查看: 567|回复: 1
FreeRTOS运行不了
ID:302293 发表于 2026-8-8 13:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  用cubeMX一键生成的freeRTOS 不能运行任务是什么问题,查了没发现问题,知道的指点一下
#include "FreeRTOS.h"
#include "task.h"
#include "main.h"
#include "cmsis_os.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN Variables */
osThreadId_t Led1TaskHandle;
const osThreadAttr_t Led1Task_attributes = {
  .name = "Led1Task",
  .stack_size = 512 * 4,
  .priority = (osPriority_t) osPriorityNormal,
/* USER CODE END Variables */
/* Private function prototypes -----------------------------------------------*/
void MX_FREERTOS_Init(void);
/* USER CODE BEGIN PFP */
void Led1_Task(void *argument);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
* @brief PA6 LED任务,500ms闪烁
  for (;;)
     HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_SET); //任务入口第一行立刻翻转IO
    osDelay(500);
/* USER CODE END 0 */
  * @brief  FreeRTOS initialization
  * @param  None
  * @retval None
void MX_FREERTOS_Init(void) {
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* USER CODE BEGIN RTOS_MUTEX */
  /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
  /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* USER CODE BEGIN RTOS_TIMERS */
  /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* USER CODE BEGIN RTOS_QUEUES */
  /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
  /* Create the thread(s) */
  /* USER CODE BEGIN RTOS_THREADS */
  Led1TaskHandle = osThreadNew(Led1_Task, NULL, &Led1Task_attributes);
//检测任务是否创建成功
  if(Led1TaskHandle == NULL)
    while(1); //创建失败直接死循环
/* USER CODE END RTOS_THREADS */
ID:1175626 发表于 2026-8-20 11:05 | 只看该作者
既然你加了 if(Led1TaskHandle == NULL) 的死循环,你可以这样验证:
在 Led1_Task 的第一行(HAL_GPIO_WritePin 之前)打断点,看能不能进。
如果进不去,在 osThreadNew 之后打断点,查看 Led1TaskHandle 的值是否为 NULL。
如果为 NULL,99% 是 堆内存不足 (configTOTAL_HEAP_SIZE 太小) 或 堆栈设置过大导致 RAM 溢出。
如果任务创建了但没调度,检查 main() 里有没有 osKernelStart();。
