查看: 2895|回复: 0
strpbrk函数实现及简单使用
ID:51090 发表于 2014-9-24 22:24 | 显示全部楼层 |阅读模式
//:Vc++6.0  String  strpbrk函数
//功能:顺序在字符串str1中搜寻与str2中字符的第一个相同字符
//参数:str1 字符串1   str2 字符串2
//返回值:返回找到字符串的字符
#include<stdio.h>
const char *strpbrk(const char *str1, const char *str2);
int main()
char str[] = "This is a sample string";
char key[] = "aeiou";
const char * pch;
printf ("Vowels in '%s': ",str);
pch = strpbrk(str, key);
while (pch != NULL)
printf ("%c " , *pch);
pch = strpbrk(pch+1,key);
printf ("\n");
return 0;
if (str1 == NULL || str2 == NULL)
perror("str1 or str2");
return NULL;
const char *temp1 = str1;
const char *temp2 = str2;
while (*temp1 != '\0')
temp2 = str2; //将str2 指针从新指向在字符串的首地址
while (*temp2 != '\0')
if (*temp2 == *temp1)
return temp1;
temp2++;
temp1++;
return NULL;
//在vc++6.0中的运行结果为:Vowels in 'This is a sample string': i i a a e i
//注:和 strcspn函数 相似//:~
