查看: 3839|回复: 2
“抛砖之四”--有史以来最简单的高端时钟
ID:67370 发表于 2014-11-3 17:57 | 显示全部楼层 |阅读模式
MAX7219是一款最适合初学者练手的驱动电路,单片电路可以显示8位数码管和8*8LED点阵,电路设计简单明了且可以多级连接,初学者动手容易成功,熟练掌握MAX7219,就基本通达了数码管和点阵的学习内容。希望能给大家以帮助。
#include <reg52.h>
#define INT8 unsigned char
#define Addr_Digit0 0x01
#define Addr_Digit1 0x02
#define Addr_Digit2 0x03
#define Addr_Digit3 0x04
#define Addr_Digit4 0x05
#define Addr_Digit5 0x06
#define Addr_Digit6 0x07
#define Addr_Digit7 0x08
#define Addr_Decode_Mode 0x09   //译码模式寄存器地址
#define Addr_Intensity 0x0A     //亮度控制寄存器地址
#define Addr_Scan_Limit 0x0B    //扫描控制寄存器地址
#define Addr_Shutdowm 0x0C      //掉电模式寄存器地址
#define Addr_Display_Test 0x0F  //显示检测寄存器地址
sbit Max7219_Din = P3 ^ 0;
sbit Max7219_Load = P3  ^1;
sbit Max7219_Clk = P3 ^ 2;
INT8 T_count = 0;
INT8 Hour_1 = 0, Hour_2 = 8;     //任意设定初始小时值。         8
INT8 Minute_1 = 3, Minute_2 = 0; //任意设定初始分钟值。         30
INT8 Second_1 = 0, Second_2 = 0; //任意设定初始小时值。         00
INT8 code max7219_led_code[11]=                         //共阴码表。
        0x7E,0x30,0x6D,0x79,0x33,              //0,1,2,3,4
        0x5B,0x5F,0x70,0x7F,0x7B,0x01           //5,6,7,8,9,-
void wr_max7219(INT8 addr,INT8 dat)
        INT8 i;
        Max7219_Load = 0;
        Max7219_Clk = 0;
        for( i = 0; i < 8; i ++ )
                Max7219_Din = ( bit )( addr & 0x80 );
                addr = addr << 1;
                Max7219_Clk = 1;
                Max7219_Clk = 0;
                Max7219_Din = ( bit )( dat & 0x80 );
                dat = dat << 1;
                Max7219_Clk = 1;
                Max7219_Clk = 0;
        Max7219_Load = 1;
        Max7219_Load = 0;
        wr_max7219( Addr_Shutdowm, 0x01 );
        wr_max7219( Addr_Scan_Limit, 0x07 );
        wr_max7219( Addr_Intensity, 0x0F );
        wr_max7219( Addr_Decode_Mode, 0x00 );
        TMOD |= 0x10;
        TMOD &= 0xDF;
        TR1 = 1;
        ET1 = 1;
        EA = 1;
                wr_max7219( Addr_Digit0, max7219_led_code[ Hour_1 ]);
                wr_max7219( Addr_Digit1, max7219_led_code[ Hour_2 ]);
                wr_max7219( Addr_Digit2, max7219_led_code[ 10 ]);
                wr_max7219( Addr_Digit3, max7219_led_code[ Minute_1 ]);
                wr_max7219( Addr_Digit4, max7219_led_code[ Minute_2 ]);
                wr_max7219( Addr_Digit5, max7219_led_code[ 10 ]);
                wr_max7219( Addr_Digit6, max7219_led_code[ Second_1 ]);
                wr_max7219( Addr_Digit7, max7219_led_code[ Second_2 ]);
void interrupt_timer1()        interrupt 3
        TH1 = ( 65536 - 5000 ) / 256;
        TL1 = ( 65536 - 5000 ) % 256;
        T_count ++;                           //定时器中断计数器加一
        if( T_count == 161 )                   //微调
                T_count = 0;                      //清零定时器中断计数器
                Second_2 ++;                        //秒个位计数器加一
                if( Second_2 == 10 )
                        Second_1 ++;
                        Second_2 = 0;
                        if( Second_2 == 0 && Second_1 == 6 )
                                Second_1 = 0;
                                Second_2 = 0;
                                Minute_2 ++;
                                if( Minute_2 == 10 )
                                        Minute_1 ++;
                                        Minute_2 = 0;                                    //分个位计数器清零
                                        if(Minute_2 == 0 && Minute_1 == 6 )
                                                Minute_1 = 0;
                                                Minute_2 = 0;
                                                Hour_2 ++;
                                                if( Hour_2 == 10 && Hour_1 <= 2)
                                                        Hour_1 ++;
                                                        Hour_2 =0;                                          //时个位计数器清零
                                                else if( Hour_2 == 4 && Hour_1 == 2 )
                                                        Hour_1 = 0;
                                                        Hour_2 = 0;
admin + 50 共享资料的积分奖励!
ID:79911 发表于 2015-5-13 23:02 | 显示全部楼层
谢谢楼主
ID:194701 发表于 2017-5-1 17:12 | 显示全部楼层
谢谢楼主
