查看: 5920|回复: 0
不知道问题出在哪里, 向高手请教
ID:17382 发表于 2009-9-19 23:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
由于刚学C语言编程,没学汇编,对硬件不是太了解。这是用1302编时钟程序;用Proteus仿真。我不知道问题出在哪里??向高手请教;
郁闷不知道怎么插入图片。
 init();  //初始化
 displayda();   //初始化 显示;
// testdate();
  displayda1();    //液晶显示;
   keyTimeSet();   //键盘扫描;
  a=read_2401add(1);     //  加这句就出错,液晶显示不能做到一秒走一步;??????去掉正常;
                                     //读出2401地址码1的数据;
   k2=!k2;        //正常;P1^0口;
uchar read_2401add(uchar address)//测试过读取正常;
 uchar date2401;
 start();
 write_byte(0xa0);
 respons();
 write_byte(address);
 respons();
 start();
 write_byte(0xa1);
 respons();
 date2401=read_byte();
 stop();
 return date2401;
void  displayda1()    液晶显示;
  second = read1302(0x80);
  timestring[6] = (second&0xf0)>>4;
  timestring[7] = second&0x0f;
  lcddisplay_com(0x80+0x4b);
  lcddisplay_date(timestring[6]+0x30);
  lcddisplay_date(timestring[7]+0x30);
   if(second==0)
    minute = read1302(0x82);
     timestring[3] = (minute&0xf0)>>4;
     timestring[4] = minute&0x0f;
    lcddisplay_com(0x80+0x48);
   lcddisplay_date(timestring[3]+0x30);
   lcddisplay_date(timestring[4]+0x30);
  if(minute==0)
     hour  = read1302(0x84);
         timestring[0] = (hour&0xf0)>>4;
      timestring[1] = hour&0x0f;
     lcddisplay_com(0x80+0x45);
    lcddisplay_date(timestring[0]+0x30);
    lcddisplay_date(timestring[1]+0x30);
   if(hour==0)
          day  = read1302(0x86);
    week = read1302(0x8a);
    datestring[6] = (day&0xf0)>>4;
     datestring[7] = day&0x0f;
    lcddisplay_com(0x80+0x0a);
    lcddisplay_date(datestring[6]+0x30);
     lcddisplay_date(datestring[7]+0x30);
    lcddisplay_com(0x80+0x09+0x04);
    week=week&0x07;
    displayweek(week);
    if(day==1)
         month  = read1302(0x88);
      datestring[3] = (month&0xf0)>>4;
        datestring[4] = month&0x0f;
      lcddisplay_com(0x80+0x07);
      lcddisplay_date(datestring[3]+0x30);
      lcddisplay_date(datestring[4]+0x30);
      if(month==1)
        year  = read1302(0x8c);
        datestring[0] = (year&0xf0)>>4;
          datestring[1] = year&0x0f;
        lcddisplay_com(0x80+0x04);
        lcddisplay_date(datestring[0]+0x30);
        lcddisplay_date(datestring[1]+0x30);
