查看: 4594|回复: 0
汇编语言常见例子
ID:60076 发表于 2014-4-30 18:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1、编写程序计算Z=(X*X-3*Y)/2
DATA    SEGMENT
X    DB    25
Y    DB    32
Z    DW    ?
DATA    ENDS
CODE    SEGMENT
     ASSUME    CS:CODE,DS:DATA
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    AL,X
     MUL    AL
     MOV    BX,0
     MOV    BL,Y
     ADD    BL,BL
     ADC    BH,0
     ADD    BL,Y
     ADC    BH,0
     SUB    AX,BX
     SHR    AX,1
     MOV    Z,AX
     MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
2、编写程序完成多字节相加
DATA    SEGMENT
DAT1    DB    5EH,89H
DAT2    DB    40H,OABH
DAT3    DW    ?
DATA    ENDS
CODE    SEGMENT
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    SI,0
     MOV    AL,DAT1[SI]
     MOV    AL,DAT2[SI]
     MOV    DAT3[SI],AL
     INC    SI
     MOV    AL,DAT1[SI]
     ADC    AL,DAT2[SI]
     MOV    DAT3[SI],AL
     MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
3、查表求平方和
DATA    SEGMENT
TABL    DB    0,1,4,9,16,25,36,49
     DB    64,81,100,121,144,169,225
XD    DB    ?
YD    DB    ?
DATA    ENDS
STACK    SEGMENT    STACK    'STACK'
STA    DB    50    DUP    (?)
TOP    EQU    LENGTH    STA
STACK    ENDS
CODE    SEGMENT
     ASSUME    CS:CODE,DS:DATA,SS:STACK
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    AX,STACK
     MOV    SS,AX
     MOV    SP,TOP
     MOV    BX,OFFSET    TABL
     MOV    AH,0
     MOV    AL,XD
     ADD    BX,AX
     MOV    AL,[BX]
     MOV    YD,AL
     MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
4、源数据块和目的数据块是否有重叠来决定采用增址还是减址方式传送
DATA    SEGMENT
STRG    DB    1000    DUP(?)
BLOK1    EQU    STRG+5
BLOK2    EQU    STRG+10
BLENG    EQU    100
DATA    ENDS
CODE    SEGMENT
     ASSUME    CS:CODE,DS:DATA,ES:DATA
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    ES,AX
     MOV    CX,BLENG
     MOV    SI,OFFSET    BLOK1
     MOV    DI,OFFSET    BLOK2
     CLD
     PUSH    SI
     ADD    SI,BLENG-1
     CMP    SI,DI
     POP    SI
     JB    GO
     STD
     ADD    SI,BLENG-1
     ADD    DI,BLENG-1
GO:    REP    MOVSB
     MOV    AH,4CH
     INT    21H
     CODE    ENDS
     END    START
5、找出最大数和最小数
DATA    SEGMENT
BUF    DB    -2,+5,-128
     DB    +127,80,-70
COUN    EQU    $-BUF
MAX    DB    ?
MIN    DB    ?
DATA    ENDS
STACK    SEGMENT    STACK
STR    DB    64H    DUP(?)
STACK    ENDS
MYCODE    SEGMENT
     ASSUME    DS:MYCODE,DS:DATA,SS:STACK
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    AX,STACK
     MOV    SS,AX
     MOV    SP,LENGTH    STR
     MOV    CX,COUN-1
     MOV    SI,OFFSET    BUF
     MOV    AL,[SI]
     MOV    BL,[SI]
     INC    SI
LOP:    CMP    AL,[SI]
     JGE    NEXT1
     MOV    AL,[SI]
NEXT1:    CMP    BL,[SI]
     JL    NEXT
     MOV    BL,[SI]
NEXT:    INC    SI
     LOOP    LOP
     MOV    MAX,AL
     MOV    MIN,BL
     MOV    AH,4CH
     INT    21H
MYCODE    ENDS
     END    START
6、三路分支结构程序
DATA    SEGMENT
DATX    DB    -3
DATY    DB    ?
DATA    ENDS
CODE    SEGMENT
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    AL,DATX
     CMP    AL,0
     JGE    BIGER
     MOV    AL,0FFH
     MOV    DATY,AL
     JMP    NEXT
BIGER:    JE    EQUL
     MOV    AL,1
     MOV    DATY,AL
     JMP    NEXT
EQUL:    MOV    DATY,AL
NEXT:    MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
7、利用跳转实现多分支结构
DATA    SEGMENT
ADRTAB    DW    R0,R1,R2,R3,R4,R5,R6,R7,R8,R9
TEN    DB    ?
DATA    ENDS
STACK    SEGMENT    PARA    STACK    'STACK'
STA    DB    100    DUP(?)
STACK    ENDS
CODE    SEGMENT
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    AX,STACK
     MOV    SS,AX
     MOV    SP,LENGTH    STA
     MOV    AH,01
     INT    21H
COMPUT:    MOV    AH,0
     AND    AL,0FH
     ADD    AL,AL
     MOV    BX,OFFSET    ADRTAB
     ADD    BX,AX
     MOV    AX,[BX]
     JMP    AX
R0:
R1:
R2:
R3:
R4:
R5:
R6:
R7:
R8:
R9:
     MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
8、计算累加和
DATA    SEGMENT
SUM    DW    ?
DATA    ENDS
CODE    SEGMENT
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    AX,0
     MOV    CX,100
AGAIN:    ADD    AX,CX
     DEC    CX
     JNZ    AGAIN
     MOV    SUM,AX
     MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
9、计算一个数中1的个数
DATA    SEGMENT
X    DW    31A0H
RESULT    DW    ?
DATA    ENDS
CODE    SEGMENT
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    CX,0
     MOV    AX,X
AGAIN:    AND    AX,AX
     JZ    EXIT
     SHL    AX,1
     JNC    NEXT
     INC    CX
NEXT:    JMP    AGAIN
EXIT:    MOV    RESULT,CX
     MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
10、求一列数的累加和
DATA    SEGMENT
BLOCK    DW    0028H,0FF18H,1005H,7823H,0
     DW    0CDABH,0FFFFH,1122H,3344H,7892H
COUN    EQU    ($-BLOCK)/2
SUM    DW    ?
DATA    ENDS
STA    DW    100    DUP(?)
TOP    EQU    SIZE    STA
STACK    ENDS
CODE    SEGMENT
START:    MOV    AX,DATA
     MOV    DS,AX
     MOV    AX,STACK
     MOV    SS,AX
     MOV    SP,TOP
     MOV    AX,0
     MOV    SI,OFFSET    BLOCK
     MOV    CX,COUN
LOP:    ADD    AX,[SI]
     ADD    SI,2
     LOOP    LOP
     MOV    SUM,AX
     MOV    AH,4CH
     INT    21H
CODE    ENDS
     END    START
11、延时程序
TIMEDLY    PROC
     MOV    BX,100
DELAY:    MOV    CX,5882
DELAYO:    LOOP    DELAYO
     DEC    BX
     JNZ    DELAY
     RET
TIMEDLY    ENDP
12、冒泡排序法
DATASEG    SEGMENT
ARRAY    DW    1234H,5437,7FFFH,0FFFFH,0AB55
     DW    05FFH,7832H,0,9043H,5634
COUN    EQU    ($-ARRAY)/2
DATASEG    ENDS
STACKSEG    SEGMENT    PARA    STACK    'STACK'
STAPN    DB    100    DUP(?)
TOP    EQU    LENGTH    STAPN
STACKSEG    ENDS
PROGRAM    SEGMENT
     ASSUME    CS:PROGRAM,DS:DATASEG,SS:STACKSEG
START:    MOV    AX,DATASEG
     MOV    DS,AX
     MOV    AX,STACKSEG
     MOV    SS,AX
     MOV    AX,TOP
     MOV    SP,AX
     MOV    BL,0FFH
A1:    CMP    BL,0FFH
     JNE    A4
     XOR    BL,BL
     MOV    CX,COUN-1
     XOR    SI,SI
A2:    MOV    AX,ARRAY[SI]
     CMP    AX,ARRAY[SI+2]
     JGE    A3
     XCHG    ARRAY[SI+2],AX
     MOV    ARRAY[SI],AX
     MOV    BL,0FFH
A3:    INC    SI
     INC    SI
     LOOP    A2
     JMP    A1
A4:    MOV    AH,4CH
     INT    21H
PROGRAM    ENDS
     END    START
