查看: 4612|回复: 1
1602程序修改
ID:59106 发表于 2014-2-19 10:10 | 显示全部楼层 |阅读模式
请问1602的代码如何写啊,这是我写的但是运行不了,怎么回事呢#include<reg52.h>sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
unsigned char code table[]="I LOVE MCU!";
unsigned char code table1[]="WWW.TXMCU.COM";
unsigned char num;
void delay(unsigned int t);
void write_com(unsigned char com)
   lcdrs=0;
   P0=com;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void write_data(unsigned char date)
   lcdrs=1;
   P0=date;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void init()
  dula=0;
  wela=0;
  lcden=0;
  write_com(0x38);
  write_com(0x0c);
  write_com(0x06);
  write_com(0x01);
     init();
     write_com(0x80);
     for(num=0;num<11;num++)
        write_data(table[num]);
        delay(5);
     write_com(0x80+0x40);
     for(num=0;num<13;num++)
       write_data(table1[num]);
       delay(5);
    while(1);
  while(--t);
ID:1 发表于 2014-2-24 22:40 | 显示全部楼层
#include "at89x52.h"
#include "51hei.h"
#define LCM_RW  P2_7 //定义引脚
#define LCM_RS  P3_5
#define LCM_E   P3_4
#define LCM_Data  P0
#define Busy    0x80 //用于检测LCM状态字中的Busy标识
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
unsigned char code uctech[] = {"    *51hei*    "};
unsigned char code net[] =    {" www.51Hei.com "};
void main(void)
  guandz();//关闭点阵
  guanled();//关闭led数码管
  Delay400Ms(); //启动等待,等LCM讲入工作状态
  LCMInit(); //LCM初始化
  Delay5Ms(); //延时片刻(可不要)
  DisplayListChar(0, 5, uctech);
  DisplayListChar(0, 0, net);
  ReadDataLCM();//测试用句无意义
while(1);
//写数据
ReadStatusLCM(); //检测忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在这后加小的延时
LCM_E = 0; //延时
LCM_E = 1;
//写指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
if (BuysC) ReadStatusLCM(); //根据需要检测忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//读数据
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//读状态
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //检测忙信号
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
WriteCommandLCM(0x08,1); //关闭显示
WriteCommandLCM(0x01,1); //显示清屏
WriteCommandLCM(0x06,1); // 显示光标移动设置
WriteCommandLCM(0x0C,1); // 显示开及光标设置
//按指定位置显示一个字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
X |= 0x80; // 算出指令码
WriteCommandLCM(X, 0); //这里不检测忙信号,发送地址码
WriteDataLCM(DData);
//按指定位置显示一串字符
unsigned char ListLength;
  ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到达字串尾则退出
   if (X <= 0xF) //X坐标应小于0xF
     DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符
     ListLength++;
     X++;
//5ms延时
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延时
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
