查看: 8874|回复: 0
AVR内部EEPROM读写函数 EEPROM.H
ID:3721 发表于 2015-1-5 16:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #pragma used+
  2. ///写单字节EEPROM
  3. void EEPROM_write(unsigned int uiAddress, unsigned char ucData);
  4. ///读单字节EEPROM
  5. unsigned char EEPROM_read(unsigned int uiAddress);
  6. ///写双字节EEPROM
  7. void EEPROM_write2(unsigned int uiAddress, unsigned int ucData);
  8. ///读双字节EEPROM
  9. unsigned int EEPROM_read2(unsigned int uiAddress);
  10. ///读4字节EEPROM
  11. unsigned long EEPROM_read4(unsigned int uiAddress);
  12. ///写4字节EEPROM
  13. void EEPROM_write4(unsigned int uiAddress, unsigned long ucData);
  14. #pragma used-
  15. #pragma library eeprom.lib
  16. EEPROM.C
  17. //#include "eeprom.h"
  18. /* EEPROM Control Register */
  19. #define    EERIE        3
  20. #define    EEMWE        2
  21. #define    EEWE         1
  22. #define    EERE         0
  23. #if  funcused EEPROM_write
  24. ///写单字节EEPROM
  25. void EEPROM_write(unsigned int uiAddress, unsigned char ucData)
  26. {
  27. //#asm("cli")
  28. ////* 等待上一次写操作结束
  29. while(EECR & (1<<EEWE));
  30. ////* 设置地址和数据寄存器
  31. EEAR = uiAddress;
  32. EEDR = ucData;
  33. ////* 置位EEMWE
  34. EECR |= (1<<EEMWE);
  35. ////* 置位EEWE 以启动写操作
  36. EECR |= (1<<EEWE);
  37. //#asm("sei")
  38. }
  39. #endif
  40. #if  funcused EEPROM_read
  41. ///读单字节EEPROM
  42. unsigned char EEPROM_read(unsigned int uiAddress)
  43. {
  44. #asm("cli")
  45. ///* 等待上一次写操作结束
  46. while(EECR & (1<<EEWE));
  47. ///* 设置地址寄存器*/
  48. EEAR = uiAddress;
  49. ///* 设置EERE 以启动读操作
  50. EECR |= (1<<EERE);
  51. ///* 自数据寄存器返回数据
  52. return EEDR;
  53. //#asm("sei")
  54. }
  55. #endif
  56. #if  funcused EEPROM_read2
  57. ///读双字节EEPROM
  58. unsigned int EEPROM_read2(unsigned int uiAddress)
  59. { unsigned int  ucdata;
  60. // #asm("cli")
  61. ///* 等待上一次写操作结束
  62. while(EECR & (1<<EEWE));
  63. ///* 设置地址寄存器*/
  64. EEAR = uiAddress+1;
  65. ///* 设置EERE 以启动读操作
  66. EECR |= (1<<EERE);
  67. ///* 自数据寄存器返回数据
  68. ucdata = EEDR;
  69. ucdata =ucdata<<8;
  70. while(EECR & (1<<EEWE));
  71. ///* 设置地址寄存器*/
  72. EEAR = uiAddress;
  73. ///* 设置EERE 以启动读操作
  74. EECR |= (1<<EERE);
  75. ///* 自数据寄存器返回数据
  76. ucdata |= EEDR;
  77. return ucdata;
  78. //#asm("sei")
  79. }
  80. #endif
  81. #if  funcused EEPROM_write2
  82. ///写双字节EEPROM
  83. void EEPROM_write2(unsigned int uiAddress, unsigned int ucData)
  84. {
  85. //#asm("cli")
  86. ////* 等待上一次写操作结束
  87. while(EECR & (1<<EEWE));
  88. ////* 设置地址和数据寄存器
  89. EEAR = uiAddress;
  90. EEDR = ucData & 0x00ff;
  91. ////* 置位EEMWE
  92. EECR |= (1<<EEMWE);
  93. ////* 置位EEWE 以启动写操作
  94. EECR |= (1<<EEWE);
  95. while(EECR & (1<<EEWE));
  96. ////* 设置地址和数据寄存器
  97. EEAR = uiAddress+1;
  98. EEDR = (ucData & 0xff00)>>8;
  99. ////* 置位EEMWE
  100. EECR |= (1<<EEMWE);
  101. ////* 置位EEWE 以启动写操作
  102. EECR |= (1<<EEWE);
  103. //#asm("sei")
  104. }
  105. #endif
  106. #if  funcused EEPROM_read4
  107. ///读4字节EEPROM
  108. unsigned long EEPROM_read4(unsigned int uiAddress)
  109. { unsigned long  ucdata;
  110. // #asm("cli")
  111. ///* 等待上一次写操作结束
  112. while(EECR & (1<<EEWE));
  113. ///* 设置地址寄存器*/
  114. EEAR = uiAddress+3;
  115. ///* 设置EERE 以启动读操作
  116. EECR |= (1<<EERE);
  117. ///* 自数据寄存器返回数据
  118. ucdata = EEDR;
  119. ucdata =ucdata<<8;
  120. EEAR = uiAddress+2;
  121. ///* 设置EERE 以启动读操作
  122. EECR |= (1<<EERE);
  123. ///* 自数据寄存器返回数据
  124. ucdata |= EEDR;
  125. ucdata =ucdata<<8;
  126. EEAR = uiAddress+1;
  127. ///* 设置EERE 以启动读操作
  128. EECR |= (1<<EERE);
  129. ///* 自数据寄存器返回数据
  130. ucdata |= EEDR;
  131. ucdata =ucdata<<8;
  132. while(EECR & (1<<EEWE));
  133. ///* 设置地址寄存器*/
  134. EEAR = uiAddress;
  135. ///* 设置EERE 以启动读操作
  136. EECR |= (1<<EERE);
  137. ///* 自数据寄存器返回数据
  138. ucdata |= EEDR;
  139. return ucdata;
  140. //#asm("sei")
  141. }
  142. #endif
  143. #if  funcused EEPROM_write4
  144. ///写4字节EEPROM
  145. void EEPROM_write4(unsigned int uiAddress, unsigned long ucData)
  146. {
  147. //#asm("cli")
  148. ////* 等待上一次写操作结束
  149. while(EECR & (1<<EEWE));
  150. ////* 设置地址和数据寄存器
  151. EEAR = uiAddress;
  152. EEDR = ucData & 0x000000ff;
  153. ////* 置位EEMWE
  154. EECR |= (1<<EEMWE);
  155. ////* 置位EEWE 以启动写操作
  156. EECR |= (1<<EEWE);
  157. ucData = ucData>>8;
  158. while(EECR & (1<<EEWE));
  159. ////* 设置地址和数据寄存器
  160. EEAR = uiAddress+1;
  161. EEDR = ucData & 0x000000ff;
  162. ////* 置位EEMWE
  163. EECR |= (1<<EEMWE);
  164. ////* 置位EEWE 以启动写操作
  165. EECR |= (1<<EEWE);
  166. ucData = ucData>>8;
  167. while(EECR & (1<<EEWE));
  168. ////* 设置地址和数据寄存器
  169. EEAR = uiAddress+2;
  170. EEDR = ucData & 0x000000ff;
  171. ////* 置位EEMWE
  172. EECR |= (1<<EEMWE);
  173. ////* 置位EEWE 以启动写操作
  174. EECR |= (1<<EEWE);
  175. ucData = ucData>>8;
  176. while(EECR & (1<<EEWE));
  177. ////* 设置地址和数据寄存器
  178. EEAR = uiAddress+3;
  179. EEDR = ucData & 0x000000ff;
  180. ////* 置位EEMWE
  181. EECR |= (1<<EEMWE);
  182. ////* 置位EEWE 以启动写操作
  183. EECR |= (1<<EEWE);
  184. //#asm("sei")
  185. }
  186. #endif
