查看: 548|回复: 0
无线通讯语言模块测试程序
ID:140644 发表于 2026-7-2 07:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/*无线通讯语言模块测试·PAST 2020 1  15 L142 CODE2257**/
              #include     <REG52.H>
              #include     <intrins.H>
                    #include     "stdio.h"
              #define      uint unsigned int
              #define      uchar unsigned char
                            uchar        s;
                            sbit         OUT1=P3^2;            /****输出***/
                            sbit         OUT2=P3^4;            /****输出***/
              sbit         MD0MD1=P5^5;//P5^4;
                            uchar        DAT2=0;
                            bit               Receive_Flag;
/*---------------延时子程序----------------*/
              void delay1 (uint ms)
              uint i,j;
              for(i=0;i<ms;i++)
              for(j=0;j<200;j++)
/*------------初始化串口---------------------*/
              void InitUart()
              SCON=0X50;                         //8位数据,可变波特率
              AUXR|=0x01;                        //串口1选择定时器2为波特率发生器
              AUXR|=0X04;                        //定时器2时钟为Fosc,即1T
                    T2L=0XE0;                          //设置定时器处置  110592》9600
              T2H=0XFE;                          //设置定时器处置  110592》9600
              AUXR|=0X10;                        //启动定时器2
              TI=1;
                    ES=1;                        //
              EA=1;
                            void change(uchar DAT)
                             switch(DAT)
                             case 1:printf("1");break;
                             case 2:printf("2");break;
                             case 3:printf("3");break;
                             case 4:printf("4");break;
                             case 5:printf("5");break;
                             case 6:printf("6");break;
                             case 7:printf("7");break;
                             case 8:printf("8");break;
                             case 9:printf("9");break;
               case 10:printf("十");break;
                             case 11:printf("十1");break;
                             case 12:printf("十2");break;
                             case 13:printf("十3");break;
                             case 14:printf("十4");break;
                             case 15:printf("十5");break;
                             case 16:printf("十6");break;
                             case 17:printf("十7");break;
                             case 18:printf("十8");break;
                             case 19:printf("十9");break;
                             case 20:printf("2十");break;
                             case 21:printf("2十1");break;
                             case 22:printf("2十2");break;
                             case 23:printf("2十3");break;
                             case 24:printf("2十4");break;
                             case 25:printf("2十5");break;
                             case 26:printf("2十6");break;
                             case 27:printf("2十7");break;
                             case 28:printf("2十8");break;
                             case 29:printf("2十9");break;
                             case 30:printf("3十");break;
                             case 31:printf("3十1");break;
                             case 32:printf("3十2");break;
                             case 33:printf("3十3");break;
                             case 34:printf("3十4");break;
                             case 35:printf("3十5");break;
                             case 36:printf("3十6");break;
                             case 37:printf("3十7");break;
                             case 38:printf("3十8");break;
                             case 39:printf("3十9");break;
                             case 40:printf("4十");break;
                             case 41:printf("4十1");break;
                             case 42:printf("4十2");break;
                             case 43:printf("4十3");break;
                             case 44:printf("4十4");break;
                             case 45:printf("4十5");break;
                             case 46:printf("4十6");break;
                             case 47:printf("4十7");break;
                             case 48:printf("4十8");break;
                             case 49:printf("4十9");break;
                             case 50:printf("5十");break;
                             default: break;
/*--------UART 中断服务程序----Buff=SBUF---------------*/
              void Uart() interrupt 4 using 1
               if(RI)
                     DAT2=SBUF;                        //数组下标位置的数据等于j
               RI=0;                                     //
                             Receive_Flag=1;                       //接收数据标志置一
/*------------------主循环程序----------------*/
              void   main( )                     /*主程序开始*/
              {                                  /**加一**/
                    AUXR=0X80;                         //STC系列的1T 设置
              TMOD=0X01;
                            delay1(2000);
                            delay1(2000);
              InitUart();                        //初始化串口
                            MD0MD1=0;                                         //
                            printf("<Z>6");                         //音效
                            printf("<V>3");                         //音量
                            printf("<S>3");                         //语速
              delay1(200);
                            OUT1=0;
                            OUT2=0;
                            delay1(2000);
                            OUT1=1;
                            OUT2=1;
                            P_SW1=0x40;                        //RXD_2/P3.6, TXD_2/P3.7
                            printf("系统启动中");
                            delay1(2000);
                            P_SW1=0x00;                        //RXD/P3.0, TXD/P3.1
                            delay1(2000);
                            Receive_Flag=0;                       //接收数据标志置零
                             if(Receive_Flag==1)
                                OUT1=0;
                                OUT2=0;
                                delay1(200);
                                change(DAT2);
                printf("号机报警,请及时处理 ");
                delay1(2000);
                                OUT1=1;
                                OUT2=1;
                        Receive_Flag=0;                     //接收到数据标志置零
