
        } else {
                dev->gain[ch] = gain;
                                                    AD7779_REG_CH_CONFIG(ch),
                                                    AD7779_CH_GAIN(0x3),
                                                    AD7779_CH_GAIN(gain));
        return ret;
* Get the gain of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
int32_t ad7779_get_gain(ad7779_dev *dev,
                        ad7779_ch ch,
                        ad7779_gain *gain)
        int32_t ret;
        uint8_t reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_CONFIG(ch), &reg_data);
                if (ret)
                        return ret;
                *gain = no_os_field_get(AD7779_CH_GAIN(0x3), reg_data);
        } else {
                *gain = dev->gain[ch];
        return 0;
* Set the decimation rate.
* @param int_val - The integer value.
* @param dec_val - The decimal value.
int32_t ad7779_set_dec_rate(ad7779_dev *dev,
                            uint16_t int_val,
                            uint16_t dec_val)
        int32_t ret;
        uint8_t msb;
        uint8_t lsb;
                switch (int_val) {
                case 128:
                        break;
                case 256:
                        break;
                case 512:
                        break;
                case 1024:
                        break;
                default:
                               __func__);
                        return -1;
                dev->dec_rate_int = int_val;
                dev->dec_rate_dec = dec_val;
        } else {
                msb = (int_val & 0x0F00) >> 8;
                lsb = (int_val & 0x00FF) >> 0;
                                               AD7779_REG_SRC_N_MSB,
                                               msb);
                ret |= ad7779_spi_int_reg_write(dev,
                                                AD7779_REG_SRC_N_LSB,
                                                lsb);
                dec_val = (dec_val * 65536) / 1000;
                msb = (dec_val & 0xFF00) >> 8;
                lsb = (dec_val & 0x00FF) >> 0;
                                                AD7779_REG_SRC_IF_MSB,
                                                msb);
                                                AD7779_REG_SRC_IF_LSB,
                                                lsb);
        return ret;
* Get the decimation rate.
int32_t ad7779_get_dec_rate(ad7779_dev *dev,
                            uint16_t *int_val,
                            uint16_t *dec_val)
        int32_t ret;
        uint8_t reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_SRC_IF_LSB, &reg_data);
                if (ret)
                        return ret;
                *dec_val = reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_SRC_IF_MSB, &reg_data);
                if (ret)
                        return ret;
                *dec_val |= reg_data << 8;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_SRC_N_LSB, &reg_data);
                if (ret)
                        return ret;
                *int_val = reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_SRC_N_MSB, &reg_data);
                if (ret)
                        return ret;
                *int_val |= reg_data << 8;
                *dec_val = *dec_val * 1000 / 65536;
        } else {
                *int_val = dev->dec_rate_int;
                *dec_val = dev->dec_rate_int;
        return 0;
* Set the power mode.
* @param pwr_mode - The power mode.
*                     Accepted values: AD7779_HIGH_RES
*                                      AD7779_LOW_PWR
int32_t ad7779_set_power_mode(ad7779_dev *dev,
                              ad7779_pwr_mode pwr_mode)
        int32_t ret;
                                            AD7779_REG_GENERAL_USER_CONFIG_1,
                                            AD7779_MOD_POWERMODE,
                                            pwr_mode ? AD7779_MOD_POWERMODE : 0);
        dev->pwr_mode = pwr_mode;
        return ret;
* Get the power mode.
int32_t ad7779_get_power_mode(ad7779_dev *dev,
                              ad7779_pwr_mode *pwr_mode)
        int32_t ret;
        uint8_t reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_GENERAL_USER_CONFIG_1, &reg_data);
                if (ret)
                        return ret;
                *pwr_mode = no_os_field_get(AD7779_MOD_POWERMODE, reg_data);
        } else {
                *pwr_mode = dev->pwr_mode;
        return 0;
* Set the reference type.
* @param ref_type - The reference type.
*                     Accepted values: AD7779_EXT_REF
*                                      AD7779_INT_REF
*                                      AD7779_EXT_SUPPLY
*                                      AD7779_EXT_REF_INV
int32_t ad7779_set_reference_type(ad7779_dev *dev,
                                  ad7779_ref_type ref_type)
        int32_t ret;
        if (ref_type == AD7779_INT_REF)
                                                    AD7779_PDB_REFOUT_BUF,
                                                    AD7779_PDB_REFOUT_BUF);
                                                    0);
        if (ret)
                return ret;
                                            AD7779_REG_ADC_MUX_CONFIG,
                                            AD7779_REF_MUX_CTRL(0x3),
                                            AD7779_REF_MUX_CTRL(ref_type));
        if (ret)
                return ret;
        dev->ref_type = ref_type;
        return 0;
* Get the reference type.
int32_t ad7779_get_reference_type(ad7779_dev *dev,
                                  ad7779_ref_type *ref_type)
        int32_t ret;
        uint8_t reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_ADC_MUX_CONFIG, &reg_data);
                if (ret)
                        return ret;
                *ref_type = no_os_field_get(AD7779_REF_MUX_CTRL(0x3), reg_data);
        } else {
                *ref_type = dev->ref_type;
        return 0;
* Set the DCLK divider.
* @param div - The DCLK divider.
*                Accepted values: AD7779_DCLK_DIV_1
*                                 AD7779_DCLK_DIV_2
*                                 AD7779_DCLK_DIV_4
*                                 AD7779_DCLK_DIV_8
*                                 AD7779_DCLK_DIV_16
*                                 AD7779_DCLK_DIV_32
*                                 AD7779_DCLK_DIV_64
*                                 AD7779_DCLK_DIV_128
int32_t ad7779_set_dclk_div(ad7779_dev *dev,
                            ad7779_dclk_div div)
        int32_t ret;
                ret = no_os_gpio_set_value(dev->gpio_dclk0,
                                           ((div & 0x01) >> 0));
                ret |= no_os_gpio_set_value(dev->gpio_dclk1,
                                            ((div & 0x02) >> 1));
                ret |= no_os_gpio_set_value(dev->gpio_dclk2,
                                            ((div & 0x04) >> 2));
        } else {
                                                    AD7779_REG_DOUT_FORMAT,
                                                    AD7779_DCLK_CLK_DIV(0x7),
                                                    AD7779_DCLK_CLK_DIV(div));
        dev->dclk_div = div;
        return ret;
* Get the DCLK divider.
int32_t ad7779_get_dclk_div(ad7779_dev *dev,
                            ad7779_dclk_div *div)
        int32_t ret;
        uint8_t reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_DOUT_FORMAT, &reg_data);
                if (ret)
                        return ret;
                *div = no_os_field_get(AD7779_DCLK_CLK_DIV(0x7), reg_data);
        } else {
                *div = dev->dclk_div;
        return 0;
* Set the synchronization offset of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
* @param sync_offset - The synchronization offset value.
int32_t ad7779_set_sync_offset(ad7779_dev *dev,
                               ad7779_ch ch,
                               uint8_t sync_offset)
        int32_t ret;
                printf("%s: This feature is not available in PIN control mode.\n",
                       __func__);
                return -1;
                                       AD7779_REG_CH_SYNC_OFFSET(ch),
                                       sync_offset);
        dev->sync_offset[ch] = sync_offset;
        return ret;
* Get the synchronization offset of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
int32_t ad7779_get_sync_offset(ad7779_dev *dev,
                               ad7779_ch ch,
                               uint8_t *sync_offset)
        int32_t ret;
        uint8_t reg_data;
                       __func__);
                return -1;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_SYNC_OFFSET(ch), &reg_data);
                if (ret)
                        return ret;
                *sync_offset = reg_data;
        } else {
                *sync_offset = dev->sync_offset[ch];
        return 0;
* Set the offset correction of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
* @param offset - The offset value.
int32_t ad7779_set_offset_corr(ad7779_dev *dev,
                               ad7779_ch ch,
                               uint32_t offset)
        int32_t ret;
        uint8_t upper_byte;
        uint8_t mid_byte;
        uint8_t lower_byte;
                       __func__);
                return -1;
        upper_byte = (offset & 0xFF0000) >> 16;
        mid_byte = (offset & 0x00FF00) >> 8;
        lower_byte = (offset & 0x0000FF) >> 0;
                                       AD7779_REG_CH_OFFSET_UPPER_BYTE(ch),
                                       upper_byte);
                                        AD7779_REG_CH_OFFSET_MID_BYTE(ch),
                                        mid_byte);
                                        AD7779_REG_CH_OFFSET_LOWER_BYTE(ch),
                                        lower_byte);
        dev->offset_corr[ch] = offset;
        return ret;
* Get the offset correction of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
int32_t ad7779_get_offset_corr(ad7779_dev *dev,
                               ad7779_ch ch,
                               uint32_t *offset)
        int32_t ret;
        uint8_t reg_data;
                       __func__);
                return -1;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_OFFSET_LOWER_BYTE(ch),
                                              &reg_data);
                if (ret)
                        return ret;
                *offset = reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_OFFSET_MID_BYTE(ch),
                                              &reg_data);
                if (ret)
                        return ret;
                *offset |= reg_data << 8;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_OFFSET_UPPER_BYTE(ch),
                                              &reg_data);
                if (ret)
                        return ret;
                *offset |= reg_data << 16;
        } else {
                *offset = dev->offset_corr[ch];
        return 0;
* Set the gain correction of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
int32_t ad7779_set_gain_corr(ad7779_dev *dev,
                             ad7779_ch ch,
                             uint32_t gain)
        int32_t ret;
        uint8_t upper_byte;
        uint8_t mid_byte;
        uint8_t lower_byte;
                       __func__);
                return -1;
        gain &= 0xFFFFFF;
        upper_byte = (gain & 0xff0000) >> 16;
        mid_byte = (gain & 0x00ff00) >> 8;
        lower_byte = (gain & 0x0000ff) >> 0;
                                       AD7779_REG_CH_GAIN_UPPER_BYTE(ch),
                                       upper_byte);
                                        AD7779_REG_CH_GAIN_MID_BYTE(ch),
                                        mid_byte);
                                        AD7779_REG_CH_GAIN_LOWER_BYTE(ch),
                                        lower_byte);
        dev->gain_corr[ch] = gain;
        return ret;
* Get the gain correction of the selected channel.
*                                AD7779_CH1
*                                AD7779_CH2
*                                AD7779_CH3
*                                AD7779_CH4
*                                AD7779_CH5
*                                AD7779_CH6
*                                AD7779_CH7
int32_t ad7779_get_gain_corr(ad7779_dev *dev,
                             ad7779_ch ch,
                             uint32_t *gain)
        int32_t ret;
        uint8_t reg_data;
                       __func__);
                return -1;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_GAIN_LOWER_BYTE(ch),
                                              &reg_data);
                if (ret)
                        return ret;
                *gain  = reg_data;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_GAIN_MID_BYTE(ch), &reg_data);
                if (ret)
                        return ret;
                *gain |= reg_data << 8;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_CH_GAIN_UPPER_BYTE(ch),
                                              &reg_data);
                if (ret)
                        return ret;
                *gain |= reg_data << 16;
        } else {
                *gain = dev->gain_corr[ch];
        return 0;
* Set the reference buffer operation mode of the selected pin.
* @param refx_pin - The selected pin.
*                     Accepted values: AD7779_REFX_P
*                                      AD7779_REFX_N
* @param mode - The reference buffer operation mode.
*                 Accepted values: AD7779_REF_BUF_ENABLED
*                                  AD7779_REF_BUF_PRECHARGED
*                                  AD7779_REF_BUF_DISABLED
int32_t ad7779_set_ref_buf_op_mode(ad7779_dev *dev,
                                   ad7779_refx_pin refx_pin,
                                   ad7779_ref_buf_op_mode mode)
        int32_t ret;
        uint8_t config_1;
        uint8_t config_2;
                       __func__);
                return -1;
        if (refx_pin == AD7779_REFX_P) {
                switch (mode) {
                case AD7779_REF_BUF_ENABLED:
                        config_1 = AD7779_REF_BUF_POS_EN;
                        config_2 = 0;
                        break;
                case AD7779_REF_BUF_PRECHARGED:
                        config_2 = AD7779_REFBUFP_PREQ;
                        break;
                default:
                        config_1 = 0;
                        config_2 = 0;
                                                    AD7779_REG_BUFFER_CONFIG_1,
                                                    AD7779_REF_BUF_POS_EN,
                                                    config_1);
                                                     AD7779_REG_BUFFER_CONFIG_2,
                                                     AD7779_REFBUFP_PREQ,
                                                     config_2);
        } else {
                switch (mode) {
                        config_1 = AD7779_REF_BUF_NEG_EN;
                        config_2 = 0;
                        break;
                        config_2 = AD7779_REFBUFN_PREQ;
                        break;
                default:
                        config_1 = 0;
                        config_2 = 0;
                                                    AD7779_REF_BUF_NEG_EN,
                                                    config_1);
                                                     AD7779_REFBUFN_PREQ,
                                                     config_2);
        dev->ref_buf_op_mode[refx_pin] = mode;
        return ret;
* Get the reference buffer operation mode of the selected pin.
*                                      AD7779_REFX_N
int32_t ad7779_get_ref_buf_op_mode(ad7779_dev *dev,
                                   ad7779_ref_buf_op_mode *mode)
        int32_t ret;
        uint8_t cfg_1;
        uint8_t cfg_2;
        uint8_t reg_data;
        uint8_t cfg_1_mask;
        uint8_t cfg_2_mask;
                       __func__);
                return -1;
                cfg_1_mask = AD7779_REF_BUF_POS_EN;
                cfg_2_mask = AD7779_REFBUFP_PREQ;
        } else {
                cfg_1_mask = AD7779_REF_BUF_NEG_EN;
                cfg_2_mask = AD7779_REFBUFN_PREQ;
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_BUFFER_CONFIG_1, &reg_data);
                if (ret)
                        return ret;
                cfg_1 = no_os_field_get(cfg_1_mask, reg_data);
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_BUFFER_CONFIG_2, &reg_data);
                if (ret)
                        return ret;
                cfg_2 = no_os_field_get(cfg_2_mask, reg_data);
                if ((cfg_1 == 1) && (cfg_2 == 0))
                        *mode = AD7779_REF_BUF_ENABLED;
                else if ((cfg_1 == 1) && (cfg_2 == 1))
                        *mode = AD7779_REF_BUF_PRECHARGED;
                else if (cfg_1 == 0 && cfg_2 == 0)
                        *mode = AD7779_REF_BUF_DISABLED;
                        return -1;
        } else {
                *mode = dev->ref_buf_op_mode[refx_pin];
        return 0;
* Set the SAR ADC configuration.
* @param state - The SAR ADC state.
*                                   AD7779_DISABLE
* @param mux - The SAR mux input configuration.
*                                 AD7779_DVBE_AVSSX
*                                 AD7779_VCM_AVSSX
int32_t ad7779_set_sar_cfg(ad7779_dev *dev,
                           ad7779_state state,
                           ad7779_sar_mux mux)
        int32_t ret;
                                            AD7779_PDB_SAR,
                                            (state == AD7779_ENABLE) ?
                                            AD7779_PDB_SAR : 0);
                                        AD7779_REG_GLOBAL_MUX_CONFIG,
                                        AD7779_GLOBAL_MUX_CTRL(mux));
        dev->sar_state = state;
        dev->sar_mux = mux;
        return ret;
* Get the SAR ADC configuration.
int32_t ad7779_get_sar_cfg(ad7779_dev *dev,
                           ad7779_state *state,
                           ad7779_sar_mux *mux)
        int32_t ret;
        uint8_t reg_data;
        uint8_t pdb_sar_val;
                                              &reg_data);
                if (ret)
                        return ret;
                pdb_sar_val = no_os_field_get(AD7779_PDB_SAR, reg_data);
                *state = (pdb_sar_val == 1 ? AD7779_ENABLE : AD7779_DISABLE);
                ret = ad7779_spi_int_reg_read(dev, AD7779_REG_GLOBAL_MUX_CONFIG, &reg_data);
                if (ret)
                        return ret;
                *mux = no_os_field_get(AD7779_GLOBAL_MUX_CTRL(0x1F), reg_data);
        } else {
                *state = dev->sar_state;
                *mux = dev->sar_mux;
        return 0;
* Do a single SAR conversion.
*                                 AD7779_DVBE_AVSSX
*                                 AD7779_VCM_AVSSX
int32_t ad7779_do_single_sar_conv(ad7779_dev *dev,
                                  ad7779_sar_mux mux,
                                  uint16_t *sar_code)
        ad7779_spi_op_mode restore_spi_op_mode;
        ad7779_state restore_sar_state;
        int32_t ret;
        restore_spi_op_mode = dev->spi_op_mode;
        restore_sar_state = dev->sar_state;
        ret = ad7779_set_sar_cfg(dev, AD7779_ENABLE, mux);
        ret |= ad7779_set_spi_op_mode(dev, AD7779_SAR_CONV);
        ret |= no_os_gpio_set_value(dev->gpio_convst_sar, NO_OS_GPIO_LOW);
        no_os_mdelay(10);        // Acquisition Time = min 500 ns
        ret |= no_os_gpio_set_value(dev->gpio_convst_sar, NO_OS_GPIO_HIGH);
        no_os_mdelay(10);        // Conversion Time = max 3.4 us
        ad7779_spi_sar_read_code(dev, mux, sar_code);
        ret |= ad7779_set_sar_cfg(dev, restore_sar_state, mux);
        ret |= ad7779_set_spi_op_mode(dev, restore_spi_op_mode);
        return ret;
* Do a SPI software reset.
int32_t ad7779_do_spi_soft_reset(ad7779_dev *dev)
        uint8_t buf[8] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
        int32_t ret;
        /* Keeping the SDI pin high during 64 consecutives clocks generates a
           software reset */
        ret = no_os_spi_write_and_read(dev->spi_desc, buf, 8);
        return ret;
* Set the state (enable, disable) of the SINC5 filter.
* @param state - The SINC5 filter state.
*                                   AD7779_DISABLE
int32_t ad7771_set_sinc5_filter_state(ad7779_dev *dev,
                                      ad7779_state state)
        int32_t ret;
                       __func__);
                return -1;
                                            AD7771_FILTER_MODE,
                                            AD7771_FILTER_MODE : 0);
        dev->sinc5_state = state;
        return ret;
* Get the state (enable, disable) of the SINC5 filter.
int32_t ad7771_get_sinc5_filter_state(ad7779_dev *dev,
        int32_t ret;
        uint8_t reg_data;
                       __func__);
                return -1;
                if (ret)
                        return ret;
                *state = no_os_field_get(AD7771_FILTER_MODE, reg_data);
        } else
                *state = dev->sinc5_state;
        return 0;
* Initialize the device.
* @param device - The device structure.
* @param init_param - The structure that contains the device initial
*                       parameters.
int32_t ad7779_init(ad7779_dev **device,
                    ad7779_init_param init_param)
        ad7779_dev *dev;
        uint8_t i;
        int32_t ret;
        dev = (ad7779_dev *)no_os_malloc(sizeof(*dev));
        if (!dev)
                return -1;
        /* SPI */
        ret = no_os_spi_init(&dev->spi_desc, &init_param.spi_init);
        /* GPIO */
        ret |= no_os_gpio_get(&dev->gpio_reset,
                              &init_param.gpio_reset);
        ret |= no_os_gpio_get(&dev->gpio_mode0,
                              &init_param.gpio_mode0);
        ret |= no_os_gpio_get(&dev->gpio_mode1,
                              &init_param.gpio_mode1);
        ret |= no_os_gpio_get(&dev->gpio_mode2,
                              &init_param.gpio_mode2);
        ret |= no_os_gpio_get(&dev->gpio_mode3,
                              &init_param.gpio_mode3);
        ret |= no_os_gpio_get(&dev->gpio_dclk0,
                              &init_param.gpio_dclk0);
        ret |= no_os_gpio_get(&dev->gpio_dclk1,
                              &init_param.gpio_dclk1);
        ret |= no_os_gpio_get(&dev->gpio_dclk2,
                              &init_param.gpio_dclk2);
        ret |= no_os_gpio_get(&dev->gpio_sync_in,
                              &init_param.gpio_sync_in);
        ret |= no_os_gpio_get(&dev->gpio_convst_sar,
                              &init_param.gpio_convst_sar);
        ret |= no_os_gpio_direction_output(dev->gpio_reset,
                                           NO_OS_GPIO_LOW);
        no_os_mdelay(10);        // RESET Hold Time = min 2 x MCLK
        ret |= no_os_gpio_set_value(dev->gpio_reset, NO_OS_GPIO_HIGH);
        no_os_mdelay(10);        // RESET Rising Edge to First DRDY = min 225 us
        ret |= no_os_gpio_direction_output(dev->gpio_mode0,
                                           NO_OS_GPIO_LOW);
        ret |= no_os_gpio_direction_output(dev->gpio_mode1,
                                           NO_OS_GPIO_LOW);
        ret |= no_os_gpio_direction_output(dev->gpio_mode2,
                                           NO_OS_GPIO_LOW);
        ret |= no_os_gpio_direction_output(dev->gpio_mode3,
                                           NO_OS_GPIO_LOW);
        ret |= no_os_gpio_direction_output(dev->gpio_dclk0,
                                           NO_OS_GPIO_LOW);
        ret |= no_os_gpio_direction_output(dev->gpio_dclk1,
                                           NO_OS_GPIO_LOW);
        ret |= no_os_gpio_direction_output(dev->gpio_dclk2,
                                           NO_OS_GPIO_LOW);
        ret |= no_os_gpio_direction_output(dev->gpio_sync_in,
                                           NO_OS_GPIO_HIGH);
        ret |= no_os_gpio_direction_output(dev->gpio_convst_sar,
                                           NO_OS_GPIO_HIGH);
        /* Device Settings */
        dev->ctrl_mode = init_param.ctrl_mode;
        dev->spi_crc_en = AD7779_DISABLE;
        dev->spi_op_mode = AD7779_INT_REG;
        dev->sar_state = AD7779_DISABLE;
        dev->sar_mux = AD7779_AUXAINP_AUXAINN;
        dev->read_from_cache = init_param.read_from_cache;
        if ((dev->ctrl_mode == AD7779_SPI_CTRL) &&
            (init_param.spi_crc_en == AD7779_ENABLE)) {
                ret |= ad7779_spi_int_reg_read(dev,
                                               AD7779_REG_GEN_ERR_REG_1_EN,
                                               &dev->cached_reg_val[AD7779_REG_GEN_ERR_REG_1_EN]);
                                                     AD7779_SPI_CRC_TEST_EN,
                                                     AD7779_SPI_CRC_TEST_EN);
                dev->spi_crc_en = AD7779_ENABLE;
        if (dev->ctrl_mode == AD7779_SPI_CTRL)
                for (i = AD7779_REG_CH_CONFIG(0); i <= AD7779_REG_SRC_UPDATE; i++)
                        ret |= ad7779_spi_int_reg_read(dev, i, &dev->cached_reg_val[i]);
        for (i = AD7779_CH0; i <= AD7779_CH7; i++) {
                dev->state[i] = init_param.state[i];
                        ret |= ad7779_set_state(dev, (ad7779_ch)i, dev->state[i]);
        no_os_mdelay(50);
                dev->gain[i] = init_param.gain[i];
                        ret |= ad7779_set_gain(dev, (ad7779_ch)i, dev->gain[i]);
        dev->dec_rate_int = init_param.dec_rate_int;
        dev->dec_rate_dec = init_param.dec_rate_dec;
                ret |= ad7779_set_dec_rate(dev, dev->dec_rate_int, dev->dec_rate_dec);
        ret |= ad7779_spi_int_reg_write(dev, AD7779_REG_SRC_UPDATE, 0x01);
        ret |= ad7779_spi_int_reg_write(dev, AD7779_REG_SRC_UPDATE, 0x00);
        dev->ref_type = init_param.ref_type;
                ret |= ad7779_set_reference_type(dev, dev->ref_type);
        dev->pwr_mode = init_param.pwr_mode;
                ret |= ad7779_set_power_mode(dev, dev->pwr_mode);
                ret |= ad7779_do_update_mode_pins(dev);
        dev->dclk_div = init_param.dclk_div;
        ad7779_set_dclk_div(dev, dev->dclk_div);
                dev->sync_offset[i] = init_param.sync_offset[i];
                dev->offset_corr[i] = init_param.offset_corr[i];
                dev->gain_corr[i] = init_param.gain_corr[i];
                if (dev->ctrl_mode == AD7779_SPI_CTRL) {
                        ret |= ad7779_set_sync_offset(dev, (ad7779_ch)i,
                                                      dev->sync_offset[i]);
                        ret |= ad7779_set_offset_corr(dev, (ad7779_ch)i,
                                                      dev->offset_corr[i]);
                        ret |= ad7779_set_gain_corr(dev, (ad7779_ch)i,
                                                    dev->gain_corr[i]);
        *device = dev;
        if (!ret)
                printf("AD7779 successfully initialized\n");
                printf("AD7779 initialization error (%d)\n", ret);
        return ret;
* @brief Free the resources allocated by ad7779_init().
int32_t ad7779_remove(ad7779_dev *dev)
        int32_t ret;
        ret = no_os_spi_remove(dev->spi_desc);
        ret |= no_os_gpio_remove(dev->gpio_reset);
        ret |= no_os_gpio_remove(dev->gpio_mode0);
        ret |= no_os_gpio_remove(dev->gpio_mode1);
        ret |= no_os_gpio_remove(dev->gpio_mode2);
        ret |= no_os_gpio_remove(dev->gpio_mode3);
        ret |= no_os_gpio_remove(dev->gpio_dclk0);
        ret |= no_os_gpio_remove(dev->gpio_dclk1);
        ret |= no_os_gpio_remove(dev->gpio_dclk2);
        ret |= no_os_gpio_remove(dev->gpio_sync_in);
        ret |= no_os_gpio_remove(dev->gpio_convst_sar);
        no_os_free(dev);
        return ret;
*   @file   ad7779.h
#ifndef AD7779_H_
#define AD7779_H_
#include <stdint.h>
#include <stdbool.h>
#include "no_os_delay.h"
#include "no_os_gpio.h"
#include "no_os_spi.h"
#define AD7779_REG_CH_CONFIG(ch)                (0x00 + (ch))                // Channel Configuration
#define AD7779_REG_CH_DISABLE                        0x08                        // Disable clocks to ADC channel
#define AD7779_REG_CH_SYNC_OFFSET(ch)                (0x09 + (ch))                // Channel SYNC Offset
#define AD7779_REG_GENERAL_USER_CONFIG_1        0x11                        // General User Config 1
#define AD7779_REG_GENERAL_USER_CONFIG_2        0x12                        // General User Config 2
#define AD7779_REG_GENERAL_USER_CONFIG_3        0x13                        // General User Config 3
#define AD7779_REG_DOUT_FORMAT                        0x14                        // Data out format
#define AD7779_REG_ADC_MUX_CONFIG                0x15                        // Main ADC meter and reference Mux control
#define AD7779_REG_GLOBAL_MUX_CONFIG                0x16                        // Global diagnostics mux
#define AD7779_REG_GPIO_CONFIG                        0x17                        // GPIO config
#define AD7779_REG_GPIO_DATA                        0x18                        // GPIO Data
#define AD7779_REG_BUFFER_CONFIG_1                0x19                        // Buffer Config 1
#define AD7779_REG_BUFFER_CONFIG_2                0x1A                        // Buffer Config 2
#define AD7779_REG_CH_OFFSET_UPPER_BYTE(ch)        (0x1C + (ch) * 6)        // Channel offset upper byte
#define AD7779_REG_CH_OFFSET_MID_BYTE(ch)        (0x1D + (ch) * 6)        // Channel offset middle byte
#define AD7779_REG_CH_OFFSET_LOWER_BYTE(ch)        (0x1E + (ch) * 6)        // Channel offset lower byte
#define AD7779_REG_CH_GAIN_UPPER_BYTE(ch)        (0x1F + (ch) * 6)        // Channel gain upper byte
#define AD7779_REG_CH_GAIN_MID_BYTE(ch)                (0x20 + (ch) * 6)        // Channel gain middle byte
#define AD7779_REG_CH_GAIN_LOWER_BYTE(ch)        (0x21 + (ch) * 6)        // Channel gain lower byte
#define AD7779_REG_CH_ERR_REG(ch)                (0x4C + (ch))                // Channel Status Register
#define AD7779_REG_CH0_1_SAT_ERR                0x54                        // Channel 0/1 DSP errors
#define AD7779_REG_CH2_3_SAT_ERR                0x55                        // Channel 2/3 DSP errors
#define AD7779_REG_CH4_5_SAT_ERR                0x56                        // Channel 4/5 DSP errors
#define AD7779_REG_CH6_7_SAT_ERR                0x57                        // Channel 6/7 DSP errors
#define AD7779_REG_CHX_ERR_REG_EN                0x58                        // Channel 0-7 Error Reg Enable
#define AD7779_REG_GEN_ERR_REG_1                0x59                        // General Errors Register 1
#define AD7779_REG_GEN_ERR_REG_1_EN                0x5A                        // General Errors Register 1 Enable
#define AD7779_REG_GEN_ERR_REG_2                0x5B                        // General Errors Register 2
#define AD7779_REG_GEN_ERR_REG_2_EN                0x5C                        // General Errors Register 2 Enable
#define AD7779_REG_STATUS_REG_1                        0x5D                        // Error Status Register 1
#define AD7779_REG_STATUS_REG_2                        0x5E                        // Error Status Register 2
#define AD7779_REG_STATUS_REG_3                        0x5F                        // Error Status Register 3
#define AD7779_REG_SRC_N_MSB                        0x60                        // Decimation Rate (N) MSB
#define AD7779_REG_SRC_N_LSB                        0x61                        // Decimation Rate (N) LSB
#define AD7779_REG_SRC_IF_MSB                        0x62                        // Decimation Rate (IF) MSB
#define AD7779_REG_SRC_IF_LSB                        0x63                        // Decimation Rate (IF) LSB
#define AD7779_REG_SRC_UPDATE                        0x64                        // SRC load source and load update
/* AD7779_REG_CHx_CONFIG */
#define AD7779_CH_GAIN(x)                        (((x) & 0x3) << 6)
#define AD7779_CH_RX                                (1 << 4)
/* AD7779_REG_CH_DISABLE */
#define AD7779_CH_DISABLE(x)                        (1 << (x))
/* AD7779_REG_GENERAL_USER_CONFIG_1 */
#define AD7779_ALL_CH_DIS_MCLK_EN                (1 << 7)
#define AD7779_MOD_POWERMODE                        (1 << 6)
#define AD7779_PDB_VCM                                (1 << 5)
#define AD7779_PDB_REFOUT_BUF                        (1 << 4)
#define AD7779_PDB_SAR                                (1 << 3)
#define AD7779_PDB_RC_OSC                        (1 << 2)
#define AD7779_SOFT_RESET(x)                        (((x) & 0x3) << 0)
/* AD7779_REG_GENERAL_USER_CONFIG_2 */
#define AD7771_FILTER_MODE                        (1 << 6)
#define AD7779_SAR_DIAG_MODE_EN                        (1 << 5)
#define AD7779_SDO_DRIVE_STR(x)                        (((x) & 0x3) << 3)
#define AD7779_DOUT_DRIVE_STR(x)                (((x) & 0x3) << 1)
#define AD7779_SPI_SYNC                                (1 << 0)
/* AD7779_REG_GENERAL_USER_CONFIG_3 */
#define AD7779_CONVST_DEGLITCH_DIS(x)                (((x) & 0x3) << 6)
#define AD7779_SPI_SLAVE_MODE_EN                (1 << 4)
#define AD7779_CLK_QUAL_DIS                        (1 << 0)
/* AD7779_REG_DOUT_FORMAT */
#define AD7779_DOUT_FORMAT(x)                        (((x) & 0x3) << 6)
#define AD7779_DOUT_HEADER_FORMAT                (1 << 5)
#define AD7779_DCLK_CLK_DIV(x)                        (((x) & 0x7) << 1)
/* AD7779_REG_ADC_MUX_CONFIG */
#define AD7779_REF_MUX_CTRL(x)                        (((x) & 0x3) << 6)
/* AD7779_REG_GLOBAL_MUX_CONFIG */
#define AD7779_GLOBAL_MUX_CTRL(x)                (((x) & 0x1F) << 3)
/* AD7779_REG_BUFFER_CONFIG_1 */
#define AD7779_REF_BUF_POS_EN                        (1 << 4)
#define AD7779_REF_BUF_NEG_EN                        (1 << 3)
/* AD7779_REG_BUFFER_CONFIG_2 */
#define AD7779_REFBUFP_PREQ                        (1 << 7)
#define AD7779_REFBUFN_PREQ                        (1 << 6)
#define AD7779_PDB_ALDO1_OVRDRV                        (1 << 2)
#define AD7779_PDB_ALDO2_OVRDRV                        (1 << 1)
#define AD7779_PDB_DLDO_OVRDRV                        (1 << 0)
/* AD7779_REG_GEN_ERR_REG_1_EN */
#define AD7779_MEMMAP_CRC_TEST_EN                (1 << 5)
#define AD7779_ROM_CRC_TEST_EN                        (1 << 4)
#define AD7779_SPI_CLK_COUNT_TEST_EN                (1 << 3)
#define AD7779_SPI_INVALID_READ_TEST_EN                (1 << 2)
#define AD7779_SPI_INVALID_WRITE_TEST_EN        (1 << 1)
#define AD7779_SPI_CRC_TEST_EN                        (1 << 0)
#define AD7779_CRC8_POLY                        0x07
typedef enum {
        AD7779_PIN_CTRL,
        AD7779_SPI_CTRL,
} ad7779_ctrl_mode;
typedef enum {
        AD7779_INT_REG,
        AD7779_SD_CONV,
        AD7779_SAR_CONV,
} ad7779_spi_op_mode;
typedef enum {
        AD7779_CH0,
        AD7779_CH1,
        AD7779_CH2,
        AD7779_CH3,
        AD7779_CH4,
        AD7779_CH5,
        AD7779_CH6,
        AD7779_CH7,
} ad7779_ch;
typedef enum {
        AD7779_ENABLE,
        AD7779_DISABLE,
} ad7779_state;
typedef enum {
        AD7779_GAIN_1,
        AD7779_GAIN_2,
        AD7779_GAIN_4,
        AD7779_GAIN_8,
} ad7779_gain;
typedef enum {
        AD7779_DCLK_DIV_1,
        AD7779_DCLK_DIV_2,
        AD7779_DCLK_DIV_4,
        AD7779_DCLK_DIV_8,
        AD7779_DCLK_DIV_16,
        AD7779_DCLK_DIV_32,
        AD7779_DCLK_DIV_64,
        AD7779_DCLK_DIV_128,
} ad7779_dclk_div;
typedef enum {
        AD7779_LOW_PWR,
        AD7779_HIGH_RES,
} ad7779_pwr_mode;
typedef enum {
        AD7779_EXT_REF,
        AD7779_INT_REF,
        AD7779_EXT_SUPPLY,
        AD7779_EXT_REF_INV,
} ad7779_ref_type;
typedef enum {
        AD7779_REFX_P,
        AD7779_REFX_N,
} ad7779_refx_pin;
typedef enum {
        AD7779_REF_BUF_ENABLED,
        AD7779_REF_BUF_PRECHARGED,
        AD7779_REF_BUF_DISABLED,
} ad7779_ref_buf_op_mode;
typedef enum {
        AD7779_AUXAINP_AUXAINN,
        AD7779_DVBE_AVSSX,
        AD7779_REF1P_REF1N,
        AD7779_REF2P_REF2N,
        AD7779_REF_OUT_AVSSX,
        AD7779_VCM_AVSSX,
        AD7779_AREG1CAP_AVSSX_ATT,
        AD7779_AREG2CAP_AVSSX_ATT,
        AD7779_DREGCAP_DGND_ATT,
        AD7779_AVDD1A_AVSSX_ATT,
        AD7779_AVDD1B_AVSSX_ATT,
        AD7779_AVDD2A_AVSSX_ATT,
        AD7779_AVDD2B_AVSSX_ATT,
        AD7779_IOVDD_DGND_ATT,
        AD7779_AVDD4_AVSSX,
        AD7779_DGND_AVSS1A_ATT,
        AD7779_DGND_AVSS1B_ATT,
        AD7779_DGND_AVSSX_ATT,
        AD7779_AVDD4_AVSSX_ATT,
        AD7779_REF1P_AVSSX,
        AD7779_REF2P_AVSSX,
        AD7779_AVSSX_AVDD4_ATT,
} ad7779_sar_mux;
typedef struct {
        /* SPI */
        struct no_os_spi_desc                *spi_desc;
        /* GPIO */
        struct no_os_gpio_desc        *gpio_reset;
        struct no_os_gpio_desc        *gpio_mode0;
        struct no_os_gpio_desc        *gpio_mode1;
        struct no_os_gpio_desc        *gpio_mode2;
        struct no_os_gpio_desc        *gpio_mode3;
        struct no_os_gpio_desc        *gpio_dclk0;
        struct no_os_gpio_desc        *gpio_dclk1;
        struct no_os_gpio_desc        *gpio_dclk2;
        struct no_os_gpio_desc        *gpio_sync_in;
        struct no_os_gpio_desc        *gpio_convst_sar;
        ad7779_ctrl_mode        ctrl_mode;
        ad7779_state                spi_crc_en;
        ad7779_spi_op_mode        spi_op_mode;
        ad7779_state                state[8];
        ad7779_gain                gain[8];
        uint16_t                dec_rate_int;
        uint16_t                dec_rate_dec;
        ad7779_ref_type                ref_type;
        ad7779_pwr_mode                pwr_mode;
        ad7779_dclk_div                dclk_div;
        uint8_t                        sync_offset[8];
        uint32_t                offset_corr[8];
        uint32_t                gain_corr[8];
        ad7779_ref_buf_op_mode        ref_buf_op_mode[2];
        ad7779_state                sar_state;
        ad7779_sar_mux                sar_mux;
        ad7779_state                sinc5_state;        // Can be enabled only for AD7771
        bool                                read_from_cache;
        uint8_t                        cached_reg_val[AD7779_REG_SRC_UPDATE + 1];
} ad7779_dev;
typedef struct {
        /* SPI */
        struct no_os_spi_init_param                spi_init;
        /* GPIO */
        struct no_os_gpio_init_param        gpio_reset;
        struct no_os_gpio_init_param        gpio_mode0;
        struct no_os_gpio_init_param        gpio_mode1;
        struct no_os_gpio_init_param        gpio_mode2;
        struct no_os_gpio_init_param        gpio_mode3;
        struct no_os_gpio_init_param        gpio_dclk0;
        struct no_os_gpio_init_param        gpio_dclk1;
        struct no_os_gpio_init_param        gpio_dclk2;
        struct no_os_gpio_init_param        gpio_sync_in;
        struct no_os_gpio_init_param        gpio_convst_sar;
} ad7779_init_param;
/* Compute CRC8 checksum. */
                            uint8_t data_size);
/* SPI read from device. */
                                uint8_t reg_addr,
                                uint8_t *reg_data);
/* SPI write to device. */
                                 uint8_t reg_addr,
                                 uint8_t reg_data);
/* SPI read from device using a mask. */
                                     uint8_t reg_addr,
                                     uint8_t mask,
                                     uint8_t *data);
/* SPI write to device using a mask. */
                                      uint8_t reg_addr,
                                      uint8_t mask,
                                      uint8_t data);
/* SPI SAR conversion code read. */
                                 uint16_t *sar_code);
/* Set SPI operation mode. */
                               ad7779_spi_op_mode mode);
/* Get SPI operation mode. */
                               ad7779_spi_op_mode *mode);
/* Set the state (enable, disable) of the channel. */
                         ad7779_ch ch,
                         ad7779_state state);
/* Get the state (enable, disable) of the selected channel. */
                         ad7779_ch ch,
                         ad7779_state *state);
/* Update the state of the MODEx pins according to the settings specified in
* the device structure. */
int32_t ad7779_do_update_mode_pins(ad7779_dev *dev);
/* Set the gain of the selected channel. */
                        ad7779_ch ch,
                        ad7779_gain gain);
/* Get the gain of the selected channel. */
                        ad7779_ch ch,
                        ad7779_gain *gain);
/* Set the decimation rate. */
                            uint16_t int_val,
                            uint16_t dec_val);
/* Get the decimation rate. */
                            uint16_t *int_val,
                            uint16_t *dec_val);
/* Set the power mode. */
                              ad7779_pwr_mode pwr_mode);
/* Get the power mode. */
                              ad7779_pwr_mode *pwr_mode);
/* Set the reference type. */
                                  ad7779_ref_type ref_type);
/* Get the reference type. */
                                  ad7779_ref_type *ref_type);
/* Set the DCLK divider. */
                            ad7779_dclk_div div);
/* Get the DCLK divider. */
                            ad7779_dclk_div *div);
/* Set the synchronization offset of the selected channel. */
                               ad7779_ch ch,
                               uint8_t sync_offset);
/* Get the synchronization offset of the selected channel. */
                               ad7779_ch ch,
                               uint8_t *sync_offset);
/* Set the offset correction of the selected channel. */
                               ad7779_ch ch,
                               uint32_t offset);
/* Get the offset correction of the selected channel. */
                               ad7779_ch ch,
                               uint32_t *offset);
/* Set the gain correction of the selected channel. */
                             ad7779_ch ch,
                             uint32_t gain);
/* Get the gain correction of the selected channel. */
                             ad7779_ch ch,
                             uint32_t *gain);
/* Set the reference buffer operation mode of the selected pin. */
                                   ad7779_ref_buf_op_mode mode);
/* Get the reference buffer operation mode of the selected pin. */
                                   ad7779_ref_buf_op_mode *mode);
/* Set the SAR ADC configuration. */
                           ad7779_state state,
                           ad7779_sar_mux mux);
/* Get the SAR ADC configuration. */
                           ad7779_sar_mux *mux);
/* Do a single SAR conversion. */
                                  ad7779_sar_mux mux,
/* Do a SPI software reset. */
int32_t ad7779_do_spi_soft_reset(ad7779_dev *dev);
/* Set the state (enable, disable) of the SINC5 filter. */
/* Get the state (enable, disable) of the SINC5 filter. */
/* Initialize the device. */
                    ad7779_init_param init_param);
/* Free the resources allocated by ad7779_init(). */
int32_t ad7779_remove(ad7779_dev *dev);
#endif // AD7779_H_
