查看: 439|回复: 0
基于51单片机的温湿度检测程序Proteus仿真
#include<reg51.h>
#include<intrins.h>         //包含所需要的机械延时
#define        uint unsigned int
*********dht22相关配置**********
***只需要直接调用数据接收函数****
sbit DA=P2^4;        //数据接受地址
unsigned char  DHT22_init();
unsigned char ReadTH();
unsigned char ReadTL();
unsigned char ReadHH();
unsigned char ReadHL();
static int THmax_val=35;
static int THmin_val=10;
static int RHmax_val=70;
static int RHmin_val=30;
int T;
int H;
int temp1;
int temp2;
unsigned char TL;     //储存暂存器的温度低位
unsigned char TH;    //储存暂存器的温度高位
unsigned char HL;
unsigned char HH;
sbit LED1=P1^1;
sbit LED2=P1^2;
sbit LED3=P1^3;
/*****LCD1602相关函数*********
*RW接地即可,也可以配置为低电平*
*只需简单延时即可,无需复杂操作*
void write_com(uchar com);  //写命令
void write_data(uchar date);//写数据
void lcd1602init();
void delay(unsigned int x_ms)        ;
void delayms(uint z);
void delayus(uint n);
sbit lcdrs=P2^5;
sbit lcden=P2^7;
sbit lcdrw=P2^6;
int abc = 0;
int bcd=0;
/*********按键相关函数******/
sbit K1 = P1^7;
sbit K2 = P1^6;
sbit K3 = P1^5;
sbit K4 = P1^4;
void THmax();
void THmin();
void RHmax();
void RHmin();
/******* 定时器相关函数****/
void timer_init();                //定时器初始化
int aaa;
/***********主函数**********/
     delayms(500);
     timer_init();
     lcd1602init();             //1602初始化
     delayms(500);
                    if(K1 ==0)
                                        write_com(0x01);
                                        write_com(0x80);                    //第一行从开头写
                        write_data('T');
                                        write_data('h');
                                        write_data('r');
                                        write_data('e');
                                        write_data('s');
                                        write_data('h');
                                        write_data('o');
                                        write_data('l');
                                        write_data('d');
                                        write_com(0x80+0x40);
                                        write_data('2');
                                        write_data('.');
                                        write_data('T');
                                        write_data('H');
                                        write_data(' ');
                                        write_data('3');
                                        write_data('.');
                                        write_data('R');
                                        write_data('H');
                                        write_data(' ');
                                        write_data('4');
                                        write_data('.');
                                        write_data('b');
                                        write_data('a');
                                        write_data('c');
                                        write_data('k');
                                    while((K2==1)&&(K3==1)&&(K4==1));
                                    //如果是温度调节
                                      if((K2==0)&&(K3==1))
                                                 while(K2==0);
                                                    write_com(0x01);
                                                        write_data('2');
                                                        write_data('.');
                                                        write_data('T');
                                                        write_data('H');
                                                        write_data('m');
                                                        write_data('a');
                                                        write_data('x');
                                                        write_data('3');
                                                        write_data('.');
                                                        write_data('T');
                                                        write_data('H');
                                                        write_data('m');
                                                        write_data('i');
                                                        write_data('n');
                                                        write_com(0x80+0x40+9);
                                                        write_data('4');
                                                        write_data('.');
                                                        write_data('b');
                                                        write_data('a');
                                                        write_data('c');
                                                        write_data('k');
                                                    //如果是温度最大值
        while(K2==0);
        THmax();
                                                        //如果是温度最小值
                                                        if((K2==1)&&(K3==0))
        while(K3==0);
        THmin();
                                                         //如果是退出
                                                        if((K4==0))
        while((K4==0));
        break;
                                          //如果是湿度调节
                                                while(K3==0);
                                                    write_com(0x01);
                                                        write_data('2');
                                                        write_data('.');
                                                        write_data('R');
                                                        write_data('H');
                                                        write_data('m');
                                                        write_data('a');
                                                        write_data('x');
                                                        write_data('3');
                                                        write_data('.');
                                                        write_data('R');
                                                        write_data('H');
                                                        write_data('m');
                                                        write_data('i');
                                                        write_data('n');
                                                        write_data('4');
                                                        write_data('.');
                                                        write_data('b');
                                                        write_data('a');
                                                        write_data('c');
                                                        write_data('k');
                                                        //如果是湿度阈值最大值
        while(K2==0);
        RHmax();
                                                        // 如果是湿度阈值最小值
        while(K3==0);
        RHmin();
                                                        // 如果是退出
                                                        if((K4==0))
        while((K4==0));
        break;
                                         //如果是退出
                                        if(K4==0)
                                                 while(K4==0);
                                                 write_com(0x01);
                                                 break;
                         else if(K1!=0)
                                 write_com(0x80);
                                 write_data('T');
                                 write_data('H');
                                 write_data(' ');
                                 write_data('0'+temp1/10/10);
                                 write_data('0'+temp1/10%10);
                                 write_data('.');
                                 write_data('0'+temp1%10);
                                 write_data(' ');
                                 write_data(' ');
                                 write_data('R');
                                 write_data('H');
                                 write_data(' ');
                                 write_data('0'+temp2/10/10);
                                 write_data('0'+temp2/10%10);
                                 write_data('.');
                                 write_data('0'+temp2%10);
                                 write_data('1');
                                 write_data('.');
                                 write_data('T');
                                 write_data('h');
                                 write_data('r');
                                 write_data('e');
                                 write_data('s');
                                 write_data('h');
                                 write_data('o');
                                 write_data('l');
                                 write_data('d');
                                if ((temp1>= (THmax_val*10))||(temp1< (THmin_val*10)))
                                         LED2=0;
                                else        LED2=1;
                                if (((temp2)>=( RHmax_val*10))||(temp2< (RHmin_val*10)))
                                                LED3=0;
                                else        LED3=1;
                                if(LED2==0||LED3==0)
                                                        LED1=1;
                                 else  LED1=0;
/*开始*/
/***********dht22相关子函数*************/
/*********LCD1602相关子函数**********/
lcdrs=0;
P3=com;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
lcdrs=1;
P3=date;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void lcd1602init()
lcdrw=0;
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
/*************简单延时函数************/
    unsigned char i, j;
  while(x_ms)
    {   i = 2;
    j = 239;
    do
        while (--j);
    } while (--i);
  x_ms--;
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
/************定时器相关函数***********/
void timer_init()
TMOD=0x01;
TH0 = (65536-50000)/256;
TL0 = (65536-50000)%256;
ET0 = 1  ;
TR0 = 1  ;
EA  = 1  ;
void timer0()interrupt 1{
aaa+=1;
TH0  = 15536/256;
TL0 = 15536%256;
if(aaa==10)
        aaa=0;
        DHT22_init();
        HH=ReadHH();
        HL=ReadHL();
        TH=ReadTH();
        TL=ReadTL();
        temp1=TH<<8|TL;
        temp2=HH<<8|HL;
    unsigned char i;
    DA=1;
    DA=0;
    delay(20);                              //延迟 1ms
    DA=1;
    while(DA==1);
    i = 27;while (--i);     //延迟 60us
    if(DA==1) return 1;
    i = 37;while (--i);         //延迟 80us
    if(DA==0) return 1;
    while(DA==1); return 1;
unsigned char ReadHH()      //读湿度高八位
    unsigned char i,n,HH=0x00;
    for(n=0;n<8;n++)
        while(DA==0);
        while (DA==1)
            i = 17;while (--i); //延迟 40us
            if(DA==1)
            HH=HH|(0X01<<(7-n));
    return HH;
unsigned char ReadHL()          //读湿度低八位
    unsigned char i,n,HL=0x00;
    for(n=0;n<8;n++)
        while(DA==0);
        while (DA==1)
            if(DA==1)
            HL=HL|(0X01<<(7-n));
    return HL;
unsigned char ReadTH()              //读温度高八位
    unsigned char i,n,TH=0x00;
    for(n=0;n<8;n++)
        while(DA==0);
        while (DA==1)
            if(DA==1)
            TH=TH|(0X01<<(7-n));
    return TH;
unsigned char ReadTL()          //读温度低八位
    unsigned char i,n,TL=0x00;
    for(n=0;n<8;n++)
        while(DA==0);
        while (DA==1)
            if(DA==1)
            TL=TL|(0X01<<(7-n));
    return TL;
   温湿度上限调节函数
void THmax()
    while(K2==0);
        write_com(0x01);
        write_com(0x80);
        write_data('T');
        write_data('H');
        write_data('m');
        write_data('a');
        write_data('x');
        write_data(' ');
        write_data(' ');
        write_data('0'+THmax_val/10);
        write_data('0'+THmax_val%10);
        write_data('2');
        write_data('.');
        write_data('+');
        write_data(' ');
        write_data(' ');
        write_data('3');
        write_data('.');
        write_data('-');
        write_data('4');
        write_data('.');
        write_data('b');
        write_data('a');
        write_data('c');
        write_data('k');
             THmax_val++;
             write_com(0x80+7);
             while(K2==0);
                 THmax_val--;
                 write_com(0x80+7);
                 while(K3==0);
        if(K4==0)
           while(K4==0);
           break;
void THmin()
    while(K3==0);
        write_com(0x01);
        write_com(0x80);
        write_data('T');
        write_data('H');
        write_data('m');
        write_data('i');
        write_data('n');
        write_data(' ');
        write_data(' ');
        write_data('0'+THmin_val/10);
        write_data('0'+THmin_val%10);
        write_data('2');
        write_data('.');
        write_data('+');
        write_data(' ');
        write_data(' ');
        write_data('3');
        write_data('.');
        write_data('-');
        write_data('4');
        write_data('.');
        write_data('b');
        write_data('a');
        write_data('c');
        write_data('k');
             THmin_val++;
             write_com(0x80+7);
             while(K2==0);
                 THmin_val--;
                 write_com(0x80+7);
                 while(K3==0);
        if(K4==0)
           while(K4==0);
           break;
void RHmax()
while(K2==0);
         write_com(0x01);
        write_com(0x80);
        write_data('R');
        write_data('H');
        write_data('m');
        write_data('a');
        write_data('x');
        write_data(' ');
        write_data(' ');
        write_data('0'+RHmax_val/10);
        write_data('0'+RHmax_val%10);
        write_data('2');
        write_data('.');
        write_data('+');
        write_data(' ');
        write_data(' ');
        write_data('3');
        write_data('.');
        write_data('-');
        write_data('4');
        write_data('.');
        write_data('b');
        write_data('a');
        write_data('c');
        write_data('k');
             RHmax_val++;
             write_com(0x80+7);
             while(K2==0);
                 RHmax_val--;
                 write_com(0x80+7);
                 while(K3==0);
        if(K4==0)
           while(K4==0);
           break;
void RHmin()
  while(K3==0);
          write_com(0x01);
        write_com(0x80);
        write_data('R');
        write_data('H');
        write_data('m');
        write_data('i');
        write_data('n');
        write_data(' ');
        write_data(' ');
        write_data('0'+RHmin_val/10);
        write_data('0'+RHmin_val%10);
        write_data('2');
        write_data('.');
        write_data('+');
        write_data(' ');
        write_data(' ');
        write_data('3');
        write_data('.');
        write_data('-');
        write_data('4');
        write_data('.');
        write_data('b');
        write_data('a');
        write_data('c');
        write_data('k');
             RHmin_val++;
             write_com(0x80+7);
             while(K2==0);
                 RHmin_val--;
                 write_com(0x80+7);
                 while(K3==0);
        if(K4==0)
           while(K4==0);
           break;
51单片机 温湿度传感器 proteus仿真.rar (103.18 KB, 下载次数: 0)
