查看: 2181|回复: 1
求助大神级人物,帮忙改动一个程序,只要改后结果能正常运行即可,拜托 拜托!
ID:71620 发表于 2015-1-4 22:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    ORG  0000H
    AJMP 0050H
    ORG 000BH
    AJMP 0100H
    ORG 0050H
    MOV SP,#6FH
    MOV TMOD,#01H
    MOV TH0,#3CH
    MOV TL0,#0B0H
    SETB EA
    SETB ET0
    SETB PT0
    MOV R3,#14H
    MOV R4,#0
    SETB TR0
    SJMP $
    ORG 0100H
    DJNZ R3,NEXT0
    MOV  R3,#14H
    INC R4
    CJNE R4,#1,NEXT1
L10:MOV R0,#7
    MOV DPTR,#TABLE
L2:CLR A
    MOVC A,@A+DPTR
    MOV P0,A
    ACALL DELAY1
    INC DPTR
    DJNZ R0,L2
    SJMP NEXT0
DELAY1:MOV R1,#250
LOOP1:MOV R2,#250
LOOP2:NOP
      NOP
      NOP
      NOP
      NOP
      DJNZ        R2,LooP2
      DJNZ        R1,LooP1
      RET
NEXT1: CJNE R4,#2,NEXT2
L100:MOV R0,#15
    MOV DPTR,#TABLE1
L20:CLR A
    MOVC A,@A+DPTR
    MOV P0,A
    ACALL DELAY2
    INC DPTR
    DJNZ R0,L20
    SJMP next0
DELAY2:MOV R1,#250
L00P3:MOV R2,#250
LOOP4:NOP
      NOP
      NOP
      NOP
      NOP
      DJNZ R2,LOOP4
      DJNZ R1,L00P3
      RET
NEXT2: CJNE R4,#3,NEXT0
L1000:MOV R0,#7
      MOV DPTR,#TABLE2
   L3:CLR A
      MOVC A,@A+DPTR
     MOV P0,A
     ACALL DELAY3
     INC DPTR
     DJNZ R0,L3
     MOV R4,#0
     SJMP next0
DELAY3:MOV R1,#250
LooP5:MOV R2,#250
LOOP6:NOP
        NOP
        NOP
        NOP
        NOP
       DJNZ        R2,LooP6
       DJNZ        R1,LooP5
       RET
NEXT0 : MOV TH0,#3CH
        MOV TL0,#0B0H
        SETB TR0
        RETI
TABLE:
DB  7EH,0BDH,0DBH,0E7H,0DBH,0BDH,7EH
TABLE2:
DB 3FH,0CFH,0F3H,0FCH,0F3H,0CFH,3FH
TABLE1:
DB 0FEH,0FDH,0FBH,0F7H,0EFH,0DFH,0BFH,07FH,0BFH,0DFH,0EFH,0F7H,0FBH,0FDH,0FEH
END
ID:18297 发表于 2015-1-5 18:59 | 只看该作者
这个程序功能上能够实现P0接LED灯串接电阻上拉到电源。
LED灯循环点亮,有一定的变化。仿真没有问题。
admin + 50 回帖助人的奖励!
