查看: 2011|回复: 1
新人求助 ,求各位帮忙了
ID:64081 发表于 2014-7-17 11:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用数码管显示交通灯实验,数码管显示的时候只有一部分显示正常其他的显示不正常
//交通灯用数码管显示实验
#include<reg51.h>
uchar code table[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code shuma_w[8] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
//定义前进路红绿灯
sbit Q_Red = P1^0;
sbit Q_Yellow = P1^1;
sbit Q_Green = P1^2;
sbit Q_P_Red = P1^3;
sbit Q_P_Green = P1^4;
//定义宝田路红绿灯
sbit B_Red = P3^0;
sbit B_Yellow = P3^1;
sbit B_Green = P3^2;
sbit B_P_Red = P3^3;
sbit B_P_Green = P3^4;
uchar Count = 0;
uchar Sec = 0;
void Delay(uint del)//10ms的延时函数
        uint i,j;
        for(i=0;i<del;i++)
        for(j=0;j<1827;j++)
void Delay_1ms(uint i)//1ms的延时函数
        uint x,j;
        for(j=0;j<i;j++)
        for(x=0;x<148;x++)
void LED(uchar dic,uchar re,uchar yel,uchar gre,uchar p_re,uchar p_gre)
        if(dic == 1)
                Q_Red = re;
                Q_Yellow = yel;
                Q_Green = gre;
                Q_P_Red = p_re;
                Q_P_Green = p_gre;
        if(dic == 2)
                B_Red = re;
                B_Yellow = yel;
                B_Green = gre;
                B_P_Red = p_re;
                B_P_Green = p_gre;
void Time0_in(void)//时间50ms
        TMOD = 0x01;
        TH0 = 0x4c;
        TL0 = 0x00;
        IE = 0x82;
        TR0 = 1;
void Time0_int(void) interrupt 1  //50ms*20=1s
        TH0 = 0x4c;
        TL0 = 0x00;
        Count++;
        if(Count == 20)
                Count = 0;
                Sec--;
void LEDreg(void)
        P0 = 0;
        P2 = shuma_w[3];
        P0 = table[Sec/10];
        Delay_1ms(2);
        P0 = 0;
        P2 = shuma_w[2];
        P0 = table[Sec%10];
        Delay_1ms(2);
        P2 = 0xff;//数码管不会被点亮
void main(void)
        uchar i;
        Time0_in();
                //前进路绿灯亮,宝田路红灯亮持续时间10秒
                Sec = 10;
                while(Sec != 0)
                        LED(1,1,1,0,1,0);
                        LED(2,0,1,1,0,1);
                        LEDreg();
                //前进路黄灯亮,宝田路红灯亮持续时间5秒
                Sec = 5;
                while(Sec != 0)
                        for(i=0;i<100;i++)
                                LED(1,1,0,1,1,1);
                                LED(2,0,1,1,0,1);
                                LEDreg();
                        LED(1,1,1,1,1,1);
                        LED(2,1,1,1,1,1);
                        Delay(50);
                //前进路红灯亮,宝田路绿灯亮持续时间10秒
                Sec = 10;
                while(Sec != 0)
                        LED(1,0,1,1,0,1);
                        LED(2,1,1,0,1,0);
                        LEDreg();
                //前进路红灯亮,宝田路黄灯亮5秒
                Sec = 5;
                while(Sec !=0)
                        for(i=0;i<100;i++)
                                LED(1,0,1,1,0,1);
                                LED(2,1,0,1,1,1);
                                LEDreg();
                        LED(1,1,1,1,1,1);
                        LED(2,1,1,1,1,1);
                        Delay(50);
希望哪位懂的能够帮我解决一下  在此谢过了
