查看: 2857|回复: 0
strspn函数实现及简单应用
ID:51090 发表于 2014-9-24 22:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//:Vc++6.0  String strspn函数
//功能:找到目标中出现的字符的个数
//参数:str1 字符串1  str2 字符串2
//返回值:返回查找到的个数
#include<stdio.h>
int strspn(const char *str1, const char *str2);
int main()
int i;
char strtext[] = "129th";
char cset[] = "1234567890";
i = strspn (strtext,cset);
printf ("The length of initial number is %d.\n",i);
return 0;
if (str1 == NULL || str2 == NULL)
perror("str1 or str2");
return -1;
int count = 0;
const char *temp1 = str1;
const char *temp2 = str2;
while (*temp1 != '\0')
temp2 = str2; //将str2 指针从新指向在字符串的首地址
while (*temp2 != '\0')
if (*temp2 == *temp1)
count++;
temp2++;
temp1++;
return count;
