查看: 3669|回复: 0
strncpy函数实现及简单应用
ID:51090 发表于 2014-9-24 22:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//:Vc++6.0  String  strncpy函数
//功能:指定大小的字符串拷贝
//参数:dest 目标字符串  str 要考的字符串  num 拷贝大小
//返回值:dest字符串地址
#include<stdio.h>
char *strncpy(char *dest, const char *str, int num);
int main()
char str1[]= "To be or not to be";
char str2[6];
strncpy (str2,str1,5);
printf("str2 = %s\n", str2);
return 0;
char *strncpy(char * dest, const char *str, int num)
//查错
    if (dest == NULL || str == NULL)
perror("dest or str");
return NULL;
//求长度
char *temp1 = dest;
const char *temp2 = str;
    int len;
while (*(temp2++) != '\0');
len = temp2 - str;
//拷贝
    if (num <= 0)
        *temp1 = '\0';
    else  if (num >= len)
        while (*str != '\0')
            *(temp1++) = *(str++);
        *temp1 = '\0';
int i;
        for (i = 0; i < num; i++)
        *temp1 = '\0';
return dest;
//在vc++6.0中的运行结果为:str2 = To be
//注:在拷贝时已经在尾部加了'\0'//:~
