查看: 2|回复: 0
time.h下载
ID:1177385 发表于 2026-10-20 19:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#ifndef __time_h
#define __time_h
#define __ARMCLIB_VERSION 5030076
#define _ARMABI __declspec(__nothrow)
#define _ARMABI_PURE __declspec(__nothrow) __pure
  #ifndef __TIME_DECLS
  #define __TIME_DECLS
    #undef __CLIBNS
    #ifdef __cplusplus
      namespace std {
          #define __CLIBNS std::
          extern "C" {
    #else
      #define __CLIBNS
    #endif  /* __cplusplus */
#if defined(__cplusplus) || !defined(__STRICT_ANSI__)
/* unconditional in C++ and non-strict C for consistency of debug info */
  typedef unsigned int size_t;
#elif !defined(__size_t)
  #define __size_t 1
  typedef unsigned int size_t;   /* see <stddef.h> */
#endif
#undef NULL
#define NULL 0                   /* see <stddef.h> */
    /* CLOCKS_PER_SEC: the number per second of the value returned by the
     * clock function. */
#if _AEABI_PORTABILITY_LEVEL != 0 || (!defined _AEABI_PORTABILITY_LEVEL && __DEFAULT_AEABI_PORTABILITY_LEVEL != 0)
  extern const int __aeabi_CLOCKS_PER_SEC;
  #define CLOCKS_PER_SEC (__aeabi_CLOCKS_PER_SEC)
#else
  #ifdef __CLK_TCK
    #define CLOCKS_PER_SEC  __CLK_TCK
  #else
    #define CLOCKS_PER_SEC  100
  #endif
#endif
#ifndef __STRICT_ANSI__
  #define CLK_TCK CLOCKS_PER_SEC
#endif
typedef unsigned int clock_t;    /* cpu time type */
typedef unsigned int time_t;     /* date/time in unix secs past 1-Jan-70 */
#pragma push
#pragma anon_unions
struct tm {
    int tm_sec;   /* seconds after the minute, 0 to 60
                     (0 - 60 allows for the occasional leap second) */
    int tm_min;   /* minutes after the hour, 0 to 59 */
    int tm_hour;  /* hours since midnight, 0 to 23 */
    int tm_mday;  /* day of the month, 1 to 31 */
    int tm_mon;   /* months since January, 0 to 11 */
    int tm_year;  /* years since 1900 */
    int tm_wday;  /* days since Sunday, 0 to 6 */
    int tm_yday;  /* days since January 1, 0 to 365 */
    int tm_isdst; /* Daylight Savings Time flag */
    union {       /* ABI-required extra fields, in a variety of types */
        struct {
            int __extra_1, __extra_2;
        struct {
            long __extra_1_long, __extra_2_long;
        struct {
            char *__extra_1_cptr, *__extra_2_cptr;
        struct {
            void *__extra_1_vptr, *__extra_2_vptr;
#pragma pop
   /* struct tm holds the components of a calendar time, called the broken-down
    * time. The value of tm_isdst is positive if Daylight Savings Time is in
    * effect, zero if Daylight Savings Time is not in effect, and negative if
    * the information is not available.
extern _ARMABI clock_t clock(void);
   /* determines the processor time used.
    * Returns: the implementation's best approximation to the processor time
    *          used by the program since program invocation. The time in
    *          seconds is the value returned divided by the value of the macro
    *          CLK_TCK. The value (clock_t)-1 is returned if the processor time
    *          used is not available.
extern _ARMABI double difftime(time_t /*time1*/, time_t /*time0*/);
    * computes the difference between two calendar times: time1 - time0.
    * Returns: the difference expressed in seconds as a double.
extern _ARMABI time_t mktime(struct tm * /*timeptr*/) __attribute__((__nonnull__(1)));
    * converts the broken-down time, expressed as local time, in the structure
    * pointed to by timeptr into a calendar time value with the same encoding
    * as that of the values returned by the time function. The original values
    * of the tm_wday and tm_yday components of the structure are ignored, and
    * the original values of the other components are not restricted to the
    * ranges indicated above. On successful completion, the values of the
    * tm_wday and tm_yday structure components are set appropriately, and the
    * other components are set to represent the specified calendar time, but
    * with their values forced to the ranges indicated above; the final value
    * of tm_mday is not set until tm_mon and tm_year are determined.
    * Returns: the specified calendar time encoded as a value of type time_t.
    *          If the calendar time cannot be represented, the function returns
    *          the value (time_t)-1.
extern _ARMABI time_t time(time_t * /*timer*/);
    * determines the current calendar time. The encoding of the value is
    * unspecified.
    * Returns: the implementations best approximation to the current calendar
    *          time. The value (time_t)-1 is returned if the calendar time is
    *          not available. If timer is not a null pointer, the return value
    *          is also assigned to the object it points to.
extern _ARMABI char *asctime(const struct tm * /*timeptr*/) __attribute__((__nonnull__(1)));
extern _ARMABI char *_asctime_r(const struct tm * /*timeptr*/,
                                char * __restrict /*buf*/) __attribute__((__nonnull__(1,2)));
extern _ARMABI char *asctime_r(const struct tm * /*timeptr*/,
#endif
    * converts the broken-down time in the structure pointed to by timeptr into
    * a string in the form "Sun Sep 16 01:03:52 1973\n\0".
    * Returns: a pointer to the string containing the date and time.
extern _ARMABI char *ctime(const time_t * /*timer*/) __attribute__((__nonnull__(1)));
    * converts the calendar time pointed to by timer to local time in the form
    * of a string. It is equivalent to asctime(localtime(timer));
    * Returns: the pointer returned by the asctime function with that
    *          broken-down time as argument.
extern _ARMABI struct tm *gmtime(const time_t * /*timer*/) __attribute__((__nonnull__(1)));
    * converts the calendar time pointed to by timer into a broken-down time,
    * expressed as Greenwich Mean Time (GMT).
    * Returns: a pointer to that object or a null pointer if GMT not available.
extern _ARMABI struct tm *localtime(const time_t * /*timer*/) __attribute__((__nonnull__(1)));
extern _ARMABI struct tm *_localtime_r(const time_t * __restrict /*timer*/,
                                       struct tm * __restrict /*result*/) __attribute__((__nonnull__(1,2)));
extern _ARMABI struct tm *localtime_r(const time_t * __restrict /*timer*/,
#endif
    * expressed a local time.
    * Returns: a pointer to that object.
extern _ARMABI size_t strftime(char * __restrict /*s*/, size_t /*maxsize*/,
                       const char * __restrict /*format*/,
                       const struct tm * __restrict /*timeptr*/) __attribute__((__nonnull__(1,3,4)));
    * places characters into the array pointed to by s as controlled by the
    * string pointed to by format. The format string consists of zero or more
    * directives and ordinary characters. A directive consists of a % character
    * followed by a character that determines the directive's behaviour. All
    * ordinary characters (including the terminating null character) are copied
    * unchanged into the array. No more than maxsize characters are placed into
    * the array. Each directive is replaced by appropriate characters  as
    * described in the following list. The appropriate characters are
    * determined by the LC_TIME category of the current locale and by the
    * values contained in the structure pointed to by timeptr.
    * %a is replaced by the locale's abbreviated weekday name.
    * %A is replaced by the locale's full weekday name.
    * %b is replaced by the locale's abbreviated month name.
    * %B is replaced by the locale's full month name.
    * %c is replaced by the locale's appropriate date and time representation.
    * %d is replaced by the day of the month as a decimal number (01-31).
    * %H is replaced by the hour (24-hour clock) as a decimal number (00-23).
    * %I is replaced by the hour (12-hour clock) as a decimal number (01-12).
    * %j is replaced by the day of the year as a decimal number (001-366).
    * %m is replaced by the month as a decimal number (01-12).
    * %M is replaced by the minute as a decimal number (00-59).
    * %p is replaced by the locale's equivalent of either AM or PM designations
    *       associated with a 12-hour clock.
    * %S is replaced by the second as a decimal number (00-61).
    * %U is replaced by the week number of the year (Sunday as the first day of
    *       week 1) as a decimal number (00-53).
    * %w is replaced by the weekday as a decimal number (0(Sunday) - 6).
    * %W is replaced by the week number of the year (Monday as the first day of
    * %x is replaced by the locale's appropriate date representation.
    * %X is replaced by the locale's appropriate time representation.
    * %y is replaced by the year without century as a decimal number (00-99).
    * %Y is replaced by the year with century as a decimal number.
    * %Z is replaced by the timezone name or abbreviation, or by no characters
    *       if no time zone is determinable.
    * %% is replaced by %.
    * If a directive is not one of the above, the behaviour is undefined.
    * Returns: If the total number of resulting characters including the
    *          terminating null character is not more than maxsize, the
    *          strftime function returns the number of characters placed into
    *          the array pointed to by s not including the terminating null
    *          character. otherwise, zero is returned and the contents of the
    *          array are indeterminate.
    #ifdef __cplusplus
         }  /* extern "C" */
      }  /* namespace std */
  #endif /* __TIME_DECLS */
  #if _AEABI_PORTABILITY_LEVEL != 0 && !defined _AEABI_PORTABLE
    #define _AEABI_PORTABLE
  #endif
  #ifdef __cplusplus
    #ifndef __TIME_NO_EXPORTS
      using ::std::clock_t;
      using ::std::time_t;
      using ::std::tm;
      using ::std::tm;
      using ::std::clock;
      using ::std::difftime;
      using ::std::mktime;
      using ::std::time;
      using ::std::asctime;
      using ::std::_asctime_r;
      using ::std::asctime_r;
#endif
      using ::std::ctime;
      using ::std::gmtime;
      using ::std::localtime;
      using ::std::_localtime_r;
      using ::std::localtime_r;
#endif
      using ::std::strftime;
      using ::std::size_t;
    #endif /* __TIME_NO_EXPORTS */
#endif
/* end of time.h */
