查看: 3463|回复: 1
求各位师哥师姐相助,感激不尽
ID:70572 发表于 2014-12-16 17:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位盆友,我想用lcd162显示矩阵键盘扫描值,结果一上电一直显示000000000,我是初学者,不会改 求各位大神帮忙改
#include
unsigned char code table[]={'0','1','2','3','4','5','6','7','8',
'9','A','B','C','D','E','F'};//转换成液晶显示的字符
uchar num,temp;
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P2^5;
sbit lcdrs=P1^0;
sbit lcdwr=P1^1;
uchar keyscan();
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init ()
wela=0; dula=0; lcdwr=0; lcden=0; write_com(0x38); write_com(0x0f); write_com(0x06); write_com(0x01); write_com(0x80);
void main ()
init ();
while (1)
uchar keyscan();
   write_date(table[keyscan()]);   delay(20);
uchar keyscan() //键盘扫描函数,返回一个值num
        P3=0xfe;        temp=P3;        temp=temp&0xf0;        while(temp!=0xf0)            {                delay(5);                temp=P3;                temp=temp&0xf0;                while(temp!=0xf0)                {                    temp=P3;                switch(temp)                    {                        case 0xee:num=1;                            break;                        case 0xde:num=2;                            break;                        case 0xbe:num=3;                            break;                        case 0x7e:num=4;                            break;                    }                while(temp!=0xf0)                    {                        temp=P3;                        temp=temp&0xf0;                    }                }            }        P3=0xfd;        temp=P3;        temp=temp&0xf0;        while(temp!=0xf0)            {                delay(5);                temp=P3;                temp=temp&0xf0;                while(temp!=0xf0)                {                    temp=P3;//必须重新读取P3口的值,否则temp将一直不等于0xf0                switch(temp)                    {                        case 0xed:num=5;                            break;                        case 0xdd:num=6;                            break;                        case 0xbd:num=7;                            break;                        case 0x7d:num=8;                            break;                    }                while(temp!=0xf0)                    {                        temp=P3;                        temp=temp&0xf0;                    }                }            }        P3=0xfb;        temp=P3;        temp=temp&0xf0;        while(temp!=0xf0)            {                delay(5);                temp=P3;                temp=temp&0xf0;                while(temp!=0xf0)                {                    temp=P3;                switch(temp)                    {                        case 0xeb:num=9;                            break;                        case 0xdb:num=10;                            break;                        case 0xbb:num=11;                            break;                        case 0x7b:num=12;                            break;                    }                while(temp!=0xf0)                    {                        temp=P3;                        temp=temp&0xf0;                    }                }            }        P3=0xf7;        temp=P3;        temp=temp&0xf0;        while(temp!=0xf0)            {                delay(5);                temp=P3;                temp=temp&0xf0;                while(temp!=0xf0)                {                    temp=P3;                switch(temp)                    {                        case 0xe7:num=13;                            break;                        case 0xd7:num=14;                            break;                        case 0xb7:num=15;                            break;                        case 0x77:num=16;                            break;                    }                while(temp!=0xf0)                    {                        temp=P3;                        temp=temp&0xf0;                    }                }            }
return num;
ID:70572 发表于 2014-12-17 11:46 | 只看该作者
都没人帮忙吗???哭。。。。。
