查看: 3332|回复: 3
这个程序是我在百度上找的,但是有错误,我不会改,希望大家可以帮我一下,谢谢啦
ID:64643 发表于 2014-8-1 21:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
由于我才接触单片机不到20天,我的编程和理解程序的能力都很菜,我就看电子大赛的题目有一个是,《电阻自动测试仪,》在百度文库上搜了一下,按着人家的那个方案,做,现在把电路什么的都搭好了,显示模块用的是128*64,采样用的是AD7705,但是人家的程序我复制过来,有错误,就卡到这里了,我研究了好几天都不会,我希望有人可以帮帮我,不胜感激!
我把人家的程序给各位前辈们带着,
#include"LCD12864.h "
#include"reg51.h"
#include"ADC.h"
#defineTHO_int  0xff
#define TL0_int  0x15
#define    TMOD_int 0x01//方式1
#define TCON_int 0x10
uchar time_4ms;
uchar cont_200ms;
uchar stop_run_delay;
uchar set_read_cont;
uchar key;
uchar key_buf;
uchar key_cont;
uchar set_step;
uchar tast_delay;
uint moto_cont;
uint moto_time;
uchar P1_buf;
uchar beef_delay;
uchar beef_cont;
uint pdata buf[50];
uchar mode;
uchar set_mode;
uchar R_wc;
uchar AD_data[2];
char dsp_buf[10];
unsigned longAD_BUF1,R1,RA,A0,set_R;
uint AD_UOR;
uchar ad_cont;
sbitout1=P1^4;
sbit out2=P1^5;
sbit out3=P1^6;
sbit out4=P1^7;
sbit buz= P3^6;
sbit led= P3^7;
uchar codemoto_tap[8]={0x08,0x0c,0x04,0x06,0x02,0x03,0x01,0x09,};//步进电机时序表格
uchar codemoto_tap2[8]={0x08,0x0a,0x02,0x06,0x04,0x05,0x01,0x09,};//步进电机时序表格
char code LCD_TAP2[10]={"012,3456789"};
uchar code dsp_[16]={"                "};
uchar bdata FLG;
sbit FLG_200MS=FLG^0;
sbit run_flg=  FLG^1;
sbit beef_en=  FLG^2;
sbit colck=    FLG^3;
sbit key_out=  FLG^4;
sbit ad_out=   FLG^5;
sbit call_en=  FLG^6;
void Ad_read(void);
void T0_int(void)
       TMOD=TMOD_int;    //设置定时器工作模式
        TCON=TCON_int;    //启运定时器
       TL0=TL0_int;   //装入定时器初值
       TH0=THO_int;   //装入定时器初值
       ET0=1;         //允许定时器0中断
        EA=1;         //开总断
void timer0_(void)interrupt 1 using 1           //  定时器溢出周期为125us已加入16t
      TR0=0;//
        TL0=TL0_int;
       TH0=THO_int;
       TR0=1;
       time_4ms++;
       if(beef_en)buz=!buz;
           buz=1;
       if(time_4ms>=16)
       {     //4ms平台
              time_4ms=0;
              if(set_mode==0)led=0;
                            led=1;
              if(beef_delay)beef_delay--;
              if(stop_run_delay)stop_run_delay--;
              if(set_step==0)
                     out1=0;
                     out2=1;
                     out3=1;
                     out4=1;
              if(set_step==1
                     out1=1;
                     out2=0;
                     out3=1;
                     out4=1;
              if(set_step==2)
              {      out1=1;
                     out2=1;
                     out3=0;
                     out4=1;
              if(set_step==3)
              {      out1=1;
                     out2=1;
                     out3=1;
                     out4=0;
              if(set_step==4)
              {      out1=1;
                     out2=1;
                     out3=1;
                     out4=0;
              colck=1;
              cont_200ms++;
              if(cont_200ms>=25)
                     cont_200ms=0;
                     FLG_200MS=1;
              if(moto_cont)
                     moto_cont--;
                     P1_buf=P1&0xf0;
                     if(run_flg)
                            P1=P1_buf|moto_tap[moto_cont];
                            P1=P1_buf|moto_tap[7-moto_cont];
              if(moto_time)
                     moto_time--;
                     moto_cont=8;
                     P1=P1&0xf0;
                     if(moto_time==0)
                            stop_run_delay=20;
              if(moto_time==0)
                     P1=P1&0xf0;
void moto_control(uint cont,ucharfx)
       if(fx==1)
              run_flg=1;
              run_flg=0;
       moto_time=cont;
void tast_control(void)
       unsignedchar i,j=0;
       chardsp[10];
       delay_ms(200);
       if((ad_out)&&(tast_delay==0))
              ad_out=0;
              lcd_dsp(0,0,"  电阻测试仪",12);
              lcd_dsp(1,0,"检测值: ",8);
              lcd_dsp(2,0,"筛选值: ",8);
              lcd_dsp(3,0,"误  差:",10);
              dsp_buf[0]=set_R/1000000;
              dsp_buf[1]=(set_R%1000000)/100000;
              dsp_buf[2]=((set_R%1000000)%100000)/10000;
              dsp_buf[3]=(((set_R%1000000)%100000)%10000)/1000;
              dsp_buf[4]=((((set_R%1000000)%100000)%10000)%1000)/100;
              dsp_buf[5]=(((((set_R%1000000)%100000)%10000)%1000)%100)/10;
              dsp_buf[6]=(((((set_R%1000000)%100000)%10000)%1000)%100)%10;
              for(i=0;i<3;i++)
                  if(dsp_buf==0)
                     dsp_buf='';
                     j++;
              for(i=0;i<7-j;i++)
                  dsp=dsp_buf[i+j];
              lcd_no_write2(2,4,dsp,7-j);
              dsp_buf[0]=R_wc/10;
              dsp_buf[1]=R_wc%10;
              lcd_no_write2(3,4,dsp_buf,2);
              lcd_dsp(3,5,"%",1);
              A0=AD_UOR*0.038147;
              R1=((2475000)/A0)-990;
              if(set_step==0)
                     RA=R1/10;
              if(set_step==1)
                     RA=R1;
              if(set_step==2)
                     RA=R1*10;
              if(set_step==3)
                     RA=R1*100;
              if(set_step==4)
                     RA=set_R;
              if(RA>set_R)
              {    if((RA-set_R)>(set_R*R_wc)/100)
                    if(call_en)beef_cont=1;
              if(RA<set_R)
              {     if((set_R-RA)>(set_R*R_wc)/100)
              if(set_step==0)
                     if(R1>1010)
                     {      set_step=1;
                            wcode(0x01);   //清除显示
              if(set_step==1)
              {      if(R1>1010)
                     {   set_step=2;
                         wcode(0x01);   //清除显示
                     if(R1<100)
                     {   set_step=0;
                         wcode(0x01);   //清除显示
              if(set_step==2)
              {      if(R1>1050)
                     {   set_step=3;
                         wcode(0x01);   //清除显示
                     if(R1<100)
                            set_step=1;
                            wcode(0x01);   //清除显示
              if(set_step==3)
                     if(R1<99)
                     {      set_step=2;
                            wcode(0x01);   //清除显示
                     if(R1>99999)
                     {      wcode(0x01);   //清除显示
                            set_step=4;
              if(set_step==4)
                     if(R1<99999)
                     {      set_step=3;
                            wcode(0x01);   //清除显示
              if(set_step==0)
                     dsp_buf[0]=LCD_TAP2[(R1%10000)/1000];
                     dsp_buf[1]=LCD_TAP2[((R1%10000)%1000)/100];
                     dsp_buf[2]=LCD_TAP2[(((R1%10000)%1000)%100)/10];
                     dsp_buf[3]='.';
                     dsp_buf[4]=LCD_TAP2[(((R1%10000)%1000)%100)%10];
                     if(((R1%10000)/1000)==0)
                     dsp_buf[0]='';
                     lcd_dsp(1,4,dsp_buf,5);
              if(set_step==1)
              {      dsp_buf[0]=LCD_TAP2[(R1%10000)/1000];
                     dsp_buf[3]=LCD_TAP2[(((R1%10000)%1000)%100)%10];
                     dsp_buf[0]='';
                     lcd_dsp(1,4,dsp_buf,4);
              if(set_step==2)
                     dsp_buf[2]='.';
                     dsp_buf[3]=LCD_TAP2[(((R1%10000)%1000)%100)/10];
                         for(i=0;i<4;i++)
                            dsp_buf=dsp_buf[i+1];
                     lcd_dsp(1,7,"K",1);
              if(set_step==3)
               {       dsp_buf[0]=LCD_TAP2[R1/10000];
                     dsp_buf[1]='.';
                     dsp_buf[2]=LCD_TAP2[(R1%10000)/1000];
                     dsp_buf[3]=LCD_TAP2[((R1%10000)%1000)/100];
                     dsp_buf[4]=LCD_TAP2[(((R1%10000)%1000)%100)/10];
                     dsp_buf[5]=LCD_TAP2[(((R1%10000)%1000)%100)%10];
                     lcd_dsp(1,7,"M",1);
              if(set_step==4)
                     lcd_dsp(1,4,"_____M",6);
void key_control(void)
{      uchari;
       if(key_out)
              key_out=0;
              if(key==0x0f)
                     wcode(0x01);   //清除显示
                     mode=0;
              if(key==0x17)
              {      mode=1;
                     beef_en=0;
                     beef_cont=0;
                     beef_delay=0;
                     set_step=1;
                     out1=1;
                     out2=0;
                     out3=1;
                     out4=1;
                     wcode(0x01);   //清除显示
                     lcd_dsp(0,0,dsp_,16);
                     lcd_dsp(1,0,dsp_,16);
                     lcd_dsp(2,0,dsp_,16);
                     lcd_dsp(3,0,dsp_,16);
                     lcd_dsp(1,0,"  请稍等候!",12);
                     set_read_cont=50;
                     for(i=0;i<=30;i++)buf=3*i;
                     ad_out=0;
                     for(i=0;i<4;)
                            if((stop_run_delay==0)&&(moto_time==0))
                            {      if(set_read_cont)
                                   {      set_read_cont--;
                                          if(set_read_cont==0)i=4;
                                          moto_time=8;
                                          ad_out=0;
                                          while(ad_out==0)
                                          {      Ad_read();
                                                 delay_ms(100);
                                          A0=AD_UOR*0.038147;
                                          R1=((2480000)/A0)-992;
                                          buf[49-set_read_cont]=R1/10;
                     show_line(buf);
              if(key==0x1b)
              {       beef_cont=1;
                     if(set_mode==0)
                            set_R++;
                     if(set_mode==1)
                     {      R_wc++;
              if(key==0x3b)
              {       key_cont=180;
                     beef_cont=1;
                     if(set_mode==0)
                            set_R++;
                     if(set_mode==1)
                     {      R_wc++;
              if(key==0x3d)
              {      key_cont=180;
                     if(set_mode==0)
                     {      if(set_R)
                            set_R--;
                     if(set_mode==1)
                     {      if(R_wc)
                            R_wc--;
                     beef_cont=1;
              if(key==0x1d)
                     if(set_mode==0)
                     {      if(set_R)
                            set_R--;
                     if(set_mode==1)
                     {      if(R_wc)
                            R_wc--;
                     beef_cont=1;
              if(key==0x1e)
              {      set_mode=set_mode^0x01;  beef_cont=1;
              if(key==0x3e)
                     call_en=!call_en;
                     if(call_en)beef_cont=0x81;
                     beef_cont=1;
void beef_control(void)
       if(beef_delay==0)
              if(beef_en)
                     beef_en=0;
                     beef_delay=20;
                     if(beef_cont&0x0f)
                            beef_cont--;
                            beef_en=1;
                            if(beef_cont&0x80)
                            beef_delay=100;
                            beef_delay=20;
void key_scan(void)
       if((P2&0x1f)!=0x1f)
              if(key_cont<200)
                     key_cont++;
                     if(key_cont==10)
                            key_buf=P2&0x1f;
                     if(key_cont==200)
                            key=key_buf|0x20;
                            key_out=1;
       {      if((key_cont>=10)&&(key_cont<200))
                     key=key_buf;
                     key_out=1;
              key_cont=0;
void Ad_read(void)
{      uinttemp,i,cons;// max0,min0,max1,min1,
       uintdata0[5],data1[5];//,t0,t1;
       longtemp0=0,temp1=0;
       cons=5;
       if(FLG_200MS)
              FLG_200MS=0;
              for(i=0;i<cons;i++)
                  AD7705_Write_Reg(0x38);        //启动AD7705AD转换
                  delay_ms(2);
                  AD_data[0]=AD7705_Read_Reg();  //保存高8位数据
                  data0=AD_data[0];
                  delay_ms(2);
                  AD_data[1]=AD7705_Read_Reg();  //保存低8位数据
                  data1=AD_data[1];
              for(i=0;i<cons;i++)
                  if(data0!=0xffff)
                  {  temp0=temp0+data0;  }
                  if(data1!=0xffff)
                  {  temp1=temp1+data1;  }
              temp0=temp0/(cons);
              temp1=temp1/(cons);
              temp=(uint)temp0*256+(uint)temp1;//保存16位AD
              AD_BUF1=temp+AD_BUF1;
              ad_cont++;
              if(ad_cont>=2)
                     ad_cont=0;
                     AD_UOR=AD_BUF1/2;
                     AD_BUF1=0;
                     ad_out=1;
                     if(tast_delay)tast_delay--;
void main(void)
       AD7705_Reset(1);
       setup();
       T0_int();
       run_flg=0;
       moto_cont=8;
       set_step=3;
       beef_cont=1;
       set_R=4000;
       R_wc=10;
       set_mode=0;
       call_en=0;
            if(colck)
                  colck=0;
                  if(mode==0)
                     tast_control();
                  delay_ms(2);
                  Ad_read();
                  beef_control();
                  key_scan();
key_control();
谢谢大家了!!!.0.0.
ID:51090 发表于 2014-8-4 00:22 来自触屏版 | 只看该作者
提示什么错误?上面的那些头文件都齐全吗?
最好是把整个工程文件都传上来方便找错误
ID:72584 发表于 2015-1-21 12:28 | 只看该作者
少了delay_ms(200);  还有定义都贴一起了  比如这个#defineTHO_int  0xff
   这样才对#define   THO_int   0xff
admin + 50 回帖助人的奖励!
