查看: 3560|回复: 0
strncat函数实现及简单应用
ID:51090 发表于 2014-9-24 22:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//:Vc++6.0  String  strncat函数
//功能:按照num数量连接num个字符
//参数:dest 目标字符串  str 连接字符串  num 连接个数
//返回值:目标字符串
#include<stdio.h>
char *strncat(char *dest, const char *str, int num);
int main()
char str1[20] = "hello ";
char str2[20] = "world haha";
char str3[20] = "heihei";
strncat(str3, strncat(str1, str2, 6), 5);
printf("str1 = %s\n", str3);
return 0;
if (dest == NULL || str == NULL)
perror("dest or str");
return NULL;
char *temp = dest;
const char *temp1 = str; //前面必须是const修饰的,否则编译不通过
    int len;
while (*(temp1++) != '\0');
len = temp1 - str;
temp1 = str;
    while (*(temp++) != '\0');
    temp--;
    if (num <= 0) //当num值小于0时,不连接
        *temp = '\0';
    else if (num >= len) //当num值大于字符长度时,全部连接
        while (*(temp1) != '\0')
            *(temp++) = *(temp1++);
        *temp = '\0';
        for (int i = 0; i < num; i++)
        *temp = '\0';
return dest;
//在vc++6.0中的运行结果为:str1 = heiheihello//:~
